11-23-2003, 03:12 AM | #1 |
fuel
would a 3 gallon tank work for???
ok i am finishing my chassis for my 72 short box and i have a 3 gallon tank for my rear air ride but now i want baggs in the front also, would this three gallon tank be ok to do all four?
11-23-2003, 01:46 PM | #2 |
belly dragger
It'll work but you would be better off with two of them. Your compreeesor won't have to run just to get you up.
11-24-2003, 10:59 AM | #3 | |
Trucker.
11-24-2003, 05:02 PM | #4 |
Happy to be here
If you are asking will it be enough to get you up on one cycle from aired out to ride height, I will have to say maybe, maybe not.
It might be enough volume, if you have a compressor that can pump enough psi. If your compressor cuts off at a low psi, then it probably won't have enough volume to re-fill the bags. If you don't mind having two tanks, add another 3 gallon. If you just want one tank, sell the 3 gallon, and get a 5 gallon instead. Even with two 5 gallon tanks, my system cycles every other time on my 77...
11-25-2003, 02:02 AM | #5 |
I am only running the three gallon tank on mine. I pretty much don't even mess with my bags so it's not a big deal. It has only enough to go from empty to aired up before the compressor kicks on.
74 swb 71 2wd Jimmy 82 2wd Blazer |
