Who makes the best vinyl floor mat?
I had originally bought black carpet for my truck but I think I want to use the vinyl floor mat instead. Who make the best quality/fit mat? Any pics would be great! Thanks.
20' Daredevil (Ret)
![]() Join Date: May 2003
Re: Who makes the best vinyl floor mat?
I bought one a few years ago, can't recall where I got it, but I wasn't ready to install it so I stored it in a dry shed for a year or so. When I unrolled it, it was dry rotted and worthless and I threw it away.
So when I bought another new one last year, I was very concerned about quality. Did some research and bought from Wes, but he was out of stock and had one drop-shipped to me from Brothers. Appearance and fit was excellent, just like OEM, and I'm hoping to get several years of use from it.
- Mike - 1972 K20 LWB 350/350/205 RIP El Jay |
#16876
I've had mine since 2005 and it looks and fits great. It came from Classic parts (Chevyduty) but that's been a while ago. I'd also check with Wes and other board vendors. I doubt there are very many manufacturers of these mats though
Posted via Stationary Device '71 Custom Deluxe C-20 402. '67 Buick Special 455. '49 Plymouth Special Deluxe. "I love that old car smell" ![]() Some people are like Slinkies... not really good for anything, but they still bring a smile to your face when you push them down a flight of stairs. |
![]() Join Date: Aug 2008
I bought one for my dads 71 GMC from LMC in 07 and it still looked good when i sold it last year. Another member on here has the truck now but i forget his handle. Granted we only put around 3k miles on the truck in 5 yrs, but i dont think using them is what wearsthem out. Some brands seem to be made from inferior rubber.
Get the Mil mat from LMC. It is a full coverage mat even under seats. It is thicker then original.
1976 k20, 350 built, 44/14 axles 1968 c10 6.5 turbo diesel,t5 trans 1977 gmc c3500 dually, crew, 4-53t, 5&3 trans http://67-72chevytrucks.com/vboard/s...d.php?t=591188 |
I hate to put anyone down, but I would not buy another rubber mat for our trucks ! I purchased one from Brothers less then two years ago, the first one shipped did not even come close to fitting, they did replace it with a correct one ASAP but the dimmer switch hole was way off position? Now I have noticed a long tear in the center of the transmission tunnel? And this is a low hump floor? Also no one has sat in the car other then me and I don't put my feet on the tunnel ever ? I think the rubber today is just plain crap period! I am building a 71 K-10 now and would prefer it to have a rubber mat, but I think I will go with carpet and get a good set of mats to protect the carpet . Also I feel that rubber mat holds moisture underneath and promotes rust, JMO......
71 C-20 07 Magnum RT AWD |
I bought one from Classic this summer. It is thick and required trimming on all sides and all holes. Full coverage, high hump version. Good so far. Good Luck!
1955 GMC 250 8 Flatbed 1971 C30 157" 350 4spd 10' Flatbed 81 GMC K30 CnC 9' Flatbed 454 T400 89 GMC Jimmy Stock https://67-72chevytrucks.com/vboard/...d.php?t=810958 71 LT1 Convertible, 72 Coupe 69 CJ5, 75 CJ6, 67 M715, 72 M35A2 Bobbed, 95 XLC2 |
Good topic! I have the original mat but it is slightly torn.
After 2 carpets I too am staying with the mat. I bought the real rubber one from Brothers because a vinyl one I purchased for my 72 Blazer CST was cheap feeling/looking, but I think the key is to be sure to buy the padding too. My Suburban still has most of the original pad, but I went ahead and bought the new soundproofing with it.
The Older Generation
As far as I know, AT THIS TIME, there is only one manufacturer and it is the cheap one. The molding and texture is crappy on them. Someone correct me if I am wrong... I finally found an older stock one that looks good. LockDoc
1969 Custom 30 wrecker
Mine got all dry rotted and cracked after about 2 years. For the cost of these, I expected alot more than this.
Typical repro junk!
Bob 63 Impala 283/PG/3.36 (under restoration) 66 Impala 327/PG/3.36 66 Chevelle SS 409/M22/3.55 69 Chevelle 307/PG/3.08 (future restoration) 69 C10 short stepside 454/TH350/3.73 69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!) 71 Cheyenne 20 fleetside 350/4 spd/4.10 71 Chevelle 6/PG/3.08 72 Chevelle 454/M21/4.10 |
Man, not real good reviews on these mats. Is anybodyhappy with theirs?
#13 | |
Only thing is mine is an '87, and I'm not sure if he has them for '67-72, but worth checking. K ![]() ![]() ![]() ![]() ![]() ![]()
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
#14 | |
20' Daredevil (Ret)
It fit perfectly (high hump) and only needed minor trimming where the seat bolts to the floor. The real test will be how it holds up over time (I just installed it last summer) so I'm keeping my fingers crossed. I also laid down new padding & soundproofing under the mat.
#15 |
If Wes carries them I would go with him.
71 swb 350/4sp manual 5/7 static drop |
#16 |
just cleaned out the inside of my 72 k10 mat is 3+ years old fit was good no dry rot yet ! got it from LMC
California 65 GTO---Texas 64 burb 283 ---Oklahoma 67 CST SWB BBW wood bed 327 2004r---New Mexico 72 k10 350 350 auto---Georga 72 short step project Last edited by 67swb72klb; 10-07-2013 at 01:24 PM. |
#17 |
67-72 trucks did not originally have a mat that covered under/ behind the seat. Not sure if anyone makes a mat that does.
#18 | |
![]() Join Date: May 2010
It wasn't only the rubber mat trucks. Here's a picture of the original carpet from my 69. A top of the line CST with buckets no less. No carpet, pad or other soundproofing of any kind under the seats. Notice it was also trimmed away under the sill plates. |
#19 |
![]() Join Date: May 2014
Yeah easy to forget how plain-jane trucks were even recently.
My 1997 top of the line Suburban had an electric 6-way seat on the driver's side only.! How cheap.! For my '67, I'm going to get one of those full vinyl mats I saw on another post and use it to cover the under seat area because I've put down the silver sound proofing and it's not tough or very good looking.
Kitsbeach (Ken) 1967 C10 LWB (now SWB) Fleetside 6cyl Saginaw three-on-the-tree "No Frills" 1980 C20 Long to short & static drop "Square One" Last edited by kitsbeach; 10-19-2014 at 12:53 AM. Reason: typo |
#20 |
20' Daredevil (Ret)
^^ x2
#21 |
I'm currently shopping for a new vinyl floor for my '72. Most of the threads I found by searching were years old. Any current recommendations or reviews?
#22 |
![]() Join Date: Jun 2007
I bought a rubber work mat from Home Depot and cut it to fit. It's thick stuff and tough but you have to be okay with some pie cuts under the dash.
#23 |
Brothers, Classic Industries, LMC, and others have them for sale, but does anyone have a better quality product or price? I would like it to have the pattern of the original floor also if possible (see photo above). Looking for recommendations from those that have bought and installed.
#24 | |
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
#25 |
My low hump one sucks. Bought one from LMC-returned it. Bought a second from Brothers-returned it. Bought a 3rd from Brothers, waited till it was 100+ degrees here and installed. Damn thing still has a couple of bumps where it heads up the trans. housing...grrr. Everytime I look at it, it pisses me off. If somebody makes one that fits--for sure--I'd buy it.
Figure out what you want--then figure out what you are willing to give up to get it. |
