Old 07-01-2003, 10:32 AM   #1
chargedstang89
Angry Wacky Wipers...help!
Everytime I turn the key forward on my truck (85 gmc 4x4), the winshield wipers turn on and go for about 3 or 4 swipes. The actual turn signal lever was broken in my truck, and I replaced that. While I had the column apart, I also replaced the winshield wiper switch that the turn signal lever goes into inside of the column. This did not cure the problem. What in the heck is making my wipers do this? There is a box or a relay looking thing that is mounted underneath my column right under the dash. Could this be bad, or is there a relay out on my winshield wiper motor that could have gone bad? Please help because this is driving me absolutely nuts
chargedstang89 is offline   Reply With Quote
Old 07-01-2003, 11:33 AM   #2
Prerunner1982
Prerunner1982's Avatar
just accept it. its part of having a 73-87. mine use to come on but not shut up until i shut the whole truck off. replaced switch, fixed the problem. now they will come one, usually only one swip. then stop about every 12-15 min while the truck is on. i am at the point that half the time i dont even notice. sorry i am not much help. but there are more than a handful of memebers that have very similar problems.
Jon
1982 Chevy Silverado 350/th350.... RETIRED
1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231
Oklahoma Roll Call
Prerunner1982 is offline   Reply With Quote
Old 07-01-2003, 12:31 PM   #3
ElGracho
Gentleman Jim Driver
ElGracho's Avatar
You problem is in your delay box. Replace it and that should fix your problem. Several people have done this recently and reported positive results here. The boxes are fairly expensive if you have to pay list price at a dealer. One place to look for them in wrecking yards is vans. Many of them have intermittants and they don't seem to get parted nearly as fast as pickups.
Joe
'75 GMC Gentleman Jim
'84 Chev C10 Short Wide - Super duper plain (manual steering, manual brakes, no dome light, no cig lighter)
'85 Chev C10 Short Wide - Super plain Vortec 4.8 4L60E trans
also: '81 K30, '83 C30 Crew Dually, '84 M1028 CUCV, '85 M1009 CUCV, another '85 C10 SWB, '89 R3500 Flatbed
ElGracho is offline   Reply With Quote
Old 07-01-2003, 01:10 PM   #4
chargedstang89
where is the delay box located and what does it look like? the wipers didn't do that when i first got the truck, just started about 3 months ago...just frustrated. where is it located on the truck?
Old 07-01-2003, 01:22 PM   #5
ElGracho
ElGracho's Avatar
It is usually clipped to the bottom of the steering column. It is about 2x4" and is black plastic with an aluminum heat sink on one side. It has electrical plugs on each end.
Joe
Old 07-01-2003, 02:28 PM   #6
remy
clean stuff up...
when i first got my truck(83 k10) i would turn on the wipers to clean the windshield and then they would just keep going and squirting ... under the hood where the wiper motor is are two terminals/connectors... i unhooked, cleaned and rehooked them and now they work fine... off when turned off, on when on, and the wiper juice stops spraying after five or six cycles...
i used emory cloth or a small file to get rid of corrosion and contact cleaner to make sure...
83 k10
350 w/edelbrock 1904 Q-jet
th400
4wd
have a nice day...
remy is offline   Reply With Quote
Old 07-01-2003, 02:48 PM   #7
chargedstang89
ok, i know exactly which box you are talking about. that was the next thing i was planning on replacing. i'm not sure, but i think i remember seeing them in year one's catalog for like $70 or something. will be worth it if i can't find one in a junk yard, just for peace of mind because it's driving me insane!!!!
Old 07-01-2003, 05:04 PM   #8
apstguy
LED King
apstguy's Avatar
I have had the same problem for MONTHS!!! It is driving me insane too. For some reason, it could be either the switch or the delay control module. People have had luck with both. It is tearing up my wipers! UGH! If you get a new on, be prepared to shell out $80. I need to go get me one!
Tyler
1985 C10 305 w/ Bowtie OD TH700R4 3.42 LSD 202,000 miles
2006 Ford Focus ZX3 5-speed Stick
2016 Chevy Spark EV
Gone: 2002.5 VW GTI 24v VR6
Gone: 2008 VW R32
apstguy is offline   Reply With Quote
Old 07-01-2003, 08:01 PM   #9
bigd65
bigd65's Avatar
get one from a wrecking yard. i grab them everytime i see one. i have 2 extra's.
2004 Silverado Crewcab
1972 Chevy Monte Carlo
2017 Chevy Tahoe
bigd65 is offline   Reply With Quote
Old 07-01-2003, 08:03 PM   #10
68 Stepside
huh?
68 Stepside's Avatar
My friends 87 'burb's wipers make one cycle if he puts the auto trans down into 1st....gotta love 73-87's
Someday when I'm lonely,
Wishing you weren't so far away,
Then I will remember
Things we said today.
RIP El Jay
68 Stepside is offline   Reply With Quote
Old 07-02-2003, 11:04 AM   #11
chargedstang89
well, one of my local parts stores can get me the Wiper Delay Module for like $33. I had them order one and it will be in on thursday...hopefully that cures the problem. If not, I guess it won't be the first time I wasted money on a part that didn't need replaced.
Old 07-02-2003, 07:33 PM   #12
bigd65
bigd65's Avatar
DITTO charged, i do that all the time it seems like
2017 Chevy Tahoe
Old 07-03-2003, 05:01 PM   #13
chargedstang89
anyone know where i can get one other than a junk yard? my local parts place can't get it. i've done some research and it seems GM discontinued this part 5 years ago????
Old 07-03-2003, 05:36 PM   #14
ElGracho
ElGracho's Avatar
No, it's not discontinued. What year are you looking for and I will get you a part number.
Joe
Old 07-03-2003, 05:37 PM   #15
ElGracho
ElGracho's Avatar
Doh, I just looked at your first post again and saw it was an 85, I'll get that number.
Joe
Old 07-07-2003, 10:06 AM   #16
chargedstang89
Gracho...thanks for the effort, but I went to the junk yard this weekend and I was able to find two of the relays in two different vans. Plugged it into my truck and bam...the wipers no longer turn on when I turn the truck on, and my washers also work now. Thanks for all of the info guys.
J
Old 07-07-2003, 12:59 PM   #17
Russell
Professional Grade
Russell's Avatar
Oh yeah, for those of you who have the problem of them turning on, then never turning off, or constantly spraying without end... there are two cables on the wiper module itself, unplug both of them and clean them well, the one that is higher up turns your wipers off after the end of their cycle, and the lower one starts the wiper pump rotation (at least in my 80)
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap)
Russell is offline   Reply With Quote
