01-31-2022, 03:45 PM | #1 |
e38 ecm pin removal
doing a diy harness modification do i need to remove the pins in the molex connector or can i just cut the wires close to pin and not have any issues. i cant see spending $85 for a extractor tool that i wont use but once thanks for you help
01-31-2022, 08:44 PM | #2 |
Re: e38 ecm pin removal
Easy solution. Remove the wire covering by gently prying out on the two tabs where the wires meet the connector. Lift it off. Then pry the blue, grey or black pin retainer to expose the pins. Look inside and you will see small piano key type fingers holding the pin. Using a jewelers screwdriver, gently lift the piano key away from the pin and pull the wire out. Another option is to just cut the wire off and push it through the connector, after removing the colored connector portion.
Current project 1959 Willys = GEZR TRUK Geezer is a Latin compound word made up of two roots. Gee meaning Urine Stain and Zer meaning your pants are open! FMCDH GBU and GBA http://www.youtube.com/user/aknovaman/videos |
02-01-2022, 08:00 AM | #3 |
thanks i will try that
02-01-2022, 10:03 AM | #4 |
Moderator
Family and country before all others... 2006 Chevy Silverado (Daily Driver) 2012 Chevy Equinox |
02-01-2022, 11:36 AM | #5 |
02-01-2022, 01:27 PM | #6 |
thanks everyone finally getting back to my truck with all this crazy going on in the world. going to the local pick and pay to see if i can find a donor fuse block. any one have any suggestions. thanks
02-01-2022, 09:25 PM | #7 |
BMW & ASE Master Certified
Removing that cover makes it a pita to snap back on when the teminals twist. I.bought the tool qhen that sum b was 65$ and its stupid simple but is the right tool for the job.
If you have ended length micro drill bit set will do the job too. Clint
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes 1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD A poor man buy's it twice finally got my domain name back, 87chevy.com.... site rework in progress |
02-03-2022, 03:43 PM | #8 |
tcm pin out
meant to start a new post
Last edited by 1958paul; 02-03-2022 at 03:48 PM. Reason: wanted to start a new post |
