Old 05-19-2010, 03:51 PM   #1
likaroc13
Rollin' Old Skool
Opinions: 71-72 vs. 73-87 front crossmember
hey guys,
i'm looking to do the 5-lug disc/drum swap...i've found a 72 with the rear end & gears i want...it also has the front crossmember with power steering/brakes...in my research though, i've read that there are some advantages with the 73-87 having rubber bushings...so, i'm unsure what to do...my initial plan was to find a 71/72 rear & 73-87 front crossmember...however, i didn't expect to find a complete 72 5-lug chassis...can anyone with experience list the pros/cons...should i just get the rear & hold out for a 73-87 front? or just get everything for the 72?
just for reference, my truck is a '66 short/fleet....later i plan on a 4.5/5.5" front drop, & 5" rear...this isn't a truck that will be driven daily...it's basically my weekend cruiser & show 'n' go truck...but i do want it to be road worthy enough to travel "comfortably" long distances every now and then
thanks for any help
Old 05-19-2010, 05:25 PM   #2
SCOTI
SCOTI's Avatar
Re: Opinions: 71-72 vs. 73-87 front crossmember
71-71 a-arms are just like what you currently have on your 66; 73-87 have the more 'pliable' rubber bushings which transmit less road noise & vibration. Think of the 6x-72 bushings as rubber lined steel sleeves. You feel more because they deflect less. The question would be is the softer ride of the later bushings more important to you?
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 05-19-2010, 05:38 PM   #3
likaroc13
Rollin' Old Skool
of course, i want it to be as comfortable as possible with a considerably lowered stance...but what i'm not sure of is how much of a difference is there between the two? drastic or not? considering this isn't something that will be daily driven, is it still worth it to go with the 73-87? that's where i'm stumped......so i guess i'm trying to figure out how much better of a ride will i have with the '73-87? if it's a very noticable difference, i'll hold out for the 73-87....if not, the 72 will have everything else i need
Old 05-19-2010, 06:40 PM   #4
protrash64
Resistance is Futile
protrash64's Avatar
I have one of each bushing type and can tell no difference. I believe tires,coils, and shocks play a more important roll.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
Old 05-19-2010, 07:29 PM   #5
SCOTI
SCOTI's Avatar
Agreed.
I've used more of the 73-87 stuff doing conversions because it's easier to find in a wrecking yard vs. 71-72 stuff. I used 71-72 stuff for my 68 when I did the disc swap because it was an easy find. I haven't noticed much difference vs. my 74 (both trucks were lowered similarly w/dropped spindles w/1-coil cut).
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 05-19-2010, 07:40 PM   #6
protrash64
protrash64's Avatar
No debate about the cost of the newer stuff being more 'budget friendly'...
Old 05-19-2010, 07:52 PM   #7
62 mark
62 mark's Avatar
I would prefer the newer style bushings, however on a budget i took what i could find cheap, which was a whole 72 chassis for 200 bucks.
62 mark is offline   Reply With Quote
Old 05-19-2010, 08:35 PM   #8
Chris65GMC
Can someone post the thread on swaping a 73-87 front member/suspension on a 60-66. I looked but could not find....
Please?
Thanks!
Chris
Chris65GMC is offline   Reply With Quote
Old 05-19-2010, 10:46 PM   #9
likaroc13
Rollin' Old Skool
Originally Posted by SCOTI View Post
Agreed.
thanks guys...this is what i was wondering
Please?
Thanks!
Chris
here's a link to some details
http://67-72chevytrucks.com/vboard/s...ght=disc+brake
you can also look at Tx Firefighter's build thread for some pics of his swap...i'm sure there are several other members who have done this swap as well...you can browse through the build threads
Old 05-20-2010, 10:52 PM   #10
likaroc13
Rollin' Old Skool
any other opinions? i plan on looking at the 72 this weekend
Old 05-25-2010, 07:11 AM   #11
raycow
I have used both designs and can't feel any difference in the ride. To me, the advantage of the 73-87 is that the bushings don't need to be greased. Also, you might prefer the later engine mount design.
If you find a 71-72 setup, you don't even have to swap the crossmember. Just unbolt the control arm shafts, which is a lot less work. If your truck isn't going to be used as a daily driver, the greasing should be a non-issue.
Ray
raycow is offline   Reply With Quote
Old 05-25-2010, 09:31 AM   #12
SCOTI
SCOTI's Avatar
Ray
You don't have to swap the c.member to use the later 73-87 style bushings. Just swap the a-arms, spindles, & the rest to the original c.member.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 05-25-2010, 10:49 AM   #13
raycow
Are the control arms the same length as the grease type? I'm asking because the only swap I have ever seen done like that had camber problems. I assumed the reason was the arm length, but I never actually compared the two types to find out. If they are the same, this would save a whole lot of work.
Ray
Old 05-25-2010, 01:01 PM   #14
SCOTI
SCOTI's Avatar
Ray
If there's a length difference, it's minute (I've stood them on the ground back to back). On the one you had camber issues, were the a-arms the only thing swapped?
The 63-66 suspension is similar to the 67-72 w/the steering box/linkage slightly different (actually it's the 63-67's that are different).
Originally Posted by 62 Bowtie
Now for clarity this is for the 63-66 right? I have a 62 torsion bar set up so I will need the entire crossmember setup be it 72 or 73 not just the a-arms and spindles
Yes, 63-66. Earlier trucks will require swapping the c.member (or to a Dropmember ).
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 05-25-2010, 11:11 AM   #15
62 Bowtie
62 Bowtie's Avatar
62 Bowtie is offline   Reply With Quote
Old 05-25-2010, 11:27 AM   #16
likaroc13
Rollin' Old Skool
Ray
actually i don't mind swapping the crossmember, as i plan to paint/clean things up...i think it'll also make it easier to rebuild the components & then roll the crossmember under
i believe that is correct
