49 Chevy on a 2000 ZR2 low buck build
It was suggested that I start a thread on my build. I'm not sure many are interested, so if you want more let me know.
My build started out in life as a 1/2 ton, worked hard enough to enjoy a 14 year retirement in an old navy store. Now it's making a comeback as a 3/4 ton, NAPCO looking truck sitting on a 2000 ZR2 frame and drive trane. I didn't set out to build a 4x4 but got lucky and came across a ZR2 that had been rolled over. It belonged to the owner of a scrap yard and had been sitting inside without a body since he got it in 2001 with 18,000 miles on it. He was liquidating the place and after hearing about about it at 11:00am one morning I owned it when the auction ended at 5:00pm. Here's what it looked like when I first saw it June 08. Just try and get the stock radiator to fit under those fenders! So much for my low cost build. Did I mention this is my first build. So much to learn,, so little time. |
Re: 49 Chevy on a 2000 ZR2 low buck build
this is going to be interesting, can't wait to see how it progresses. Welcome
Yellow truck club
more please.............
................................................................ Brian ...... ![]() My hub garage address http://www.hubgarage.com/mygarage/59apache I gue$$ everything has it'$ price ALL GONE NOW ![]() ![]() ![]() ![]() PRAISE THE LOWERED 350 700r lokar shifter power MII front end, shockwaves tilt, 4 wheel discs 4-link and bags 10 bolt limited |
Within a couple of days of bringing the ZR2 home I started to realize that besides all the mechanical fitting challenges ahead of me fitting these two trucks into one, I hadn't given much thought to the wiring issues of a vortec. I quickly decided that I needed a complete cab harness (wrong) and quickly went back to the yard and bought half a truck cheep before he closed. I was told that the wiring was the same on a 2001 S10 4x4 as the 2000 ZR2, no problem (wrong again) and so I stripped the cab of its harness. After trying to mate them together I realized I had gotten poor information.
The extra half a truck showing up out back didn't get by the wife or neighbors either. After trying to hookup the harness the challenges became soooooo obvious. And only a few extra wires. I just kept reminding myself how much fun I was having. |
Hey 49ZR2, What is the width of the rear end from that Blazer. I know a guy near me that bought 4 brand new rear ends from the ZR2 and I need to know how wide they are to see if it will fit on my original frame. Is your 4 wheel disc, 3:42 Posi?
Thanks |
MORE MORE MORE!!!!!!!!!!!
got any pics of where you mounted your cab mounts? thanks
53GMC, I'll get some for you over the holiday weekend. I know they are modeled after some I found on this forum. I hope that's soon enough.
BlueJeep, I think I'm going to try and shorten the box and running boards as you suggested. It looks like mine could go forward about 3". I'll take more specific measurements and cut it down next weekend. |
#9 | |
One thing to maybe consider is that the rear mount on the running board where the bracket goes to the frame won't work in "stock" location...that would send it straight into the leaf spring mounting bolt. If you remove that bracket from the running board, you could move it forward a little more and make mounting of the running boards a little easier. I haven't done that yet on mine, I only have the front 2 brackets for each board done so far.
build threads: 86 Suburban 88 Jeep 6.0 swap 49 Chevy truck 54 Chevy wagon 86 Suburban lowered 4/6 54 Chevy wagon 49 Chevy/s10 mix 88 Jeep Wrangler rockcrawler |
That sounds good 49ZR2....im lookin for where they are placed and what side and a few other things...but any and all pics will be greatly appreciated! Thanks again!
53GMC
I went back through my notes and found a drawing of the mounts I used. There made out of 3" tube cut on a diagonal. As you can see in the images of the actual mounts I have them bolted on until everything is lined up. Then I will weld them in place. I will also add a short support on top of the rail. The mounts are based on drawings I think I found on this forum by Jeff51. They are however a different size. I used the stock ZR2 rubber mounts on top of them. For the back of the cab I simply used the stock mounts and through bolted them for now. |
and a few others
So, what about the wiring harness?
"stay focused, forget the rear end, what about the wiring??" ![]()
Bill ![]() BlueRidgeMuscleCars.com “The greatness of a nation and its moral progress can be judged by the way its animals are treated” Gandhi |
Bill, yesterday was thanksgiving and thanks to you and other vets like you I was able to enjoy another day with most of my kids and grandkids. Thanks for all that you vets do and have done!
