![]() Join Date: Mar 2016
Hump fastener/hardware size?
What size are the bolts, including length? Do they have flat washers on both sides? Lock washer? Maybe they're sheet metal screws?
Re: Hump fastener/hardware size?
Captured nuts, if I recall, probably 5/16x3/4 bolts as a best guess.
1970 GMC Sierra Grande Custom Camper - Built, not Bought 1969 Pontiac 2+2 427/390 4-speed Coupe 1969 Pontiac 2+2 427/390 4-speed Convertible |
That really makes sense. Didn't consider the difficulty of fastening with loose hw.
Can anyone confirm the size? Also, the captive nuts, are they just square nuts welded in, or are the "fancier kind" with a cage around them?
![]() Join Date: Aug 2014
I have a set I will check size tomorrow
My dad always says that HEI distributers are pointless... •1972 Custom/10 Deluxe. My first truck and I've had it since I was 7. Tilt, tach, AM/FM, 350, deep dish rally's, original paint and an increasing amount of NOS jewelry. It's always taking my money.. •1967 c10 with tach, dropped 3/5 on deep dish rally's •1972 Cheyenne Super. Sold |
![]() Join Date: May 2003
I just did mine yesterday, 10 - 5/16-18 thread x 3/4" washer head bolts. This is what's on the original installation with the nuts welded under the floor. The capture nuts should work good if your adding a high hump.
Gary
Gary 72 SWB 4x4 My 72 SWB Build http://67-72chevytrucks.com/vboard/s...d.php?t=259859 Last edited by CUSTOM/10; 08-07-2016 at 12:27 PM. |
The nuts welded to the floor...simple square nuts tacked or some sort of caged nut?
They are square nuts, but they also have a strip of heavy gauge sheet metal attaching them to each-other to help distribute the force. In the past I have tach-welded flange nuts under the floor and that work well.
Gary
Gary 72 SWB 4x4 My 72 SWB Build http://67-72chevytrucks.com/vboard/s...d.php?t=259859 |
That's why I said "captured nuts" but you said that didn't make sense :-) I think two of mine broke loose or were missing and I had to use a nut, but should have tack-welded a square nut there to be more correct if I cared about that level of hidden detail...
I said that it did make sense.
I must have read you backwards the first time, sorry about that!
Thanks. Interesting. Not sure I'm tracking 100%. Maybe someone has photos.
I found some pics that show it. I'm tracking now. One more question: On the upper 2 bolts. Was there a thick metal strip on the bottom side with the nuts or were the strips just on the 3 flat sections?
Nothing on the 2 top nuts just the 3 straight sections.
Gary
#15 |
![]() Join Date: Dec 2015
Any one have pics of the reinforcing strips?
#16 |
I managed to find some shots of them in the thread below. My question now is how the strips are attached. Are they tacked in a few spots or welded all around?
http://67-72chevytrucks.com/vboard/s...ghlight=Tunnel |
#17 |
Eagle sniped the hump I was watching (link above)! I was drafting him a PM when you posted that you were interested. No worries.
#18 |
Sorry about that, I thought you were posting the link just to reference the picture. See my reply on that post.
#19 |
No worries. I should've been quicker on the trigger. It's all yours. I'm looking for the whole package if I can get it (but plates and hump), so I really don't need to split it up.
