10-19-2008, 12:10 PM | #1 |
Stock '67 headlights are trash, need help.
The headlights have a broken prong, lights still work, but every good bump, they go out, luckly just one goes out...lol. I need lights bad, I looked at the clear ones on LMC Truck that you can change the bulbs, and not wait 2 to 3 weeks on a new headlight. Most people don't seem to like LMC, whats some good places to buy headlights? I need some lenses too, both back lenses, and both front turns.
10-19-2008, 12:26 PM | #2 |
Re: Stock '67 headlights are trash, need help.
Cibie H4 headlamps—7” round
http://www.danielsternlighting.com/p.../products.html H4 high/low beam, convex (domed) lens: $74.95/ea
Trueman |
10-19-2008, 12:28 PM | #3 |
I bought mine at Wal-Mart. Halogens, I think I paid $10-12 each.
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride American Born, Country by the Grace of God 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! Last edited by 67ChevyRedneck; 10-19-2008 at 12:30 PM. |
10-19-2008, 02:13 PM | #4 |
I just picked up a new pair at Napa... H6024
10-19-2008, 02:43 PM | #5 |
20' Daredevil (Ret)
Cibies are the best, IMO -- if you want lamps that are nearly as good for less $$, get Hella H4 E-Codes. One good outlet is http://www.rallylights.com/ (no affiliation).
Whatever you get, the relay mod is highly recommended.
- Mike - 1972 K20 LWB 350/350/205 RIP El Jay |
10-19-2008, 02:55 PM | #6 |
I want lights where I can buy the headlight bulbs, and not the whole light everytime. When I blow a bulb out, I want to go buy the bulb...lol
I think the clear lenses look great. |
10-19-2008, 10:45 PM | #7 |
20' Daredevil (Ret)
The above mentioned Cibies and Hellas come with replaceable H4 bulbs, as do many other aftermarket headlamps.
10-20-2008, 09:59 AM | #8 |
I like the ones from LMC Truck, but can't remember what the price was. I saw a pic of the lights on another tread on here.
I'm guessing the ones at part stores, and Walmarts are the whole light, and the bulb isn't replaceable. I haven't ever looked, just figured they were. Thanks guys, I'll look into them all. Atleast I know theres a few out there. |
10-20-2008, 09:47 PM | #9 |
I agree with Corn - Some H6024 halogens are much better than stock and will not over load your wiring, same wattage as stock. We have 3 trucks here with halogens and properly adjusted, they light up the road better than many new cars.
Sticking my neck out here but there is no real good reason to rewire with relays and all the stuff, when a halogen H6024 does the job. Try them, at worst you would only be out less than 20 dollars.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103 1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285 1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894 2001 GMC Sierra 1500 C3 6.0 |
10-21-2008, 09:39 AM | #10 |
Thanks guys, I'll go to Wallyworld, and pick up some. I'm not rewiring the whole truck, when its been rewired already, originally.
10-21-2008, 09:43 AM | #11 |
The wiring they are talking about is just a headlight harness that many vendors sell or you can make up one yourself..
A husband can be right...or...A husband can be happy. 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! |
10-21-2008, 10:02 AM | #12 |
I just re-wired under the hood, where the harnesses plug in the firewall. My wires started cracking about a year ago maybe, that, and I went to a internal voltage regulator like most probably do. I still have the stock dimmer switch, and fuses, and everything. I just updated a few minor things.
10-20-2008, 01:49 PM | #13 |
PROJECT 7DEUCE
check with wes at classic heartbeat.
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
10-20-2008, 02:04 PM | #14 |
They don't offer any headlights, or they don't list any that I saw.
10-20-2008, 08:31 PM | #15 |
Old Skool Club
One thing to consider is that the existing wiring, if it is original, will be taxed to its limits if you install some hi-tech headlights. Even halogens, though often used, are a good load. You gotta remember that the current that operates them goes through the light switch. How old it that part? Then, there's the dimmer switch. It ain't new, either, is it?
If you want some hi-tech lights, you need to consider upgrading the wiring (it's easy to do with what the vendors sell) and also installing a relay kit that will take the load off of the switch and let the relays handle the load. Then, it won't matter if you use Cibies, Hellas or whoever's bulbs. But, in the meantime, go to WallyWorld and get you some new headlight bulbs, H6024's are just peachy, and don't risk driving in the dark when you least expect it.
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
