edelbrock performer rpm???
i was cleaning up the manifold before it went back on the truck. i started picking at what i thought were clogged coolant passages on the rear. well it turns out the are actually blocked off. i found when i started drilling and hit a aluminum wall. are they supposed to be like this?
Re: edelbrock performer rpm???
there are no coolant passages on the back of the manifold
common sense isn't so common anymore |
oh, i just figured there was since there is some on the heads
1971 GMC 3/4 ton, 572 CID
The heads have the holes on each end so that they can be used on either sidem intakes only have the cooling passages on the front
71 GMC 3/4 572 CID, 1988 GMC 1/2 2006 Saturn Vue "We always have parts left over on a job this size" |
