10-30-2008, 11:15 PM | #1 |
"the other guy"
1st timer in need of some help?
will my stock 5 lug axles fit in a stock 6 lug rear end? i just bought a 71 swb chevy frankinstein. thanks
10-31-2008, 06:31 AM | #2 |
Re: 1st timer in need of some help?
I think the axles are diferent lengths so, my vote would be no. I have a 5 lug rear and a 6 lug rear out at my shop I will take a tape and see. Jim
10-31-2008, 09:23 AM | #3 |
"the other guy"
i would really appreciate that.-art
10-31-2008, 09:26 AM | #4 |
it depends on the year of the 6lug//i think 69-70 will swap into 71-72// 67-68 wont
10-31-2008, 10:08 AM | #5 |
It's a catastrophic success.
10-31-2008, 03:06 PM | #6 |
I've done this one before myself - as said above, 69-70 are the same length as 71-72, but 67-68 are different.
I'd also vote to just swap the whole rearend...it's not bad at all to do, especially if you have some air tools.
72' LWB Cheyenne 73' Camaro Z28/RS 70' Chevelle RagTop 00=ss=00 |
10-31-2008, 04:47 PM | #7 |
69-72 are the same width, I just checked. This thread caught my eye since I planned on swapping the 3.73 ratio out of the 69 in place of the factory 3.08 rear.
10-31-2008, 05:00 PM | #8 | |
its all about the +6 inches
Also, dod you just slide them in, and put the wider drum on there? If so, you are riding a long axle that is sticking out of the housing too far and a non hardened surface on the bearings. it ain't fun when a wheel falls off due to a broken axle... esp the rear. |
10-31-2008, 05:29 PM | #9 |
I didn't feel like crawling under the 70 to measure but, the 68 is 55.25 from hub to huband the 71 is 57.25 hub to hub. That doesn't help you much and if you don't get an answer over the weekend, I'll measure the 70 on monday. Jim
10-31-2008, 04:56 PM | #10 |
I am a Referee of life.
Andy,you stay out of LHM's desk!!!!
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
10-31-2008, 05:29 PM | #11 |
I have a 69 GMC as well as a 71 and 72 chevy, I measured center to center on the tires. The wheels all have the same offset so its a true comparison.
10-31-2008, 05:47 PM | #12 |
My 69 is around 57" flange to flange and the 71 is around 58". It's possible that the 69s rear came out of a newer truck but I'm really not sure.
11-01-2008, 09:25 PM | #13 |
Either it didn't go as perfect as you think, or it wasn't the original rear end.
As measured from backing plate to backing plate, early 70 and older was 56 inches, late 70 and up is 57 1/2 inches. |
11-01-2008, 11:11 PM | #14 |
Too Dumb To Know Better
I agree with LHM. Having purchased a 67 with 5 lug axles and seeing the drum on only half of the shoe, I had to swap the whole thing out. But I just put 5 lug axles in my 70 Jimmy with no issues. It was a later build and had the wider rear end.
11-01-2008, 11:21 PM | #15 |
and if the drums off a 67 - 87 are used, they cover the whole shoe... but the axle shaft is still too far out of the housing.
