Front roll pans WITH sway bar???
Was working on putting a sway bar on the front of my truck and
the roll pan is in the way......don't want to cut the roll pan back...... ![]() http://67-72chevytrucks.com/vboard/s...d.php?t=323691 What did all these guys do??
1968 Chevy C10 307 3ott fleetside 1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold 1967 Chev C/10 step, 383, M21. SOLD |
TOTY 2006
![]() Join Date: Dec 1999
Re: Front roll pans WITH sway bar???
What part of the sway bar is hitting the pan? (the bar or the frame bracket?) If it is the frame bracket, are you using a stock bracket or a lowered one?
I think I maybe looking at the wrong mounts......does anybody have a nice under shot
for the sway bar all mounted up??? Big help
Under Construction
like these?
Heath subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php http://67-72chevytrucks.com/vboard/s...d.php?t=157669 FAQ how to's 1956 Chevy Apache 1967 C10 SWB FleetSide (under construction) 1969 K10 SWB FleetSide (Future Build) 1972 C10 SWB Stepside (Future Build) 56 chevy truck : http://www.cardomain.com/ride/2955823/1 67 truck build: http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1 69 k10: http://67-72chevytrucks.com/vboard/s...d.php?t=389470 |
So these are the lowered ones!
brings the bar up from the road...right?
MOVE OVER
there are lowered brackets for the front sway bar, I'm not at home, but tonight I'll take a shot of mine..
No matter where you are..... There you are... Buckaroo Banzi |
That would be sweet. I did a search too....a few 73+ ones...
The first pic shows the mount I think I am looking at.
It comes right up to the roll pan. I would have to cut back the pan a few inches? It is hard to tell with out a front roll pan on there how close it comes to it. When I got my truck 13 years ago I sold the sway bar because it wasn't on the truck....and I had no idea at the time what it was...lol Now before I buy another I want to make sure it will go on without too much trouble. Thanks for those pics....now I know where the control arm mounts are. Just need the top mounts figured out.
Under Construction
mined are lowered sway bar mounts from ECE. and that is them installed on my pics i posted.
Under Construction
I thought i remember seeing this earlier this week. per the below thread they are stating your have to cut some of the front frame horns off to mount the front roll pan.
http://67-72chevytrucks.com/vboard/s...ight=roll+pans
MOVE OVER
I got the bar from randy (teeitup) and the bushings and such from Manes truck parts a few years ago. here is a picture of the drop brackets I am talking about. Not my truck but a good pic..
![]() another one. ![]() here is a link to some brackets. probably some board vendors have some... http://www.classicperform.com/ brackets $29
No matter where you are..... There you are... Buckaroo Banzi Last edited by rambler; 03-18-2009 at 10:36 PM. Reason: brain fart |
Found this pic. Not sure whos it is.
Yep the front is cut and the roll pan is soo close to the front top mount bolt that I am not to sure. Somebody want to come over with a sway bar...feel free...I got a case of cold Canadain beer for ya...lol ![]()
1968 Chevy C10 307 3ott fleetside 1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold 1967 Chev C/10 step, 383, M21. SOLD Last edited by 67chevemall; 07-09-2010 at 02:26 PM. |
So that must be a lowered bracket pic..?
It says on that site..."trucks with air bags use stock brackets" |
TOTY 2006
Which part of the sway bar bracked are you hitting? The part where bracket bolts to frame, or the part where the bar bolts to the bracket?
most of the ones in the pictures above look like stock ones. Here are two photos below are from Earlyclassic.com First one is stock height, second one is lowered height. |
#15 |
I think you are doing something incorrectly or maybe you have the wrong sway bar as there is no possible way the front roll pan and the swaybar including any type of bracket you are using could get in the way.
I just checked my truck and the front of the bracket is at least a foot back from the lower lip of the front roll pan.
67 Short Step, 355, 700R 4.11 posi rear, 4/6 drop Discs on all 4 corners. Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=219094 |
#16 |
Not the best pis but you can see how close the bolt holes are to the pan
#17 |
Never Ending Projects
I just checked my '68 and the front of the sway bar bracket is behind the large hole in the frame, using the bolt hole behind it (in your pic, the area with the blue on it). The rear of the brack mounts back up the frame rail, I think where you have the factory rivit. You have to drill out that rivit and replace it with a bolt that holds the cross member and sway bar bracket.
I think you are trying to mount the bracket too far forward, looking at your pics. I edited your pic and put arrows where you should be bolting the bracket to.
. 1965 C10 Panel, ![]() 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... Last edited by chevy_mike; 03-27-2009 at 06:21 PM. |
#18 |
Old member
Here is some pictures of mine on a 71 frame. I don't know if it shows enough or not.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
#19 | |
Sweet thanks the rivet was the problem.....thanks man
#20 |
Under Construction
yep you have to remove the rivet, i should have mentioned that, but could not tell from the pics you posted. good luck.