"Focus" -- I started out trying to reuse the entire wiring harness from the trucks. After all they had these neat little snap together plugs, who could resist. After about a year of calling and emailing --- everyone I spoke to just wanted to sell me a new complete wiring harness. While I didn't think I needed a $1500 harness. Finally I stumbled on Larrys Electric http://www.larryselectricsite.com/index.html Larry was the first guy that took the time to listen to what I was trying to do and then try to give me some options. I decided to send Larry my motor and transmission harness and PCM. He reworked the harness ($400 I think) and re-flashed the PCM $100. I will buy or build a harness for the cab and lights. The harness worked fine right out of the box. |
Shortened the box this weekend
Bluejeep pm'd me with some pictures of how he shortened his box and running boards to match his wheel base. What an inspiration he was......where was he while I was trying to do it? Just kidding it was as easy as he said it was for someone who knew how to weld. I didn't so I did some research online and got started. After drilling out the welds I cut the box down 3", cleaned up the stake support brackets and welded them back on. It took most of Friday and Saturday but I'm stoked. I think it looks great! What are your thoughts? Below are the before and after.
My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=372267 49 4x4 build 51 Willys frame off beer getter. |
#15 |
Registered Chevy Owner
49ZR2, I'm glad to see that you have a build thread. I have some questions for you now. I've read in a couple different forums that the 4x4 frame with these body styles are a bit difficult to use. Did you have any problems with mounting your body? How high are you off the frame? It looks to me about 4". Last, are you driving it around yet? It looks like you could be.
Nice work on your build. Post a lot more pictures of you truck it looks awesome!
Love is fleeting, but Chevy trucks are forever!!!! ![]() 1970 Chevy CST C10 long box 350/400 ![]() 2008 Chevy Silverado short box 4x4 Had; 1951 Chevy short box 307/T5 1988 Chevy shot box 4x4 350/350 1971 Chevy C10 long box 4x4 350/350 1971 Chevy C20 long box 350/350 1971 Chevy C10 long box 350/350 |
#16 |
Nick, your right it sits about 4" off the frame in the front and 3.75" in the back. Thanks for the kind words
I did have some challenges alligning the front clip but it didn't have anything to do with the 4x4 frame. It was because it had been disassembled and in pieces. I really haven't found the frame to have caused me any real challenges. In fact sometimes after reading some of the other posts on this site mine build seems to have been pretty easy. Driving has been limited to the neighbors for a beer or two. I still have to mount the box and running boards, install a wiring harness and gauges, then disassemble everything and weld all the brackets in place. Then I can reassemble and take it for the big test ride - this spring I hope.
#17 |
Nick -
49ZR2 is right about the 4x4 frame not actually being that difficult. I used a 1996 V6 Vortec 4x4 S10 and it did not pose any major problems for me - in fact, the height that i was able to set my on the 4x4 frame actually made the clearance for many things a little easier in my opinion.... 49ZR2 - i left my motor in the stock location also...because we both have a 4x4 suspension and frame (although yours sits a little higher because its a ZR2) i think our projects are startin to look a lot identical! ![]() you are doing an awesome job...every picture you take really helps me out so keep em coming!! 53GMC |
#18 |
Hood Adjustment Blues - I've been surfing the site today while recovering from Christmas and noticed a post by snoopy0775 http://67-72chevytrucks.com/vboard/s...77#post3693777 In the post there are some pics from Richard H and Solidaxle that make my hood alingment look like crap. I probably will have to go back and play with the cab tilt again. My front clip came in pieces so I never saw it properly assembled. If any of you have hood alingment pics and advise please post them.
#19 |
truck is looking good, so how did you get ahold of it? every time I see one of these trucks sitting somwhere as a prop I think its such a waste.
#20 |
I will work on gettin you some pics 49ZR2.....i had mine all mocked up and had some motor fabbing to do so the moment i get it all back on i will post pics to this thread...ill try to hurry haha
#21 |
Thanks 53GMC, i'll watch for them. I thought I was really close until I saw what some of the other guys were able to do. So now before I start welding the mounts in place I should try adjusting the fit one more time. I think it's probably down to adjusting the cab front up or rear down 1/4" or so. Any close up pics of how the hood fits into the fenders is appreciated.
#22 |
After shortening the box, I finally got to work on shortening the running boards and the trim piece's. Here's a couple of pics. Welding the running boards seemed pretty straight forward. But the trim pieces - lets just say they were challenging and will need a little more work.
#23 |
Took the truck out so I could stand back and see what the running boards looked like. Thought I would share.
#24 |
Looks good all the way from Oklahoma! Really like this build. Always liked the ZR2 but the AD looks better on that chassis, and there aren't enough 4x4 AD trucks out there. Don't forget to post more as it comes!
#25 |
Looks Good!
Classic Trucks Link http://www.classictrucks.com/feature...uck/index.html 1958 GMC.Project Build http://67-72chevytrucks.com/vboard/s...d.php?t=162816 1966 Chevelle Build http://67-72chevytrucks.com/vboard/s...d.php?t=443576 Video http://www.youtube.com/watch?v=prrNKo8F7Zw#GU5U2spHI_4 |
