Old 04-21-2008, 04:04 AM   #1
gr8one
cheap straight axle swap late model
i have a rockwell 211 independent transfer case, im doing a sas on my 97 crew cab. i used front spring hangers from a 78 ford f250 and the rear spring hangers. and i used 2003 f350 superduty 4" lift leaf springs. here is a before and what i have done so far.
gr8one is offline   Reply With Quote
Old 04-21-2008, 04:18 AM   #2
toomanytoyz
Luv the Crewcabs
toomanytoyz's Avatar
Re: cheap straight axle swap late model
Really like your Build, Great way you went about doing it. I 1st saw your post in Storm Chaser's thread & meant to compliment you on it then, this actually worked better for you to do your own Build thread for us to follow along with...........
What all do you have planned for the Truck Build???
Rick
55 Nomad
52 Willys Truck
67 Stepper
67 Fleet
68 Wrecker
68 Suburban
76 Crewcab
79 Gmc Dumptruck
84 Blazer
86 Crewcab Stepside
87 Iroc
89 GMC Plow Truck
91 Camaro Vert
96 Z71 Stepsde
toomanytoyz is offline   Reply With Quote
Old 04-21-2008, 04:41 AM   #3
FormerMember
FormerMember is offline   Reply With Quote
Old 04-21-2008, 04:59 AM   #4
gr8one
the front spring hangers will be weld to under the frame horns.
Old 04-21-2008, 05:02 AM   #5
gr8one
by the way this is a 2wd converison i have done many of 4wd converisons, so i thought i would convert my 2wd to 4wd.
Old 04-21-2008, 06:24 AM   #6
FormerMember
Old 04-21-2008, 03:37 PM   #7
gr8one
no the front hangers are front f250 hangers attached to the spring in the rear is the rear spring hangers from the rearend from the same f250. it is 8:55 a.m here in Fl i will be installing the frod 1/2 ton crossover steering on it today. will post pics later.
Old 04-21-2008, 04:16 PM   #8
msgross
msgross's Avatar
looks like your getting plenty of lift too... what the plans for the rear/?
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 04-21-2008, 04:32 PM   #9
gr8one
i might use a block lift and level the truck. or i might have some springs made by tampa spring.
Old 04-21-2008, 04:40 PM   #10
1969 GMC
1969 GMC's Avatar
cool project, except i'd keep my eyes open to find a better t-case.
1969 GMC K2500
1996 Honda Accord
2007 Kawasaki KLR 650
1969 GMC is offline   Reply With Quote
Old 04-21-2008, 11:48 PM   #11
b454rat
Looks like the axle is back a couple inchs....looks good tho..
2000 GMC CCSB 454/4L80 6” lift SAS
1999 Chevy CCSB 454/NV4500 6” lift
1999 GMC Yukon 350/4L60 4" SAS
Old 04-27-2008, 11:47 PM   #12
gr8one
i have finished the swap and made a 200 mile road trip on it today i will post pics later today or tomorrow.
Old 04-29-2008, 01:52 AM   #13
gr8one
Wink Re: cheap straight axle swap late model
before and after
if you have any questions just ask.
Old 04-29-2008, 03:07 AM   #14
msgross
msgross's Avatar
any pics of the TC and drivetrain setup....
The Garage:
Old 04-29-2008, 03:23 AM   #15
gr8one
the transfer case is a independent rockwell 221 out of a 1967 suburban, im building the cross member. wifes 98 gmc z71 blowed head gasket yesterday.
Old 05-20-2008, 07:36 AM   #16
b454rat
Haven't seen this post in awhile, but that turned out pretty sweet. Have anymore pics of the mounts?? About how much lift did you get overall??? I want to do a small SAS, trying to get some ideas....
Old 05-21-2008, 12:35 AM   #17
gr8one
at first i had 4" overstock springs which gave me 10" of lift. i removed the 4" overstock and put the stock springs on it. 6" of lift with the factor springs. drives as good as it did before. which pics do you want to see. i can get the pics for you.
Old 05-21-2008, 12:38 AM   #18
gr8one
look at the wheel well you can see how much lift.
before and after.
Old 05-21-2008, 12:52 AM   #19
FormerMember
Old 05-21-2008, 02:00 AM   #20
Pyrotechnic
Pyrotechnic's Avatar
Nice build! Looks great with the solid axle up front.
Pyrotechnic is offline   Reply With Quote
