67 dually and rear disc brake conv
I'm planning to convert my 67 C-20 to a dually with disc brakes. Has anyone else done it? Ideally I would use a late model one ton diff with disc brakes already on it. If not I have an idea on how to manufacture the disc brake brackets, has anyone else done that?
hooberjon@yahoo.com "Life's Been Good To Me So Far" 1941 Chevy PU (new project, right out of the field) 1948 P/U: 350/700r4, Nova Clip,Chevelle rear, air ride suspension, custom door handles, custom firewall, custom dash, buckets and console, visor 1967 C20: 427 Tall Deck, Turbo 400 with Gear Vendors aux tranny, 5th wheel, 3500 bucket seats and console. 1996 Geo Tracker 2x4 1996 Geo Tracker 4x4 |
Saving 1 truck at a time!
Re: 67 dually and rear disc brake conv
Sounds like a great idea...I love the dually flatbeds...just too many projects to start another one now!
'68 C20 Longhorn 50th Anniversary 400/TH400 '68 C20 Longhorn 50th Anniversary 468/TH400w/buckets '72 C20 Halfhorn (Longhorn w/o cab and front clip) '69 Flxible Cruiser (look up ugly in the dictionary) |
I know there is at least one vendor around here who makes disc brake kits expressly for the Eaton axle you should have, but generic 14 bolt brackets can be made to work. Even the generic weld on variety would work.
However, that brings up the problem of parking brakes. I haven't tried Cadillac calipers myself, but have heard they leave quite a bit to be desired on a heavy rig. Late model disc rearends have the parking brake shoes in the rotor hat, if you couldn't find the entire late model axle perhaps you could graft the brakes onto your existing axle.
1969 GMC K2500 ![]() 1996 Honda Accord 2007 Kawasaki KLR 650 |
I did it on my '70 C30 carhauler about eight years ago.
I used the stock CC duallie Eaton with duallie hubs, 4x4 F rotors AND backing plates, 4x4 calipers, and a 3.08"-thick (IIRC) spacer to move the rotor inboard from the hub enough for the caliper to clear the duallie wheel. The whole assembly is clamped together with grade8 5/8x6.5" bolts with anti-rotator tabs welded to the bolthead. I tried the Caddy parkbrake calipers, but the won't fit over the rotor(too thick). In front, I used the BIG rotors and calipers from a 10000lb-tow-capacity 1978 crewcab 2wd C30 and the hydroboost from the same-era truck. I tested a loaded and unloaded panic stop without a proportioning valve and consistently got the fronts to lock before the rears, so I left it unproportioned. The thing weighs 4100 lbs at each axle unloaded.
Just as if I knew what I was doin' |
I have a radical idea!
Wow Duallie! Nice looking car hauler. I have one similiar, but your's looks much nicer than mine. You should post some pics on the "Where are the 1 tons" thread here: http://67-72chevytrucks.com/vboard/s...d.php?t=126946
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435 ‘72 C-10 SWB , 350 4bbl, TH350 '69 C-10 SWB , 250 L6, 3 OTT '69 GMC C3500, dump truck, 351 V6, NP435 '84 M1009 CUCV Military Blazer 67 C-30 Turbodiesel build thread http://67-72chevytrucks.com/vboard/s...d.php?t=254096 My trucks http://s226.photobucket.com/albums/d...ediafilter=all Member of the 1-Ton Club! |
Well, thanks!!
Check my link out for some pics my brother snapped and made a site out of: turniptrucking.com
