where does ya'lls exhaust dump out?
going to the muffler shop this weekend and getting my exhaust redone. where do ya'll have yours dump out and why?
thanks. |
Dude...I'm a CHICK
Mine dump straight down just before the rear axle, I have 2 chamber Flow Masters with 3 inch tips. I have it that way cause it sounds better, much "throatier" than they were when they dumped out behind the rear wheels.
~*~*~*~*~*~*~*~*~*~*~*~*~* "The unexamined life is not worth living" -Socrates ~*~*~*~*~*~*~*~*~*~*~*~*~* '71 GMC Suburban 4x4 |
Mine exit behind the rear wheels.
Jim |
Its Magically Delicious
duals behind the rear wheels..
71 C10 LWB 350sbc -TH350 12 bolt 3.42 Posi Of all my favorite things to do, The utmost is to have a brew. My love grows for my foamy friend, with each thirst-quenching elbow bend. Beer so frosty, smooth, and cold it's paradise pure liquid gold. Yes beer means many things to me that's all for now cus I gotta pee. |
#5 | |
Hot Rods For Life
The LuvShack Garage
My 67 Has Headers / H-pipe / Flowmasters / 4" X 12" Tips Dumping
45 Degrees In Front Of Rear Axle, Caution, I Changed This To Where They Dump Under The Axle Now Due To The Fact I Was Trailering, I Stopped At Good Old Wally World, Came Back Out To Find A Puddle Under My Truck, Heated Rear End Oil/grease So Hot It Blew Out Of The Overflow Hose, All Over My Flows And Underside Of My Truck, Needless To Say It Was A Mess To Clean-up And For Some Reason It Is Real Hard To Fill When Your In That Type Of Senario, My $.02
Born To Lose Club
![]() Join Date: Feb 2003
Location: Calgary, Alberta/Oxenden, Ontario, Great White North
I Too Like GMCJunkie...whoop...I mean I too, like GMCJunkie have exhaust that exits before my rear axle.
![]() I get compliments about it all the time and it's not even a special setup at all. I don't think I'll change it either I like the way it echoes and rumbles from beneath the bed... ![]()
Brian Smith ![]() 1969 Chevrolet K10 LWB Fleetside - Proud Owner For 20 Yrs - 1 of 208 Built & Sold In Canada! - 283 V8/350TH/NP208, 2" All Spring Lift, 32" Good Year MT/R's. 1972 GMC K2500 Custom LWB Fleetside - Proud Owner For 2 Yrs - 1 of 571 Built & Sold In Canada! - 350 V8/SM465/NP205, 4” Rough Country Lift, 33” Interco TSL Thornbirds 2007.5 GMC Sierra SLE 2500HD 4x4 - Proud Owner For 15 Yrs - 6.6L V8 Duramax Diesel/Allison 1000, 2" Lift, 33" Mickey Thompson MTZ's. 2008 Yamaha Raptor 700r - Proud Owner For 13 Yrs - ITP Mud Lites. 2015 John Deere 1025R - Proud Owner For 6 Yrs - 24HP Diesel/H120/54D/260B/SB1154. Last edited by Canadian694x4; 05-07-2004 at 07:20 PM. |
I agree with GMCJUNKIE. My exhaust setup is the same.
I have one that goes straight out the back below the rear bumper and one that dumps out below the rear quarter panel behind the wheel. I don't like the one that is straight out the back as well.
Plus don't make your pipes stick further out than your rear bumper and then back into something.... ![]() |
user # 2756
![]() Join Date: Jun 2001
Both mine exit behind the rear wheels. Also check your local inspection requirements, for ex. here in VA the exhaust has to exit 18" past the normally occupied area(cab), outside the frame rails or out the back, so a burb with turn downs wouldn't pass in VA(bet it sounds good though).
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs 1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX 1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears 1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now..... 1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone. 1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed. 1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm ![]() Last edited by JIMs70GMC; 05-07-2004 at 07:04 AM. |
I need another Barley Pop
same as GMCJunkie's
67 Short Fleet 4x4 04 Honda CRF450R 89 Toyota 4-Runner 34 Ford 2 door sedan - Long term project ---------------------------------------------- There is a very fine line between "hobby" and "mental illness" ![]() |
English Chevy Owner
In front of the rear wheels either side, as fitted by previous owner. Would not be a good place on a 4x4 though as it would be too easy to crush the pipes against an obstacle.
