05-16-2013, 09:09 PM | #1 |
Roto Reuter thats the name...
What's wrong with this power steering hose routing? (besides it hits my alternator)
I'm trying to replace the pressure power steering hose on my '70 K10, but it hits the bottom of the alternator. What's wrong with the routing? I'm trying to keep this truck original. I bought the PS hose from LMC. Maybe it wasn't bent right. If anyone has pictures that show the routing I would appreciate it.
~ Dan My 70 K10 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=782232 My 71 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=651394 1970 SWB Fleet K10 4X4, 5.3L LM7, 4L60E, Dakota Digital RTX, Vintage Air, Ididit tilt 1971 SWB Fleet C10 - Original SWB Arizona truck, new custom restoration project "Kick out your motor and drive while you're still alive - kick it out!" - Heart 1977 |
05-16-2013, 09:27 PM | #2 |
Re: What's wrong with this power steering hose routing? (besides it hits my alternato
I think you need to swap it end for end.
05-16-2013, 10:12 PM | #3 |
The hard line on mine has more bends in it than that and keeps it lower and behind the belts.
Shawn 1970 Chevy C-10 SWB, 350, TKO 600 5 speed My build http://67-72chevytrucks.com/vboard/s...d.php?t=559881 |
05-16-2013, 10:31 PM | #4 |
I don't know... Unless LMC gave me the wrong hose. There is only one part number for my '70 K10. It's p/n 32-1974 which covers 68-72 V8 4WD.
05-16-2013, 11:15 PM | #5 |
Don't know about 4x4's, I have a C-10. But my line stays lower and closer to the frame. If I were you I'd borrow a tubing bender and make it fit.
05-17-2013, 07:16 AM | #6 |
thats terrible (another horror story from lmc) its definitly not bent correctly
I would send a pic over too lmc and make a call too them and see what they have too say before trying too rebend it once you do that your screwed
81 camaro 355 4/spd 342 posi my first love. 67 swb step 454/4spd ott 373 posi 4/7 drop. 2000 s10 zr2 little blue truck that never gets stuck. '74 heald super bronc vt8. tecumseh powered moon rover. |
05-17-2013, 08:33 AM | #7 |
Me again, when i did a hose replacement (about 5 years ago) your hose looks like mine did before i put a 90 degree bend. The area that runs horizontal on top of the frame i put a 90 degree bend back. What that accomplished was 2 fold. It used up the extra length and lowered the loop down, and if i remember correctly it helped with getting the line to lay nicely under the the inner fender. Hey, what gear box are you using? Stock with maybe 5 turns lock to lock? If so find a newer truck (i believe 77 and newer and get a 3 1/2 turn lock to lock with VARIABLE RATIO OPTION. Look in the glove box for option labeling. I went to auto schooling in late 70's and this is my favorite box. BEST OF BOTH WORLDS, and never talked about, (atleast i haven't seen it yet). This box gives you a casual slower (normal) reacting center feel, but when you turn past 1/4 turn right and left from center it's reaction rate speeds up (quicker). The gm engineers came up with this (if i remember correctly) was when the corvettes went at a high speed the steering was too twitchy and sensitive. So again, i feel that a room full of gm engineers is pretty hard to beat. Now, 2 box styles, 2wheel drive and 4 wheel drive with a pinch bolt pitman arm, and 2 locations (inside frame and outside frame mounting). The only hassle that i know of is pressure hose issues. Newer box's use o ring sealing where your older box is flare. I you get a newer box from the junk yard get the hoses (both of them) and the screw in fitting in the back of the pump, or just get the pump. Now, in 1996 gm went to an easy steer (less road feel-more assist) and you can steer it with your little pinky, and i don't like them. Some internet info says that variable ratio is for parallel parking, BALONEY. (that was harsh, excuse me). I bring this all up now as this is the prime time to do all the change and don't look back. If anybody doubts this info, just drive a newer gm truck with all of this engineered in and then tell me this is wrong? Good luck. Brian F.
05-17-2013, 08:48 AM | #8 |
I did forget one additional issue, is rag joint mating. Pay attention to both your original one and the newer one (get it with the box). Worst come to worst i can't think of who makes the rag joint to adapt up, but i know it's possible as i used a 1985 2wd box in my 68 factory power steering truck and i think i made one rag joint out of two, attention to details, that's all. The input spline diameter i believe got bigger on the newer boxs. Good luck and let me know. This conversion looks stock but you will know and feel the difference!
