![]() Join Date: May 2010
72 PRNDL gear shift issue
My 72 truck I have to move it down to almost L1 L2 for it to fully engage to Drive.. So if you were to move it up to D the handle falls down... Is this a clip issue, or something lower on the transmission?
Also is there away I can fix where I dont have to jam it up into park? I have to use some force to get it up into park. |
Sounds like ya need to adjust yer shift linkage? Block wheels, set park brake. Check linkage where shift linkage connects to column for worn bushing or link arm. Repair as needed. Loosen nut on linkage at base of steer column where shift linkage connects to column. Put trans into park or neutral, no matter what it says at indicator. Have someone hold shifter into whatever gear your trans is in, and tighten adj. nut. May have to repeat as necessary until ya get it right. Hope this helps?
![]() ![]() ![]() LIFE AIN'T EASY WHEN YER FAT AND GREASY! GMC= Got More Class! ![]() ![]() Last edited by OhioDan; 05-06-2010 at 07:14 AM. |
Re: 72 PRNDL gear shift issue
I kind of know what your taking about. Today I looked at it. Now at the top where there is a nut to the linkage it appears that there is like a fan that when you shift, the lever goes down. Those "fan blades" however you want to call them look worn.
Could this be the problem? |
ttt
pics????
![]() ![]() ![]() LIFE AIN'T EASY WHEN YER FAT AND GREASY! GMC= Got More Class! ![]() ![]() |
Project Junkie! Fishing Poor!!
![]() Join Date: Dec 1999
I would have someone shift the truck (with it turned off of coarse) and watch the adjuster to see if it is slipping on the shift rod. If so, tighten the 9/16 bolt once you adjust it. If not the it sounds like you may have lost the rubber grommet and steel sleeve out of the shift arm at the bottom of the column. You may also have worn linkage issues. If the first thing doesn't solve your problem, then you will need to take it apart to inspect for ware. WES
On-line catolog Classic Heartbeat Pickup Parts WEHEPP@comcast.net Call us Toll Free (888) 338-2502 Like Us on Facebook No appointment necessary. 72 BB Chevy Custom Deluxe / Custom Camper 67 I-6 (Soon to be 5.7 LS1) Panel 68 BB Chevy Short Bed 72 6.0 LQ9 Short Bed Chevy 4X4 Olympia's fastest growing truck parts supplier. Olympia's home for Wayward Chevys |
GO to this to adjust and tighten up, it might help on post #8
http://67-72chevytrucks.com/vboard/s...18#post3959618
Kerry My build thread. http://67-72chevytrucks.com/vboard/s....php?p=3657823 1971 Chev SWB with 68 nose, 6.2 diesel th350, and 3.73 rear gears 1988 Chev Extendacab 2010 Honda VT1300CS Sabre 2005 Buick Rendezvous wife's ride Last edited by chevy88; 05-11-2010 at 08:03 AM. |
Well I managed to do that now the holes where the screws were arent lining up... Its like the holes somehow have drifted up a bit, and I cant find anything to move them back down. I tried sticking something in the hole to push it downward to line up with the bracket and screw, however Im having no such luck.
Has anyone ever experienced this before? |
Do not stick anything in holes/be careful you could ruin threads. Try turning outside with pipe wrench and hold inner shaft crescent/visegrip to take out play. Lets us know how it turns out.
Kerry My build thread. http://67-72chevytrucks.com/vboard/s....php?p=3657823 1971 Chev SWB with 68 nose, 6.2 diesel th350, and 3.73 rear gears 1988 Chev Extendacab 2010 Honda VT1300CS Sabre 2005 Buick Rendezvous wife's ride |