Phil '67 C10 long fleet. 350/TH350, 4 bbl Carter, K&N, Dual exhaust, loads of stuff coming soon 2001 S10 Blazer Daily Driver, bone stock 4 door 4x4 with manual transmission |
Keepin an eye out
Behind rear wheels.
1970 Chevy C10 SWB 5.3 1996 Toyota Tacoma SR5 4x4 2007 Vespa GTS 250 Scooter ZIP 91351 |
Fabricate till you "puke"
mine is side exit , ahead of the rear wheels(Hooker headers.2 1/2" pipe,H pipe, running into Dynomax Superturbos. the tail pipes are a 90 (mandral bend) out of the muffs, the are bent 45 around the nose end of the leaf hangers, to kick out the sides at an angle. i like to hear them run, so side exit was my choice. crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
#15 |
Formerly yellow72custom
My system looks just like Pont's, headers, 2.5" duals, and 40 series Delta Flow flowmasters with turndowns infront of the rear axle.
I like the way it sounds. Fairly quiet until you open it up and then it gets really loud. Has a fairly deep muscle car tone to it....kinda unique, sounds really good and turns heads. For awhile i had the same system with no turndowns, and it sounded really deep and throaty. Turned even more heads, but was a little loud and kept getting me into trouble so i slapped some turndowns back on it. Quieted it down.
'72 Chevy C10 Mild 350/TH350/3.07. Ochre/White. Old high school ride. '70 GMC C2500 '62 327 4bbl/SM465/4.56-geared Dana 60. White/White. Project or parts truck. '97 Saturn SL DD. 1.9/5-speed. 40+ highway mpg |
#16 |
![]() Join Date: Sep 2003
2.5 duals, crossover with 40 series flows exiting behind the rear wheels
#17 |
I just had mine redone as the original had rusted a bit too much for my taste. 2.5" duals that turn out and dump just behind the rear wheels. I'm just a little disapointed with how far out the sides of the truck the pipes come. Gonna just cut them short and add tips that turn down.
MeanGreenMachine - 1972 Cheyenne Super 402 |
#18 |
Guess I'm just different. Mine have Oval tips and exit just under the chrome rear bumper.
Bill - Tucson, AZ 47 Chevrolet 2 dr sedan 56 Chevrolet 210 2 dr sedan 66 Chevrolet Malibu 2 dr 4 speed 71 Chevrolet C30 Longhorn 86 Chevrolet Monte Carlo SS (Sold) 01 Chevrolet Tahoe IM - BUSTERWIVE@aol.com |
#19 |
Mine exit out under the rear bumper no turn downs
1971 Cheyenne |
#20 |
Exit behind the rear wheels ahead of the bumper at about a 45 deg angle to the wheels. Don't like the way it looks, something the PO did but other things are more important to fix right now than how aesthetically pleasing the exhaust exits are. Sounds pretty good tho.
#21 |
71 DELUX
Mine exit just in front of the rear tires, but do not stick out in front of them. I'd prefer that they go straight out the rear, but I've not yet decided where I want the rear ride height to remain. It was easy to replace the rusted glass packs installed by the previous owner and simply turn the pipes out while I get the suspension and rear sway bar matters settled. :p
#22 | |
A splendid one to behold
![]() and pretty much for the same reasons too. after i get the truck back running again, i'm going to take it down and have 3" duals ran back and dumped at the axle what about you guys that have 4 link/ladder setups with the ass-end down a ways... what kind of setup are you running?
67 swb 02 wrx |
#23 |
Hank - not trying to highjack your thread but I am looking at getting exhaust done on my blazer.
Does anyone have their exhaust dumping behind the rear wheels, but turned down towards the ground? I think Fast71 had a setup that I am referring too. Any pics? Thanks, Jason
2006 Silverado CCSB, 1939 Ford Sedan, 1962 BelAir Wagon, 1976 Vega Panel Charleston, South Carolina |
#24 | |
#25 |
MOVE OVER
Mine (single exhaust for now) once exited behind the left wheel, but I cut it short to make room for the overload springs when I put them on... havnet decided how to do it when I go to dual exhaust..
No matter where you are..... There you are... Buckaroo Banzi |
