Old 10-25-2013, 03:55 PM   #1
jmorri34
jmorri34's Avatar
Temp guage ?
Hey just curious, I got the truck street legal and registered and just now getting to drive it. My question is, I have factory guages and a new temp sender and was just wondering where everyone using the factory guage, where does the needle sit on the factory guage. I am going to put in autometer guages eventually but just wondered where everyones factory guage say while driving. Thanks
1969 cst prostreet
http://67-72chevytrucks.com/vboard/s...d.php?t=568661
jmorri34 is offline   Reply With Quote
Old 10-25-2013, 04:29 PM   #2
hayhauler71
hayhauler71's Avatar
Re: Temp guage ?
1/4 to 1/2 180 degrees to 200 at 1/2
Fuzzy
hayhauler71 is offline   Reply With Quote
Old 10-25-2013, 04:33 PM   #3
Lee H
Lee H's Avatar
Re: Temp guage ?
Just off cold at normal operation temp, 190 as measured with IR gun.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner.
1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components.
My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703
Lee H is offline   Reply With Quote
Old 10-25-2013, 05:09 PM   #4
Don Quixote
Don Quixote's Avatar
Re: Temp guage ?
I am running a 195 degree thermostat only because I know that small blocks like to run a bit on the warmer side. My guage when warm reads about 5/8 to hot. I am happy with that reading because I'm good at 200 degrees. The needle reads an overheat at 220 degrees, which is just about overheating.
Rocinante: 1972 GMC C25, 292, SM465, 14 bolt, power nothing, 440k and still handles my PCS moves
Jorge: Kia Roller-skate with lots of buttons for the wife
Wovoka: 2017 Indian Chief Vintage, better on gas but not much
So far, this is the oldest I've ever been.
Don Quixote is offline   Reply With Quote
Old 10-25-2013, 06:33 PM   #5
Lattimer
Lattimer's Avatar
Re: Temp guage ?
Its going to vary a lot depending on the sender you have. A replacement sender will read different than an original. I had to add a resistor inline with my wire to get mine to not read full hot at normal operating temp.
Shawn
1970 Chevy C-10 SWB, 350, TKO 600 5 speed
My build http://67-72chevytrucks.com/vboard/s...d.php?t=559881
Lattimer is offline   Reply With Quote
Old 10-25-2013, 06:56 PM   #6
zeldman
zeldman's Avatar
Re: Temp guage ?
The factory temp gauge in the dash is not there to tell me the temperature, it is there to tell me when there are changes. Let the engine run and warm up to operating temperature, then use a thermometer (IR is safer) to see it the coolant temp is where you want it, then note where the gauge is. Any large, sudden changes and you will know that something is wrong.
2005 GMC K2500HD D/A
1993 GMC K1500
2011 Subaru Legacy.
2013 Subaru Outback
1970 C-10 2WD, SWB stepside, 292, TH350, PS, more rust than anything. God is my pilot.
zeldman is offline   Reply With Quote
Old 10-25-2013, 08:36 PM   #7
jmorri34
jmorri34's Avatar
Re: Temp guage ?
Ok thanks everyone, I did just put another temp sender in it and at operating temp it is about at 5/8 and rolls back and forth a little but doesnt go farther than that so I should be good till I get real guages on it. Once again thanks everyone for the help!
1969 cst prostreet
