Old 03-10-2010, 10:50 AM   #1
GreenAcres
"I tawt I taw a puddy tat!"
GreenAcres's Avatar
GMC leaf spring lowering
Doh!...already committed to buy a '68 1/2T, SWB GMC.
How do you lower a leaf spring rear suspension? (I realize converting to coil spring gives more options...let's skip that part for now please)
How much drop is possible? Any photos, or links?
(note planned on a drop spindle front)
Thanks,
John
'67 C/20 LWB CST 283/SM420 FleetWood - project "HELL!"
'68 GMC 1500 SWB Fleetside 250/TOT SOLD
'70 C/10 454/TH400 LWB SOLD
GreenAcres is offline   Reply With Quote
Old 03-10-2010, 11:03 AM   #2
Orange
Licensed to Thrill!
Orange's Avatar
Re: GMC leaf spring lowering
There are really 2 common options.
First is the cheapest which is to flip the rear end...that is put the springs on the other side of the axle.
http://www.stylintrucks.com/parts.as...tfamilyid=3339
The other most common option (what I did) was the Early Classic lowering leaf's.
http://www.earlyclassic.com/catalog.aspx (Go to Leaf Springs and Rear Shackles).
Coupled with their drop shackles you can get 5.5" drop.
I have to get some better pics of mine, but here's one that shows it pretty good:
(full size is at slickorange.com - which is out of date...been busy lately.)
That's static with 3" CPP springs and the ECE rear drop leaf's @ 4".
DLB
1971 GMC.Lowered. Overdrive. Orange.
Krue's excellent FAQ Index.
Orange is offline   Reply With Quote
Old 03-10-2010, 11:38 AM   #3
GreenAcres
GreenAcres's Avatar
Thanks DLB,
Great links. (I obviously didn't have the patience to find the right parts on the ECE site).
Next question...can I expect the same results as if using 6" lowering coils? That is, no interfence with the frame? no need to notch?
And would like to see more examples (thanks again) to see what the option combinations are.
John
Old 03-10-2010, 11:47 AM   #4
butternut1972
butternut1972's Avatar
I used a bell tech flip kit on mine and a de-arched spring. It did require a c-notch. The ride is pretty good.
butternut1972 is offline   Reply With Quote
Old 03-10-2010, 12:05 PM   #5
dieselarmy13
Phone's ringin Dude.
dieselarmy13's Avatar
I used the flip kit and removed a couple of leafs. Pics in my build thread down below.
I pitty the fool with only two headlights!!
2003 SILVERADO SS--THE NEW GIRL
1972 GMC--THE OLD GIRL
dieselarmy13 is offline   Reply With Quote
Old 03-10-2010, 12:45 PM   #6
GreenAcres
GreenAcres's Avatar
Thanks Gentlemen...more great links!
Anyone else? "To notch?...or not to notch?"
Old 03-11-2010, 08:58 AM   #7
Jeffs70
Jeffs70's Avatar
Originally Posted by GreenAcres View Post
Thanks DLB,
John
I have non arched leafs and axle on top with a leaf removed and a C-notch on one of my trucks there is no way of getting away from a Notch I do not believe at how low you have specified you wish to go.
Even with rear Coil's at a 6" drop you will still need to notch the frame
Jeffs70 is offline   Reply With Quote
Old 03-11-2010, 09:19 AM   #8
GreenAcres
GreenAcres's Avatar
Originally Posted by Jeffs70 View Post
... I do not believe at how low you have specified you wish to go.
Jeffs70,
My thoughts for spec's are:
Drop Front with 2 1/2" spindles and 1" lowering springs.
Drop Rear is my question mark. Level would be ideal, but slightly higher (subjective...I know) is OK.
This is why these links to photos and others specs are FANTASTIC, and slow72, just the kind of info I was looking for.
Like I stated earlier, didn't want to go the route of discussing pros/cons of a coil swap.
Old 03-11-2010, 09:53 AM   #9
Orange
Licensed to Thrill!
Orange's Avatar
FWIW I didn't have to notch (axle didn't "relocate") and I can swap back to original just by changing out my springs. That's something to consider if you don't want to cut on your truck. Most guys though that commit to a suspension change don't mind that.
I just wanted the ability to go back if I ever wanted too...and if gassers are the new craze again in 2020, I'll be one step ahead.
DLB
Old 03-10-2010, 11:30 AM   #10
Ackattack
Ackattack's Avatar
I removed leafs from my 72 GMC (that's really cheap!). I did have wheel hop problems when I was at the track (broke a u-joint).
Ackattack is offline   Reply With Quote
Old 03-10-2010, 10:56 PM   #11
chevydog66
GM ONLY BABY!!!
chevydog66's Avatar
I did some drop shackles from styin concepts and then removed that top leaf. It dropped about 4". O ya, and try to search the Suspension section.
2 wrongs don't make a right, but 3 lefts do.
66 Chevelle Malibu 406ci, 573hp, 10.99@121mph
96 Chevy Silverado Z71
72 GMC 1500 Super Custom LS 6.0/4L65 on airride
http://www.cardomain.com/ride/707879...mc-c-k-pick-up
chevydog66 is offline   Reply With Quote
Old 03-11-2010, 03:21 AM   #12
dieselarmy13
You will need a notch
Old 03-11-2010, 05:19 AM   #13
slow72
slow72's Avatar
I used a flip kit from DJM. Dropped the rear almost 6 inches. Afterwards it was evident that a notch was required since my axle was less than an inch away from my frame. For now i have avoided notching by adding helper airbags on top of the leafs. I will be switching to a coil frame and full air ride setup this summer with a bolt in notch.
1972 GMC LWB, 250, 4sp
2010 GMC Sierra 6.6 CCSB
slow72 is offline   Reply With Quote
Old 03-11-2010, 08:26 AM   #14
CHEMPOWR
CHEMPOWR's Avatar
I have a flip kit with lowering shackles and it is notched. Check out my avatar and profile for pics. I can't figure out how to post pics to my reply yet.
I think you will need to notch the frame if you lower more than 4 inches I believe.
1969 GMC Wideside SWB 400ci/TH400/373/Disc Brakes/Leaf Springs
1992 Chevy C3500 Ext Cab Dually Silverado 454 TBI
2007 Chevy Corvette ZO6 427ci 505HP
CHEMPOWR is offline   Reply With Quote
