11-29-2006, 11:34 PM | #1 |
Rear disk brake kit for sale
I am sadly selling this kit I was going to put on my own truck to fund repairing my blown up rear end. Oh well, enough whining, this is a setup with Impala SS components. It comes with everything you need except gear oil, I'm even including brake fluid. Here's the rundown.
USED Impala calipers I purchased from Burnsman USED caliper brackets that were cleaned, painted, and slides greased NEW 5x5 Raybestos Impala rotors, hats painted with high temp caliper paint NEW laser cut axle brackets with new hardware from glock35ipsc NEW braided flexable brake hose from Precision Brake, factory Impala Banjo bolt on caliper end, 3/16 inverted to AN on the other end, with new copper washers Two NEW 30'' sections of brake line to replace the old ones running across the diff tubes NEW Duralast Brake pads USED factory Impala flex hose brackets and clips NEW CPP disc/disc prop valve with lines and bracket I'm letting this go for $300 plus shipping.
Chris 74 Custom Deluxe SWB 350/350/3.73’s 99 2wd Silverado RCSB 5.3/4L60/3.90’s http://www.classictrucks.com/feature...short_bed.html Last edited by powell72; 12-01-2006 at 12:01 AM. |
11-30-2006, 11:35 AM | #2 |
Keepin an eye out
Re: Rear disk brake kit for sale
Nice, are those calipers set up for e-brake?
1970 Chevy C10 SWB 5.3 1996 Toyota Tacoma SR5 4x4 2007 Vespa GTS 250 Scooter ZIP 91351 |
11-30-2006, 01:09 PM | #3 |
No, I'm sorry, I forgot to put that. They use the hat style e-brake with the shoes in the back of the rotor.
Chris 74 Custom Deluxe SWB 350/350/3.73’s 99 2wd Silverado RCSB 5.3/4L60/3.90’s http://www.classictrucks.com/feature...short_bed.html |
12-02-2006, 01:37 PM | #4 |
That's a hell of a deal, I wish I had a 5-lug rear.
70 C/10 SWB 402/TH400/3.73 "The Needy Beast" 200,000 Mile Club Disc Brake Club Owner installed options: Front Sway Bar Power Steering Power Brakes Cigar Lighter Courtesy Lights Deluxe Side Markers Wiper Delay Power windows Power Locks Sniper EFI 2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear |
12-02-2006, 03:00 PM | #5 |
Keepin an eye out
Im a little confused and also interested in the kit...Does this mean they come e-brake ready? With or without? Can be added? I know im a little sloooow
12-02-2006, 05:24 PM | #6 |
It comes without the e-brake. I think if you had Impala (SS or 9C1) e-brake backing plates and shoes you could probably modifiy it to fit on the truck housing end instead of using the bracket I have in my kit. I figured my truck is an auto, I never use the e-brake, I used it one time right after I got the truck to see if it worked, haven't used it since.
12-02-2006, 01:53 PM | #7 |
The LuvShack Garage
I almost bought something like these calipers awhile back, but was told
they would not clear 15" wheels, can you confirm this claim either way?
12-02-2006, 02:08 PM | #8 |
Yes, they will clear a 15'' truck rally, I mocked this setup up in a spare wheel I have.
12-02-2006, 02:44 PM | #9 |
BTW, I'm also including a diff cover gasket and one axle seal. I only had one leaking. LUV, I have one person interested right now, if he backs out and you wanted this setup I could save you shipping, I'll be leaving for Symrna on the the 22nd. I could bring them with me.
12-02-2006, 05:06 PM | #10 |
The LuvShack Garage
The caprice / impalla e-brake was like a traditional drum brake, it
was inside the hub part of that rotor, and the cables went to it.
12-04-2006, 11:56 PM | #11 |
Ttt, anybody?
12-05-2006, 06:55 PM | #12 |
Next project: 1970 K10
Dude, that 6-lug rear is just sittin outside the shop not being used. It's yours to use for however long you need it, all you got to do is come get it!!! Or I can bring it to you. I even have some 6-lug rallys you can use. It's 3.73 and has new (well, ~200 mile old) brakes, drums, and cylinders. At least it will get you back on the road.
No wonder I haven't seen your truck at your shop for the past week or so......
Bob 1970 Chevy K10 LWB "Goldie" 350/TH350 next project!! 1981 Chevy C10 LWB 355/TH350 - My son's truck LS SWAP FORUM! Tons of LS swap info here! PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET! CLICK HERE FOR THE FAQ INDEX by KRUE Last edited by glock35ipsc; 12-05-2006 at 06:59 PM. |
12-06-2006, 12:08 AM | #13 |
I appreciate the offer Bob, but I already have the new parts at the shop, $600 worth. I took my truck apart the Monday before Thanksgiving to do the brake swap when I found out the bolt had broken out of the cross shaft and it starting moving around and hogged out the carrier. Plus it was welded to one of the spider gears. I'll have to show you the mess when I get a chance. When I recover from the hit to the wallet I'll get another set of brackets from you and try again!
12-06-2006, 12:11 AM | #14 |
What rear are you running or were you running, I might have some parts ie. bearings ect. laying around if you need them. I also have 3.73s for a 10 bolt if that is what you have.
12-06-2006, 12:13 AM | #15 |
oops, I just saw your new post, I gess you have all the parts. are you setting up the gears your self?
12-06-2006, 12:27 AM | #16 |
Damn those bolts!!! I still need to get one for mine. I'll set a set of brackets aside for you.
Bob 1970 Chevy K10 LWB "Goldie" 350/TH350 next project!! 1981 Chevy C10 LWB 355/TH350 - My son's truck LS SWAP FORUM! Tons of LS swap info here! PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET! CLICK HERE FOR THE FAQ INDEX by KRUE |
12-06-2006, 12:17 PM | #17 |
Active Member
DO I HAVE TO PULL THE AXLES TO INSTALL THESE WHAT ALL IS REQUIRED i HAVE A 72 WITH 5 BOLT DISC FRONT PLANNING ON ADDING BOOSTER, WILL BE IN MURFREESBORO AT CHRISTMAS SO COULD SAVE THE SHIPPING FOR ME ALSO, ANYTHING ELSE FOR SALE??
12-06-2006, 12:18 PM | #18 |
Active Member
Also Ive Been Pretty Much Copying Your Truck Hope You Dont Mind I Love The Ole Blue And White And Your Drop Looks Perfect Mines Just A C/10 Though
12-06-2006, 10:37 PM | #19 |
chevota- I do have all the parts I need, thanks. My buddy that works for Houska's in Fort Collins is setting them up. He was the rearend guy (that doesn't sound good) at Dellenbach Chevrolet for years and has always set up my gears.
jpkerley-I'm working with someone on them right now and there is someone else in line after that. If it all falls through to you I'll gladly deliver them. You do need to pull the axles to install. Bob, stop by some time and check out what I had to do to get the cross shaft out!
Chris 74 Custom Deluxe SWB 350/350/3.73’s 99 2wd Silverado RCSB 5.3/4L60/3.90’s http://www.classictrucks.com/feature...short_bed.html Last edited by powell72; 12-06-2006 at 10:40 PM. |
12-06-2006, 10:46 PM | #20 |
Will do!
12-07-2006, 04:52 PM | #21 |
Active Member
Pm Me If The Others Fall Thru Thanks
12-30-2006, 09:34 PM | #22 |
are these still available? PM me please...
01-03-2007, 06:35 PM | #23 |
These are sold. Sorry for not listing it, I've been out of town since before Christmas.
