Old 03-03-2013, 08:43 PM   #1
Yellow72C10
C10 or k10?
So I have a 1972 Chevy short stepper C10 or so I thought. It's 4wd, but it's badged as a C10? Shouldn't it be k10? Can anyone help me with this? Thanks!
Yellow72C10 is offline   Reply With Quote
Old 03-03-2013, 08:53 PM   #2
Ironhorse
Ironhorse's Avatar
Re: C10 or k10?
Fenders and badging can easily be changed. Bodies can be swapped, glove box doors can be changed. Does the cab VIN # match the frame stamped #. Cab VIN will have a "K" for 4wd or a "C" for a 2wd factory production. The frame stamped # should be on drivers side top frame rail near the steering gear box. May have to clean grease and crud off with wire brush to see it. Will be a partial number matching the vin #. Others with more knowledge can give you some more things to look for I'm sure.
1971 Chevy 1/2T 4x4 LWB 350 V-8
Was sm465-now 350TH/np205
Tilt, Tach, Towhooks
Original Truck AM/FM
Wellington, Ks
Ironhorse is offline   Reply With Quote
Old 03-03-2013, 08:57 PM   #3
too much stuff
Roadtrip!
too much stuff's Avatar
Re: C10 or k10?
C-10 is the correct badge. The only 67-72s that got a "K" badge was the blazer on 2 or 4wd. Your VIN would have a CK at the beginning if it is a 4x4.
67 gmc custom lwb dakota truck. Sold...And bought back
69 swb 4x4 project (in progress)
70 c-10 lwb texas truck
70 4x4/BB/bkts/posi/tach(retired)
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
71 cheyenne 4x4/tach/posi/ plow rig
71 Cheyenne20 BB, buckets, tach, tilt, 4 speed
72 jimmy CST wyoming rig
72 jimmy Colorado rig
72 lifted texas 4x4 3/4 ton burb
65 fury conv. 383/auto
65 chrysler 300 "L" 413 auto
too much stuff is offline   Reply With Quote
Old 03-03-2013, 09:36 PM   #4
Yellow72C10
Re: C10 or k10?
Thanks fellas!! Makes sense now. By the way, do y'all know what weight oil for the differential? It's a 12 bolt
Old 03-03-2013, 10:23 PM   #5
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Re: C10 or k10?
75w90
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Old 03-03-2013, 10:54 PM   #6
Yellow72C10
Re: C10 or k10?
What does that mean! And thanks!!
