12-09-2010, 01:19 PM | #1 |
Power Steering Pumps
I have a MII with power rack and pinion going into my project. I was just wondering what you guys are using as far as p/s pumps. Who is using an OEM pump and who's using aftermarket Borgeson/Saginaw pumps. I have a 401 Nailhead going in my project if thats any help.
12-09-2010, 03:03 PM | #2 |
Re: Power Steering Pumps
I didn't know there was such a thing as an aftermarket Saginaw pump. Wouldn't an OE Buick pump be easier to mount?
Ray
Live more responsibly. Eat lower on the food chain. Eat vegetarians. |
12-09-2010, 03:41 PM | #3 |
I'd think that a standard Saginaw pump with the factory Buick brackets would be the most practical and best all all around setup. You would need the correct reservoir for the engine and brackets but I think most of the pumps that have the nut on the shaft are the same. Usually you match the reservoir and pulleys to the engine. This pump doesn't show to go on a nailhead but as an example of what a pump that fits my 71 GMC also fits. http://www.oreillyauto.com/site/c/de...2869&ppt=C0031 If you click on compatibility you will see that the pump it's self fits several thousand models of vehicles depending on the control valve, reservoir and pulley you put on it.
12-09-2010, 03:56 PM | #4 |
They are same part I take it older GM PS pumps are universal. So I should run the gm pump with pressure valve to lower the pressure to acomidate for the Ford rack
12-09-2010, 04:07 PM | #5 |
That's what I would do and what I intend to do on my 48 in the next few months.
I'm a serious advocate of using parts like power steering pumps, alternators and distributors that are pretty much standard and use standard and easy to come by repair parts. The custom stuff is nice but if you really put miles on the truck and take it more than a few miles and a couple of hours away from home it's nice to know that you can get repair pieces at most well stocked parts houses. And yes we both need to run the correct control valve to get the pressure down right for the MII rack. |
