03-01-2014, 06:19 PM | #1 |
Linkage getting stuck between gears
Hi everyone – I have a 3-on the tree and my linkage gets stuck between gears. I am thinking that I need to change out the bushings/hardware. As you can see in the picture it is really worn… Does anyone know where I can purchase this kind of hardware? I checked my LMC catalog and I did not see it in there. The three pictures are two on the column and a picture at the tran. If you have any other suggestion - always appreciate everyone advice.
Thanks for your help! |
03-01-2014, 06:38 PM | #2 |
Re: Linkage getting stuck between gears
Check out this thread. I can't help you out with a rebuild kit, but this explains how to adjust the linkage to keep it from hanging up.
http://67-72chevytrucks.com/vboard/s...d.php?t=215307 |
03-01-2014, 06:51 PM | #3 |
i buy parts at the local autoparts store
03-01-2014, 06:54 PM | #4 |
Watch out for your cornhole !
New bushings and hardware should fix your problem. I've bought the parts from Classic Parts up in Missouri for several linkage rebuilds over the years.
http://www.classicparts.com/1960-76-.../#.UxJkjZK9KSM
03-02-2014, 07:42 PM | #5 | |
Chris |
03-01-2014, 06:55 PM | #6 |
Check rockauto and see if you can pull the part numbers off and then shoppe around to see if any other parts stores or online shoppes (summit or Jegs) sells it
03-01-2014, 07:18 PM | #7 |
You guys rock!!
Thanks for your feedback! Chris |
03-01-2014, 09:49 PM | #8 |
Before you buy ANYTHING adjust that thing or you money. The thread that was posted I didn't read of course but there is a simple guide in the FAQ or the truck tech section of the home page of this site. If you have not been there it is worth the time investment to do so. The project ideas and quick and simple fixes for thing such as the hanging linkages really pays off. I bought a 70 3oot truck and had trouble driving to my shop as the shifter would hang a bit shifting on the ride home and I adjusted as the post said and then it was like new. The bushing were worn but it shifted so much better. Jim
03-02-2014, 07:08 PM | #9 |
How to fix it? Get a rock crusher, ha ha ha ha. Or a floor shift conversion for the 3 speed. Summit just had the truck 3 speed for 40 bucks, plus it looks cool
03-05-2014, 07:14 PM | #10 |
New bushings and proper adjustment as in the link will help immensely.
That is what I did. Installed the Hurst floor conversion kit. Probably the best thing I did to this truck. Much easier shifting. No disputing that 3 ott coolness factor though.
1969 c-10 Step Side Long Bed. I-6 250cid = = 1969 Pontiac GTO hard top. 400, 4-speed. |
03-02-2014, 07:48 PM | #11 |
CAN'T FIX NOTHIN
It may just be that you need to practice shifting it ? Anybody else can try to drive my 67 and they tell me the shifter is messed up , I can drive it 7 days a week without a problem ? Is mine tore up ?
1967 C10 Shortbed Fleetside Small back glass 6 cyl 3spd on the tree 3.08 gears underdash AC |
03-02-2014, 07:55 PM | #12 |
CAN'T FIX NOTHIN
Here is how to shift a 3 on the tree !
#1 starting from 1st gear pull back on the shifter towards the steering wheel raise the shifter up to neutral while holding pressure on it towards the steering wheel this keeps the levers from trying to go in two gears at once which is what hangs them up #2 let it fall gently towards the dash and push slightly towards the dash and raise it up into 2nd gear #3 push gently towards the dash from 2nd gear and pull down to 3rd gear it dont matter if the bushings are worn or not it will shift like this ,,,,,, good bushings do help
1967 C10 Shortbed Fleetside Small back glass 6 cyl 3spd on the tree 3.08 gears underdash AC Last edited by 19673ontree; 03-02-2014 at 08:08 PM. |
03-05-2014, 02:55 PM | #13 |
X2 on 71Sixer's link. That single quick & simple adjustment will make your 3OTT shift like (well damn close!) new.
Wanda - 1969 C/10 LWB 250 I6 3OTT LWB>SWB |
