Old 05-18-2016, 08:52 PM   #1
kbill45@gmail.com
69 CST10 fuel pump to carb problem
69 with 350 and auto trans. The engine is 350 supposedly out of 75 Camaro.
600cfm(1406) Edelbrock carb and intake, new fuel pump.
Problem Cranks right up cold but takes the battery way down to crank when hot say 10 minutes later. Put a clear fuel filter on to check what was happening. When the engine is turned off gas keeps flowing in until filter is full. Clamped off the rubber line immediately after shut off and
release it after 10 minutes and it starts right up. Was doing this with the old pump also. Took the truck to a repair shop and it baffles them too.
Any ideas. I am about ready to install an electric with an on off switch like I used to run when I had mirror finish cylinders and double moly rings 40 years ago.
kbill45@gmail.com is offline   Reply With Quote
Old 05-18-2016, 09:46 PM   #2
GMCJOE
GMCJOE's Avatar
Re: 69 CST10 fuel pump to carb problem
From what I am gathering, you are having hot start issues. Does it take an extended crank for it to fire up?
I ran a 1406 on mine after I dropped my motor in. It would fire up cold no problem. But as soon as it was hot, and shut it down for 5 mins to 10 minutes, it would crank for a extend period of time before it would fire. From research across multiple forums, I have gathered that it's a heat transfer issue causing the fuel in the carb to boil. People have put a non metal 3/4" spacer in between the carb and intake and wrapped the fuel lines to correct the issue. I personally switched out to a Edelbrock 650, and never had the issue since. From all my research, it's a problem a lot of people have encountered with the 1406.
Joseph
Joe's 69 GMC
http://67-72chevytrucks.com/vboard/s...d.php?t=543253
1969 GMC SWB-350 SBC 700R4
2013 Ram 2500 CC Laramie Longhorn Edition-6.7 PPEI EFI Live CSP5 5” ProFlo Exhaust
GMCJOE is offline   Reply With Quote
Old 05-18-2016, 09:54 PM   #3
kbill45@gmail.com
Thanks for responding. If I turn it off and restart in 20 to 30 seconds it fires right up.
Old 05-18-2016, 10:01 PM   #4
geezer#99
geezer#99's Avatar
You need a heat insulator and a fuel regulator.
Eddy carbs don't like more than 5 psi.
Old 05-18-2016, 10:03 PM   #5
GMCJOE
GMCJOE's Avatar
Same thing for me. I could start it back up immediately with no issues. So, I believe you are experiencing the heat transfer issue. Good luck getting it sorted out. I choose to throw a new part at the truck, instead of trying to sort out the issue like others. But for me, the 1406 was free and temporary, I always had the plan to run a 1806. This issue just moved me a long a bit quicker.
Joseph
Joe's 69 GMC
Old 05-18-2016, 10:13 PM   #6
chainsawman
chainsawman's Avatar
I had exactly the same problem with the same carb. A wood spacer and a 3 psi regulator fixed it. Just like the guys on here said it would.
chainsawman is offline   Reply With Quote
Old 05-18-2016, 10:20 PM   #7
lilred2
lilred2's Avatar
I had this problem with the same carb on a 71 Bronco. What I noticed was after I shut it off the carb was still dumping gas in the engine causing it to flood and stink up the garage. I just replaced the carb when I put a 351 in it but I bet a regulator would have fixed it.
lilred2 is offline   Reply With Quote
Old 05-19-2016, 11:42 AM   #8
cdowns
cdowns's Avatar
lazymans rubber fuel lines cause fires
Old 05-31-2016, 03:52 PM   #9
68Gold/white
That clear plastic filter should only be used to diagnose a problem, also. Seen some dandy engine fires from them also...
68Gold/white is offline   Reply With Quote
Old 05-25-2016, 11:29 AM   #10
kbill45@gmail.com
Who sells the spacer>
Old 05-26-2016, 08:24 PM   #11
kbill45@gmail.com
bump
somebody. where did you find the wood spacer?
Old 05-23-2016, 12:16 PM   #12
kbill45@gmail.com
Installed Mr Gasket fuel pressure regulator - set at 3.5 and so far runs great and does not fill up the transparent filter. Will now change oil, switch to metal filter and steel lines.
Thanks for the input. Bill
Old 05-23-2016, 12:29 PM   #13
rmr_69c10
I have the same issues on my Carter AFB carbed 355. I have a spacer on order and am planning to get a regulator soon as well. Any pics or advice on how you mounted the regulator? Thanks.
rmr_69c10 is offline   Reply With Quote
Old 05-23-2016, 12:48 PM   #14
kbill45@gmail.com
I do not know how to post pics but will be glad to email or text.
kbill45@gmail.com
Old 05-23-2016, 12:53 PM   #15
70STOVEBOLT
70STOVEBOLT's Avatar
Here is how I mounted mine. Fabbed a bracket from a flat piece of 1/8" plate.
70 C/10 SWB 402/TH400/3.73 "The Needy Beast"
200,000 Mile Club
Disc Brake Club
Owner installed options:
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Power windows
Power Locks
Sniper EFI
2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear
70STOVEBOLT is offline   Reply With Quote
Old 05-26-2016, 08:44 PM   #16
rmr_69c10
You can see the available options on Edelbrock's website. Amazon has them and most major parts stores (AutoZone, Oreilly's, etc) can get them. I'm getting the 1/2" thick one to try, Edelbrock model 8723 since my Dad can get it at AutoZone for me (he's semi-retired and works there part time to stay busy).
Old 05-30-2016, 05:01 PM   #17
kbill45@gmail.com
went to Orileys and Autozone today. O'riley couldn't find it at all. Autozone found it but it was out of stock. Will try Edelbrock direct
Old 05-31-2016, 01:19 PM   #18
rmr_69c10
Sorry to hear you are having trouble sourcing one locally. Good luck!
What PSI did you settle on running? I'm looking at a Holley regulator so I can use the 2nd output right to a fuel pressure gauge and the options are 1-4PSI or 4.5 to 9PSI.
Old 05-31-2016, 01:44 PM   #19
kbill45@gmail.com
Bought a Mr Gasket 1to5psi regulator and set it to 3 1/2. It does not fill up the filter now and seem to start right up after sitting for 5 to 10 minutes. I waiting on a wooden spacer from Jegs. also cut up and old windshield sun screen and wrapped the fuel line. If all of this don't work it will be on Craig's list.
