03-30-2014, 11:23 AM | #1 |
Location: Fort Mitchell, AL (out the back gate of Ft Benning)
AC opinion poll (and why)
Looking for input. I have a factory AC cab. Want to use factory controls and duct outlets. Want to change out all other parts for aftermarket, so I can clean up the firewall. All opinions appreciated. Experiences with products GREATLY appreciated. Will be going with the AAW harness too.
SSG Walker Harris '72 Cheyenne Longbed '66 Panel '66 Short Stepside '65 Short Fleetside |
03-30-2014, 03:48 PM | #2 |
Re: AC opinion poll (and why)
I don't know this for a fact, but I would be willing to bet that the aftermarket heater cores are much, much smaller than stock. I don't know of any other vehicle with a bigger heater core than stock '67 - '72 truck with A/C. Of course down in AL you probably don't have to worry about sub-zero temperatures for too long.
03-30-2014, 05:28 PM | #3 |
Vintage Air. You can use your oem control panel and your vents. Mine was not a factory A/C cab but I did use a factory A/C control panel with the Vintage Air replacement lens. Click on my build thread below to see quite a few photos of the system.
1969 RS/SS Z10 Camaro Pace coupe 1972 GMC Short Step buildhttp://67-72chevytrucks.com/vboard/s...=1#post6356218 1979 Mazda RX7 1979 Pontiac Trans Am WS6 & 1979 Pontiac Trans Am 10th Anniversary 1999 Honda Valkyrie 2006 Corvette Z06 2010 BMW 650i |
03-30-2014, 05:43 PM | #4 | |
03-30-2014, 07:57 PM | #5 |
Thanks for your service.
04-04-2014, 12:14 AM | #6 |
I have the stock heat and A/C on my 71 and the vintage air on my 72. The vintage air A/C is really good but the heat is not very good. It is just to small if you need any serious heat. In UT when it gets to 20 degrees even with a 195 thermostat and card board covering the entire front of the radiator with a big block the heat sucks. I can run a 165 thermostat in the 71 with stock heat and even when the temp is below 0 it is to hot in the cab if you turn the heat up.
Mike 1971 C10 350 1969 C20 396 1979 Corvette L-82 |
04-04-2014, 01:41 AM | #7 |
Old member
I have all internal new stuff in old AC boxes. You have to know what your looking at to tell it's not factory installed. I run the 134-a freon with a Sanderson compressor.
Coming to work tonight it was 84 degree's outside and 40 inside the cab.Condensor evaporator everything internally is newer 134-a stuff but I installed it all in the factory box outside. As far as making the truck firewall look cleaner it just makes it look out of place to me. With everything gone it looks like something is missing under the hood. Here are some close ups of the AC system. This is the old motor though.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
03-30-2014, 07:02 PM | #8 |
Too many leaky, heavy pieces 40+ years old with factory. Go modern and never look back.
04-04-2014, 06:58 AM | #9 |
If the factory A/C is in good working condition I'd just get used to looking at what belongs under the hood. I like my trucks best with the hood down anyway. Looks best that way,too
04-04-2014, 07:27 AM | #10 |
I like nostalga air in okala florida , vintage air is good also but expensive , I have no experience with oldair
68 Long Fleet , ly6 , turbo 350 , 3-5 drop , original paint , front discs 67 Small window , 7 foot bed , tweaked 6.0 LSX 2004R Medium Olive 58 Apache fleet , 235 , offy intake , dual exhaust , 4 on the floor , red/white 69 Long Fleet , Custom , 6.0, 4l60 , AC , Medium Olive |
04-04-2014, 09:00 AM | #11 |
I'm running VA in my factory AC truck. It cools good, maybe a bit better than the factory unit, blows out 42 degrees even on the hottest days. Heater not as good as factory. The blower motor forces more air through the vents than the factory motor. The in cab components are about the same size as factory, maybe a little smaller, and tucked up in the dash a little better. Renders the glove box almost useless. The engine bay side is where the major improvement takes place, nothing hanging off the fire wall.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
04-04-2014, 09:26 AM | #12 | |
Location: Formerly MD and San Diego, now loving life in Arizona
Really cleaned up the engine bay and looks good.
Alan 2012 Ram 3500 Dually Crew Cab 6.7 Cummins 2014 Palomino Columbus 340RK 5th wheel '69 Chevy C10 396BB |
04-04-2014, 01:36 PM | #13 |
If I had more money than time I'd go aftermarket.
Aftermarket is $1000 PLUS. I started with a non-AC truck, converted it to all stock parts, and still didn't put more than $500 in to it. If I was starting with a already stock AC truck, I could have it up and running in an afternoon for the cost of the refrigerant if no other parts were bad.
'70 cab, '71 chassis, 383, TH350, NP205. '71 Malibu convertible '72 Malibu hard top Center City, MN |
