06-25-2004, 07:11 PM | #1 |
Will a set of 2003 hd wheels fit my K20??
I have a set of 2003 hd wheels, just wondering if they would fit on my K20. I think it has a donor front end out of a 73ish truck with 1/4 turn hubs.
Thanks for the help David
1969 K10 Custom 10 1997 Z71 2006 Volkswagen Jetta TDI 2006 King Ranch 1980 Wife |
06-25-2004, 07:34 PM | #2 |
Project Junkie! Fishing Poor!!
They fit the 2X4s so there isn't any reason that they won't fit the 4X4s. You will need to buy the conversion lug nuts though if you are talking about the aluminum ones. WES www.ClassciHeartbeat.com
On-line catolog Classic Heartbeat Pickup Parts WEHEPP@comcast.net Call us Toll Free (888) 338-2502 Like Us on Facebook No appointment necessary. 72 BB Chevy Custom Deluxe / Custom Camper 67 I-6 (Soon to be 5.7 LS1) Panel 68 BB Chevy Short Bed 72 6.0 LQ9 Short Bed Chevy 4X4 Olympia's fastest growing truck parts supplier. Olympia's home for Wayward Chevys |
06-25-2004, 07:41 PM | #3 |
I tried to put wheels off a '95 gmc suburban on my 67 gmc p/u...95 a 4wd and the 67 a 2wd...and the 6 lugs looked they would line up okay, but the actual center hole the hub or whatever goes through wasn't big enough. It only liked a hair, but I couldn't get it to work and was afraid to start grinding material out to fix it. If you have to buy wheels for this, make sure to test fit them to ensure they work b4 you're out a bunch of money and still no luck. Yours may work--everything on my junker seems messed up and out of line a little. Good luck.
06-25-2004, 07:47 PM | #4 |
The 1/2 ton wheels have a smaller I.D. for the center hole, but the 3/4 tons do not. The 1/2ton wheels will not work without spacers either, because the back spacing is not right. The rear might, but the fronts definetly will not. WES www.ClassicHeartbeat.com
06-25-2004, 08:29 PM | #5 |
wes
Wes;
Doi you still have pics of the truck you had setup that way and what it took to get center caps mounted up and looking right? If I remember therer was a trick or 2 to get center caps right. What does a set of wheels like that cost on the used market?
Bob |
06-25-2004, 08:43 PM | #6 |
Thanks guys
now that you mention it, i do remember that blue truck that Wes posted, they looked so good that they looked like they were made to fit a 72. I was worried that the middle of the wheel would be too small, or that the back spacing would be all jacked up. I already have a set, but i think i see them listed on ebay for 400-650/set without tires. thanks again guys David
06-25-2004, 08:55 PM | #7 |
I do not have those pictures any more. Sorry Bob. You may be able to find them in the archives. What you need to do is to use the standard 3/4 ton caps for the front and the Duelly caps for the rear. You also need to get the correct outside threaded lug nuts for your aplication. WES www.ClassicHeartbeat.com
06-27-2004, 08:33 AM | #8 |
I know the center holes on the steel`88-00 8-lug wheels are too small to fit over the original`72 K20 front hubs.
72CheyenneSuperK20CustomCamper350/TH350,A/C 72SierreGrandeK2500350/TH350,A/C 72CustomDeluxeK20CustomCamperSB400/4SPD.A/C 72CustomC10SWB,TH400,project |
