TCI EZ-TCU Trans Controller
I was using this to control my 4l80e but wont be needing it anymore since my new LS motor ECM will control my transmission. I ran this system for about 8 months.
TPS Signal / Throttle - The THROTTLE connector can be plugged into an early style GM TPS sensor or if you have EFI The loose TPS SIGNAL wire is provided to facilitate sharing the TPS signal between two systems. For carbureted application I also have the remote mount TPS to go with it for $75. Asking $300 for the TCI EZ-TCU and $75 for the Remote TPS. Part Numbers TCI Remote TPS 377450 TCI EZ-TCU 302820
My Build Thread 72 K5 http://67-72chevytrucks.com/vboard/s...d.php?t=628612 Build version 2.0: 72 K5 6.0 LQ9, 4L80e, NP205 http://67-72chevytrucks.com/vboard/s...d.php?t=793192 ____________________________________________ 1972 CST K5 Blazer Dark Olive |
Re: TCI EZ-TCU Trans Controller
I am interested if you still have it. I have a couple questions, I will pm you.
Sold on ebay.