05-17-2013, 09:00 AM | #9 |
Oh, rag joint needs to have the metal strip be installed across the front half to the back half to supply ground for your steering column otherwise your horn won't work. Boy at 57 years old this keeps the gray matter working. I loved front end work and electrical work so this project satisfies both. Rag joints have two different diameter bolts so it keeps everything indexed straight, otherwise you change rag joint, nothing indexed, and your steering wheel would possibly be upside down driving straight ahead, That god for engineers.
05-17-2013, 09:14 AM | #10 |
As an engineer------you are one of the few people to ever say that. Mostly we get cussed at
05-17-2013, 09:17 AM | #11 | |
Charlie Daniels w/ a Tq Wrench
ΜΟΛΩΝ ΛΑΒΕ 67 C10 Shortbed "Great Grandpa's Truck" I6 3 on the Tree 71k original miles 5.3 swap in the works69 K5 Blazer-Family Beach Cruiser Project 78 K30 Dually Semi-Retired Fire Truck 350/SM465 35"s SOLD01 2500HD ECSB 6.0 4x4 5.13's 8" lift 38"s |
05-17-2013, 09:47 AM | #12 |
I did the 5.3 in my 68 and love it. Made my own motor mount brackets, and used the 2001 motor mounts as older motor mounts had issues of separation, replacements are rock hard, and newer trucks strive to reduce noise, vibration, and harshness (NVH0. I made my factory temp gauge still read half scale because the 5.3 runs hotter, Nova tight tuck sanderson headers, Painless ecm harness with 5 extra feet and put the ecm behind my bench seat, newer variable ratio quicker gear box, 72 up 5 lug, lowered spindles only and 4" drop in the rear with antiswaybars front and back. I'm old school so bags are not me. Good luck, Brian F.
05-17-2013, 07:33 PM | #13 | |
05-17-2013, 08:43 PM | #14 |
On my truck,, when the new engine goes in--everything on it will be new-----that brought on the power steering issue.
I started to order one from LMC but decided to go to oriellys and order a new one there so I could compare. Good thought! The 71-72 hose (as well as the one listed for 69-70 looked nothing like the one I had (one that I had--that I knew worked!) An astute counter man at oriellys said the one I had looked like a "generic" GM hose that he was familiar with. He went to the back and brought one up that was an exact match to what I had. I asked what it fit---his answer was Maaany gm v8's. One that he called up was for a 73 blazer. So, rather than take a chance on going back with what was "supposed" to work, I decided to go with what I knew worked. (mine had several more bends in it also.)
1997 shortie stepside 1968 short stepside 1966 mustang 1966 chevelle ss Dont always go the cheapest route--You can save yourself into the poorhouse! My Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=489030 |
05-23-2013, 12:50 AM | #15 | |
Before and After
Not Grandpa's C-20 anymore... 383 Stroker 425HP, 485Ft/Lbs Lowered 3.5" Front / 5" Rear 66,000 miles. Alberta, CANADA |
05-17-2013, 09:59 PM | #16 |
One thing you might try is to take a cable tie and wrap it around the hose and the brake line under it. Just tighten it enough to pull the hose down away from the belt. I bought a hose from Napa that looks kind of like yours, it doesnt hit the belt but it was close to the header and I did the cable tie thing and it works.
Posted via Mobile Device |
05-17-2013, 10:51 PM | #17 |
looks like you have it on backwards...switch the two ends around
05-18-2013, 07:16 PM | #18 |
Good luck with contacting LMC. I did that with a lower ball joint issue---Theirs was too small---I contacted them about the issue---they looked at my "profile" and decided the answer to the problem was----I ordered the wrong part!! I argued, sent pictures and waited for their "investigation"------4 months later,, they must still be investigating a ball joint that was physically too small!!
Youd be much quicker handling the issue your self!
05-18-2013, 09:58 PM | #19 |
Rock Auto shows the same hose for the K10 as the C10. However, I'm not sure if this is correct. They also have pictures of the actual parts. If they are the same, I have some close shots of mine on my 69 without the inner and outer fender. I can post them if you'd like.
Jim Last edited by FirstOwner69; 05-18-2013 at 10:08 PM. |
05-23-2013, 09:36 PM | #20 | |
http://www.lmctruck.com/icatalog/cb/full.aspx?Page=128 I have been looking for any pictures, but so far no one has given me any. Please do! You can either post or email me. I know you have my email from before. Thanks.
