HydroBoost Plumbing Diagram Help
Hello everyone, I have my hydro boost installed and I am getting ready to plumb all the hoses. I converted my 67 to power steering and the LS is out of a 2005 Silverado. I noticed the power steering pump has 2 barb connections and the high pressure fitting on the back of the pump. All the diagrams I came across showed only 1 barb return fitting on the pump. I found another diagram and modified it to what I have and would like input to make sure I am plumbing it up right. Thank you in advance for the help.
Last edited by Worldofhurts; 10-06-2019 at 03:15 PM. Reason: forgot to include photo |
![]() Join Date: Aug 2004
Re: HydroBoost Plumbing Diagram Help
That will work, it is the way those systems are plumbed from the factory.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO http://67-72chevytrucks.com/vboard/s...d.php?t=788602 93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday... 05 Jeep Wrangler Unlimited. 3” lift & 6-speed 02 E320 the insurance total “free car” 13 Tahoe LTZ |
Thank you, It's my first swap so it's all new to me. I appreciate the help.
![]() ![]() Join Date: May 2015
yep...that's right...but I may may offer some advise is to get a small finned inline cooler for the return line...itll help keep the fluid temps down
I run mine between the steering box and reservoir... heres what I'm using...https://www.summitracing.com/parts/rnb-918-319
mongocanfly, do you recommend installing a cooler only on the steering return? Or is there much point teeing both returns together and running both through the cooler?
1987 C6P V20 truck, 2010 LMG 5.3, AFM delete, 2010 Camaro exhaust manifolds, 1997 nv4500, 1991 np241c, hydroboost, 2005 14bff axle & driveshaft, drop-n-lock gooseneck, 4.10 gears, stock suspension, rims, and tires. Still a work in progress. Any questions or suggestions are welcome! |
mine came factory only coming off the steering box....im not sure how much fluid runs thru the return line from the hydro...I think one off the steering box is good enough
Mongo...aka Greg RIP Dad RIP Jesse 1981 C30 LQ9 NV4500..http://67-72chevytrucks.com/vboard/s...d.php?t=753598 Mongos AD- LS3 TR6060...http://67-72chevytrucks.com/vboard/s...34#post8522334 Columbus..the 1957 IH 4x4...http://67-72chevytrucks.com/vboard/s...63#post8082563 2023 Chevy Z71..daily driver Last edited by mongocanfly; 10-07-2019 at 03:12 AM. |
no cooler on the hydro return. it will cause problems.
88 military v30 crewcab shortbed 5.9 cummins, nv4500, 205 86 k30, 89 diesel burb, 76 gmc pathfinder 71 longbed 5.3 4l80 http://67-72chevytrucks.com/vboard/s...d.php?t=522535 |
Cooler is on return from steering box...not the hydroboost return
