English Chevy Owner
My progres pics, finally!
Stated the bodywork on my truck to get it through its annual inspection as the rocker rust would have failed it. Front end half stripped down for access. I've also removed the remains of the back half of the exhausts and have dropped them in to a local exhaust place to have two new ones made up. Should be ready today with a bit of luck.
Phil '67 C10 long fleet. 350/TH350, 4 bbl Carter, K&N, Dual exhaust, loads of stuff coming soon 2001 S10 Blazer Daily Driver, bone stock 4 door 4x4 with manual transmission |
![]() Join Date: Feb 2004
Re: My progres pics, finally!
Good luck with the rust removal.....
"Remember, They can Kill You, but they can't eat You, That's against the law!!!!!!!!!" |
![]() Join Date: Feb 2000
Never heard of a rusty rocker causing an inspection problem - that is interesting. How much rust is too much to pass your inspection?
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 |
English Chevy Owner
If theres more than surface rust (i.e. it holes when they hit it with their little plastic inspection hammer or it's already holed) within 15cm of what is considered to be a structural member such as a cab mount it'll fail. This rule is really designed around modern monocoque vehicles and doesn't really take into account older vehicles with a seperate frame, so it means regardless of the fact this rust doesn't really effect the structural integrity of the vehicle it still fails. the government over here has been tightening up and tightening up the rules with the aim of taking older vehicles off the road. Fortunately anything made pre 1972 is only tested for visible smoke rather than emissions. In the 22 years I've been driving its changed a lot, in the past I've had cars pass with exhausts patched with coke cans and two pipe clips, gaping holes in the fenders, even patches pop riveted on over holes.
Phil '67 C10 long fleet. 350/TH350, 4 bbl Carter, K&N, Dual exhaust, loads of stuff coming soon 2001 S10 Blazer Daily Driver, bone stock 4 door 4x4 with manual transmission Last edited by Lippyp; 06-07-2006 at 10:46 AM. |
Interesting. My truck would've been in the junk yard a long time ago then.
-Greg My Chevy trucks, past and present: 1962 C10 SB Fleetside 1964 C10 LB Fleetside BBW 1966 C10 SB Fleetside 1966 C10 SB Fleetside BBW 1968 C10 SB Fleetside 1971 C10 LB Fleetside 1971 C10 SB Fleetside 1972 C10 SB Fleetside Cheyenne 1972 C10 SB Fleetside Cheyenne Super 1972 C10 LB Fleetside Cheyenne Super 1974 C20 Cheyenne 1979 K5 Blazer Cheyenne 1982 K10 SB Fleetside Custom Deluxe 1982 K10 SB Fleetside Scottsdale 1986 C10 SB Fleetside Silverado 2008 Silverado 1500 4x4 |
![]() ![]() Join Date: Jul 2002
Sounds like Pennsylvania. Japan was real rough on inspections too. Good luck with the clean up of the truck. I think it even looks sharp half stripped!
English Chevy Owner
Yeah it's got a bit silly really! Just been to pick up my new exhaust bits. Two matching 2 1/2" pipes to go from the mufflers to just in front to the rear wheels, I've just got to check them for length and take them back to have the ends stretched and the 3" stainless tips welded on. These things are really heavy gauge steel so should outlast the rest of the exhaust which is a little rusty. the idea is when the front bit dies I'll maybe go to headers and a decent set of louder mufflers.
Up here we are starting to have on-the-spot inspections, and they will fail you if any rust holes are present. Guy I know has a pretty nice 71 GMC and he has a small hole in a cab corner. Now he has to fix it or the truck is illegal to drive. Lippy are you planning to keep the yellow color on your truck?
"You can take the man out of PA, but you can't take PA out of the man" Last edited by HeavyD; 06-09-2006 at 01:23 PM. |
#9 | |
LAIDOUT
It doesn't happen alot, but just latrely they have had these get-em-off-the-road blitzes. Hope they are done for awhile.
"You can take the man out of PA, but you can't take PA out of the man" |
English Chevy Owner
Yep, yellow is staying for the moment as I can't afford a full repaint. We also have on the spot inspections, both forr vehicle condition and also now for emissions.
Back in the sticks
I like the yellow, and I am surprised the rocker backing plate is in that good a shape! Looks like other than some surface rust, your floors and rockers weren't in that bad a shape at all. Especially for a truck that was shipped over there! Usually the trip causes lots of rust. Keep us updated on your progress. Looking good! Jeff.
1971 Cheyenne C-10 w/700R4 and Tuned Port Injection 1969 K5 Blazer w/Tuned Port 2010 2SS/RS Flaming Orange Camaro 2011 K1500 Suburban 2014 K1500 Pickup 2008 Nissan Altima? The wifes' hoopty |
English Chevy Owner
Got the rest of the sill off today and found that the bottom of the door pillar is rusted through which is a bummer as I don't have the repair panel for this bit. They do make them though so I guess I need to order a pair as like as not the other side will be goosed. $19.95 each and I'll have to spring for air freight as surface will take too long. What is the best way to make sure that this all lines up properly, any tips appreciated. Do I do the kick panel patch first and then the door pillar and then the inner rocker?
I started to dress down the old spot welds on the rear of the sill and test fitted the sill just for a giggle, not a bad fit but will need a bit of work for a good fit.. I also took my new exhausts and test fitted them so now they're all marked up to go back and have the tips welded in and the box end needs to be stretched so it fits over the box outlet. ![]() ![]() ![]() ![]() ![]() ![]()
English Chevy Owner
Thanks, the floors gonna get a going over with a wire bursh in the angle grinder followed once the repairs are done by a coat of POR15 before the new carpets go in.
