How does this work? Tell me everything!!
I found this Accel Fuel Management System and thought it was the coolest looking intake I could find. All I'm wondering is how does it work, does it use just any normal carb, is fuel injected, and what all do I need to buy if I bought this?
Are there any pics out there with this on there 350 as well? |
Re: How does this work? Tell me everything!!
Its for multi point fuel injection. You would have to add injectors and a throttle body.
And a controller. And an electric fuel pump. It does look tempting.
'70 GMC C1500 LWB Power disc brakes. WooHoo! Posi 6 Lug Dana 60 |
#4 | ||
Champagne Taste on Beer Budget
![]() Quote:
Then you can give it to me! ![]() Honestly it would cost a lot of money to get it working properly. But I can be done if researched on each component needed. Good luck.
Coming Soon: Project 1970 Country Truck |
Holy Cow!! $2,600?? just to do that set up?
To break that down it is VERY close estimate.
1. Electric Fuel pump 2. High Pressure Fuel line & Filter 3. EFI Controller 4. 8 High Pressure fuel injector 5. Throttle Body 6. Fuel Rail I am sure that I am missing a few parts but you get the idea if you pieced the system together the price is very close to that estimate of $2,600!!
![]() Join Date: Feb 2007
My limited efi knowledge has taught me that it's easier to use a complete system. A lot of time, money, and frustration can be spent on piecing a system together and getting it to run right. Don't forget your 12 volt system better be tip top as the controller get finicky without constant voltage, and a good fuel and plumbing system is a must.
Steve 1971 GMC Longbox. Full Roller Stroker 489 w/ FiTech EFI, Chris Straub Cam/NV4500/205/D60/14B w. Grizzly Locker and 4.11's. 2" Lift on 33's |
Go to the Smeding Performance website and take a look at their 383 EFI crate motor ... it uses an Accel system. And yes, it requires alot of components that would need to be source, including an EFI-capable fuel tank.
Barry
Barry L. Van Hook '69 Chevy Frankentruck |
If it is just the look of the intake you like it looks like a cross between the Edelbrock Air Gap and Edelbrock Victor Jr. You really should pick your intake based on your engine build though.
http://www.jegs.com/i/Edelbrock/350/7501/10002/-1 http://www.jegs.com/i/Edelbrock/350/2900/10002/-1
72 Cheyenne Super 1/2 LWB White/Dark Yellow 07 Avalanche 2LT 74 Sleek Craft Rebel Jet Boat W/Pontiac 400 Last edited by OhOneWS6; 12-14-2010 at 02:37 PM. |
Thanks for the help guys. I'm pretty sure I have convinced myself to just stick with the easy stuff till I learn more. I didn't quite realize you need all that. That's a lot of scratch I don't have.
It can be done cheaper. Mega Squirt makes controllers, buy used injectors, throttle body... But you need to know what your doing or be willing to do the research,troubleshooting...Big learning experience.
A few more parts to help the controller; map sensor, engine temp switch, O2 sensors, bungs on the exhaust for the O2 sensors and tpi (throttle position sensor) if your throttle body does not have one. A laptop to install the programs/maps to the controller. I used mega squirt on a 6 cyl and still, it took some time (maybe 8 hours) and various mapping to get it running right.
#14 | |
Now that is something I'm very interestesd in learning. At first you all where scaring me away, but now I'm really interested. |
