07-27-2012, 09:20 PM | #1 |
Gauge cluster differences
Ok so I have 2 different trucks my dd is an 86 custom deluxe 10 4x4 with a 4spd the other is a 79 k20 silverado auto trans but it has a factory tach dash the 86 is what I'm going to fix up nice the k20 is going to be my hauler and snow plow how hard wiring wise would it be to put the 79 tach dash in my 86
Krazy Texan My Trucks are made with Wrenches not Chop Sticks 1967 GMC 3/4 ton "Johnny Cash" 1990 v1500 suburban 1967 Ford f100 Swb 4x4 "green bean" GOD BLESS JESUS, JOHN WAYNE, AND THE ALAMO |
07-28-2012, 12:58 AM | #2 |
Re: Gauge cluster differences
not sure on trucks. but on my race cars just a green wire to the distributor,one to Ing, light, grown!!
68 chevy swd fleetside LT1/700R/under construction 72 chevy swb fleetside sb400/400 trans 73 chevy swb fleetside bb454/400 trans 2inch drop spindles 4bar c notch and airbaged/Under construction 07 GMC HD Durmax Marshall Weaver |
07-28-2012, 05:26 PM | #3 |
I'm kind of in the same boat right now, I have an 82 C10 I put a 87 wiring harness in the dash but still have the 82 gauge cluster, I can't get my gauges to work, I'm assuming the locationg of the contacts on the printed circuit is different I have considered tying to hard wire all the gauges and eliminate the printed circuit.
82 GMC SW 2WD, 454 TH400, shaved mirrors, drip rails, tailgate, emblems. Midnight Blue, black and grey interior. Father son project in progresss. |
07-28-2012, 08:24 PM | #4 |
I believe 78 to 87 all have the same pin-out on the cluster plug (except for trucks with the idiot light clusters). But it would be a good idea to double check with 79 & 86 wiring diagrams just to be sure.
It was the earlier years that had some differences in the cluster wiring with ammeters (73-75) instead of voltmeters (76-up) & mechanical oil gauges (73-77) instead of electric oil gauges (78-up). As for the factory tach wiring, they use a separate 3-wire harness that plugs directly onto the back of the tach. The other ends of the wires go to power (fusebox), ground, and to the "TACH" terminal on the HEI distributor. Just transfer that harness over from the donor truck. The printed circuit on the back of the cluster will automatically take care of the fuel gauge being re-located to the lower/left corner on the tach cluster. And the auto trans shift indicator just attaches to the cluster with a couple of screws so that's easy to swap. |
07-28-2012, 09:00 PM | #5 |
A while back I upgraded the dash in my friend's 83 1-ton (SRW) from lights to gages using the instrument cluster from a 76 or 77 Suburban. Here's the link to my post about that, http://67-72chevytrucks.com/vboard/s...d.php?t=525870, there is some very helpful info that was posted there.
My Projects: 1960 GMC 1/2ton with 305 V6 (daily driver) 1963 Chevy 1/2ton 2wd...converting to 4x4 1967 Suburban 1/2ton 2wd My Girlfriends Projects 1985 Chevy Suburban 3/4ton 4x4 with 6.2L diesel, 4" lift, converted to TH-400, Warn Premium manual hubs, & Wildcat 315/75/R16 tires. (daily driver) 1978 Camaro Type LT with a Marine 350 & vortec heads, Rochester Carb, & roller cam 1978 Camaro Z28 |
07-31-2012, 11:04 AM | #6 |
78K & 79C Jimmys
i did it to my 78
the gas gauge wire in the plug has to move and add a ground for gas i put the tach power to the pink/black custer power
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
07-31-2012, 12:36 PM | #7 |
I converted my 89' cluster to a 91' electronic cluster and had to re-pin the connector. Maybe you can see if the 87' and 89' are similar
Hope this helps a little..... |
07-31-2012, 02:22 PM | #8 |
78K & 79C Jimmys
and one for the 78s may help
