05-06-2009, 08:59 PM | #1 |
Love Posi
Hi guys,
Does anyone know what kind of unit this is? I used to have it my Chevelle wagon. I put it in the 10 bolt rear with 3.08 gears but wasn't original to the car. A freebie that worked! I want to donate it to my friend's '67 C-10 project now that wagon is gone, but don't want to give him a piece of junk. You know, keep the positive Karma flowing.If it needs to be, can it be rebuilt, are parts still available? Would it be better to just get an aftermarket posi? Thanks
Free beer is good beer. |
05-06-2009, 09:49 PM | #2 |
resident oilfield trash
Re: Love Posi
Yeah dont give your friend that piece of junk. Send it to Jerod Bristo 5204 90th Lubbock TX 79424 instead
1967 SWB C10 396/400 factory air factory tach (sadly had to send to a new home) 1986 Honda 70 Fourtrax 1991 Chevrolet K5 blazer 2wd 1982 Mastercraft Pro Star 190 Stars and Stripes 2002 Chevrolet Tahoe 2011 Nissan Armada |
05-07-2009, 12:35 AM | #3 |
Re: Love Posi
If that posi was in a chevelle than it won't fit in a truck. Chevelles had 4 types of diffs
64-72 had 8.2 10 bolts in 350 2bbl and smaller engines 64-72 had 8.875 12 bolts in 350 4bbl and bigger engines 73-77 all had 8.5 10 bolts 78-87 had 7.5 10 bolts Trucks use 12 bolts from around 63 up until 81. In 82 trucks switched to the 8.5 10 bolt (same internals as the 73-77 chevelle). Also the car and truck 12 bolts are not the same. |
05-07-2009, 01:06 AM | #4 |
Re: Love Posi
car and truck 12 bolts are not the same. What are the differances? My diff is open and would like to get a posi for it, so what should I be looking for?
I was hooked on these trucks since 1982 when I drove my budys fathers 1968 Custum GMC 396 automatic dana 60 rear with a power lock diff what a ride more fun then we will we can ever tell!! Last edited by Willys47; 05-07-2009 at 01:06 AM. |
05-07-2009, 01:34 AM | #5 |
Re: Love Posi
I believe that the width of the carrier is different and the pinion has a smaller diameter on the truck 12 bolt. When shopping for a posi remember that around 73 gm trucks switched to the gov-loc type(the explosive one) of limited slip. 72 and older used the eaton clutch style(the good one) limited slip.
05-07-2009, 02:54 AM | #6 |
Re: Love Posi
while we are on the subject of posi's.
Ihave a posi in my truck and when I make a slow turn like in a drive tru or a slow left turn, It pops. Loud. What is the deal my dad says its normal. I hate it. whats the deal? |
05-07-2009, 10:10 AM | #7 |
Re: Love Posi
that is normal, but when was the last time you changed the fluid? my truck did the same thing, but once i changed the fluid, most of the popping and noise went away.
Mike 2001 Dakota R/T - Silver CC - 1 of 1671 •360 w/46RE •392 limited slip 1972 Chevy Suburban - Turquoise/Black 1969 Chevy C/10 - Blue LWB •350 w/ 700R4 •3.73 posi •PS PB A/C - SOLD Using your turn signal is not "giving information to the enemy" 67-72 FAQ |
05-07-2009, 03:16 AM | #8 |
Re: Love Posi
Its normal. They all do it.
05-07-2009, 10:11 AM | #9 |
Re: Love Posi
Mine pops, I keep thinking something is broken and here goes another million dollars to fix it..... the rear didn't pop when it was in my 72 but after switching it to the 68 with a new axel and 20 inch rims and tires it just doesn't seem right...... but everyone say's it's normal, so I guess it's normal.
05-07-2009, 12:05 PM | #10 |
Re: Love Posi
Its not normal!! It shouldnt pop!!! What you need to do is change the fluid unless its been recently changed and add a bottle of Posi fluid. It goes in with your gear oil and prevents the popping and makes it work correctly. I dont remember the exact name for it but its at every major parts store.
A computer once beat me at chess, but it was no match for me at kick boxing. Duct tape is like the force. It has a light side, a dark side, and it holds the world together. Last edited by monte0185; 05-07-2009 at 12:05 PM. |
05-07-2009, 02:08 PM | #11 | |
Re: Love Posi
'69 Chevy C/10-under reconstruction -- '68 C20 Camper 50th Anniversary-runs, but sorely needs a resto --
'07 Cobalt SS/SC-very fun DD -- '93 Chevy K2500-LQ4/4L80E swap -- '84 Trans Am-awaiting (LS) drivetrain -- '00 Trans Am-road tripper -- '06 Z06-577 WHP beast |
05-07-2009, 04:27 PM | #12 | |
Re: Love Posi
The rear I had the posi in was an 8.2, 10 bolt. I yhink it's a 2 serries carrier. Does anyone have any other info about this old thing?
05-07-2009, 12:28 PM | #13 |
Under Construction
Re: Love Posi
It's a limited slip/positraction additive oil. It smells aweful..... and no it should not pop when you turn. most likely your oil (80w90)needs to be changed, always add the additive when changing the oil. If its popping the friction plates are not releasing as they should when you corner. I bought my last bottle from NAPA....
Heath subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php http://67-72chevytrucks.com/vboard/s...d.php?t=157669 FAQ how to's 1956 Chevy Apache 1967 C10 SWB FleetSide (under construction) 1969 K10 SWB FleetSide (Future Build) 1972 C10 SWB Stepside (Future Build) 56 chevy truck : http://www.cardomain.com/ride/2955823/1 67 truck build: http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1 69 k10: http://67-72chevytrucks.com/vboard/s...d.php?t=389470 Last edited by my67chevytruck; 05-07-2009 at 12:33 PM. |
05-07-2009, 01:51 PM | #14 | |
Re: Love Posi
A computer once beat me at chess, but it was no match for me at kick boxing. Duct tape is like the force. It has a light side, a dark side, and it holds the world together. |
