03-12-2003, 06:57 PM | #1 |
97' Tahoe 2dr/2wd
Progress pics, 70 swb
finally I will post some progress pics.
I finally got the correct spindles for 1.25" thick rotors. just put the spindles,springs, upper and lower control arms, rotors, calipers, pads, and front shocks on. finally its back on all 4 wheels, its alot eiasier than rolling it with the floor jack holding the front of the truck. i got all of my steering parts, paint dring on them right now. anyway heres some pics, in the garage. |
03-12-2003, 06:59 PM | #2 |
97' Tahoe 2dr/2wd
another
03-12-2003, 07:01 PM | #3 |
97' Tahoe 2dr/2wd
last one
03-12-2003, 07:26 PM | #4 |
Looks good Tommie, keep us posted with the progress.
71 C-10 SWB 1969 C-30 Custom Camper Motorhome Restoration in progress. 2020 Chevy 2500 Crew 4x4 LTZ Diesel 2024 Chevy Tahoe Z71 4X4 2015 Diamond C 22' HD car hauler Bowie, Texas 76230 |
03-12-2003, 07:29 PM | #5 |
KEEP ON TRUCKING
nice keep up the good work
72 cheyenne 2wd lwb 71 k20 sons bassett va |
03-12-2003, 08:00 PM | #6 |
Good work.
03-12-2003, 08:16 PM | #7 |
turnin wrenches
looks good man!!
"three can keep a secret if two are dead" -unknown hell's angel- D.M.C. -FF- 68 SWB full frame off (project ol skool) 2000 s-10 formally bagged but now my daily driver... |
03-12-2003, 09:39 PM | #8 |
Looking nice, what type of paint did you use on the frame?
03-12-2003, 10:01 PM | #9 |
97' Tahoe 2dr/2wd
thanks for the compiliments,
as far as paint goes, I ground down all the surface rust, applied about 2-3 coats of rust oleum rusty metal primer, then used rustoleum satin black (7777) I used this paint on my 82 gmc when i did the suspension and dropped it, and it worked good, and it is relativly inexpensive also. i get it at Home Dpeot, they have it in rattle cans or by the quart. tommie |
03-12-2003, 10:47 PM | #10 |
tommie looks like your doing it right, Love to see it finished, how do you walk around your truck, your garage looks like mine.
03-13-2003, 12:31 AM | #11 |
97' Tahoe 2dr/2wd
your right,
no room to walk around truck in garage, step 1 is to pull truck out of garage into driveway for anything. thats why i am so glad to actually have wheels on the front of it again, it was a lot harder rolling it out with it on the floor jack. rolling on tires is much easier. all of my steering linkage is dring outside right now. will be nice to have all the tie rods, center link, and idler arm back on. it feels good to make progress. tommie |
03-13-2003, 01:19 AM | #12 |
Progress pics are my favorites. The front looks great!
03-13-2003, 11:55 AM | #13 |
looks good did the tierod adapters go together alright.
03-13-2003, 01:31 PM | #14 |
97' Tahoe 2dr/2wd
the tie rod adapters seem to work ok, have not fully installed them yet, test fit one side, took back apart to paint tie rods and idler arm.
will know for sure this weekend. the 70' outer is used as an inner, because it has reverse threads, it is what makes the sleve work. tommie |
03-13-2003, 02:45 PM | #15 |
yep it also makes it so that you can use the stock 70 centerlink
03-15-2003, 12:51 PM | #16 |
PROJECT 7DEUCE
Thats going to be a sweeet truck when ur done !!!!!!
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
03-15-2003, 01:04 PM | #17 |
Its Magically Delicious
agreed looks like its going to be a great truck
71 C10 LWB 350sbc -TH350 12 bolt 3.42 Posi Of all my favorite things to do, The utmost is to have a brew. My love grows for my foamy friend, with each thirst-quenching elbow bend. Beer so frosty, smooth, and cold it's paradise pure liquid gold. Yes beer means many things to me that's all for now cus I gotta pee. |
03-15-2003, 02:26 PM | #18 |
Looks very good. I used the same paint on my frame.
68 short fleet with 71 front clip 2wd jaguar blue 99 chevy ext cab shrtbed z71 loaded 99 chevy swb fleetside(daily driver) Sparks, Nevada |
03-15-2003, 03:13 PM | #19 |
Looking good,keep the progress pics coming....
