Zinc In Oil
I recently found some military spec oil. it has a .14% zinc content. In my mind, that translates to 1400 PPM. Is this correct?
Here's the specs. |
Re: Zinc In Oil
1% = 10,000 ppm.
1969 RS/SS Z10 Camaro Pace coupe 1972 GMC Short Step buildhttp://67-72chevytrucks.com/vboard/s...=1#post6356218 1979 Mazda RX7 1979 Pontiac Trans Am WS6 & 1979 Pontiac Trans Am 10th Anniversary 1999 Honda Valkyrie 2006 Corvette Z06 2010 BMW 650i |
Re: Zinc In Oil
yes that's correct. To find ppm just convert the % to a decimal then move the decimal point 6 places to the right. Or if it's easier multiply by one million. So .14% = .0014 = 1400ppm Or .0014 x 1,000,000 = 1400ppm
That oil looks like diesel engine oil. Not sure how that zinc # compares to other diesel oils.
Dane 67 Chevy Fleet 250/4 speed 1/2 ton 68 Chevy 250/4 speed 1/2 ton for parts 49 GMC Grain truck 235 1 1/2 ton 76 Chevy 350/4 speed 1/2 ton |
Grandpa in the rustmobile...
Re: Zinc In Oil
Alot of our (af) engines/equipment are diesel engines.
Where would you find this oil to the public anyway?..
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
#5 | |
Re: Zinc In Oil
I went to an oil distributor in great falls and asked about zinc additive or oil with zinc. He had a few cases and said he could get barrels and might be able to get a tote. I have done a fair bit of research on oil and found that the diesel oil today doesn't even have zinc (Zinc wreaks havoc with catalytic converters). When it did have zinc, it was between 900 and 1300 on average. |
Re: Zinc In Oil
Been wondering the same.I read on a bottle of STP oil treatment and the bottle had ZDDP(same thing?)in it.
I know back when me and the wife married her father always run the oil traetment in his vehicles.never any oil useage. Just wondering. |
Re: Zinc In Oil
Search Brad Penn oil. Great stuff
A man's thoughts devise his ways; but it's GOD that directs his steps. |
Re: Zinc In Oil
I've heard that too. So what vehicle are you gonna use the oil in?
Re: Zinc In Oil
It's only $10 a gallon and all of our vehicles get the catalytic converter removed as soon as we bring them home, so why not run it in all of them?
Re: Zinc In Oil
Well I guess aside from the additive package being different there's no reason not to. I know lots of guys with old vehicles that use diesel oil in their old cars for the zinc. Me I like to stick with gas engine oil in gas engines and diesel in diesel.
Re: Zinc In Oil
It is my understanding that gas engine oil used to have zinc too. In the '70's when the gas vehicles started to have to have catalytic converters, the gasoline motor oil could no longer have zinc.
Re: Zinc In Oil
Zinc was in all oil up until the early 2000's Around 2008 zinc was removed from diesel oil as well. You either need to use a dedicated oil that has zinc in it or run a zinc additive. ZDDP is zinc but it usually isnt enough. STP oil treatment does NOT have enough zinc for a flat tappet cam. Joe Gibbs and Brad Penn and Valvoline racing oil are a couple off the top of my head. Comp cams,Edelbrock,Lunati etc etc etc all sell a zinc additive that will allow you to use any off the shelf oil.
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member. |
Re: Zinc In Oil
AMSOIL and Royal Purple aslo have oil with zinc fortified additives. I've been a fan of Royal Purple for years and highly recommend it. Here's Royal Purple's link for their HPS (High Performance Street) Oil. There is also a ton of info on there site for many of there oil products.
http://royalpurpleconsumer.com/produ...!hps-motor-oil |
#14 | |
Re: Zinc In Oil
#15 |
Registered Truck Offender
Re: Zinc In Oil
Just a mention here,, ANY oil with the API Starburst sold as over the counter as automomotive oil has a REDUCED level of ZDDP and other soluable metals. ALL OF THEM!!!. Klotz, Gibbs, RedLine, Amsol, RoyalPurple, Valvoline They can not have the API starburst and meet the EPA new standard for reduced ZDDP / Lead / etc. (including Rotella / Delo and all diesel oils as of 2008 as mentioned)
ONLY a off road oil (like the Royal Purple XPR) still has the full ZDDP package. It is not sold in your local PepBoys, and is marked 'NOT FOR HIGHWAY USE'. Royal Purple is a great oil,, I use it in most everything,, including the XPR in the race motors. But don't confuse the $18 a quart XPR with the $10-$12 standard over the counter, API / EPA version for highway cars. Even R.P., Amsol.. everyone who has the API starburst,, follows the SAME rules for reducing heavy metals.
Still playin with trucks, even at my age! When you're dead, it's only a problem for the people around you, because you don't know you're dead. .....It's kinda the same when your STUPID. I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral. Last edited by Marv D; 12-26-2012 at 10:42 AM. |
#16 |
Re: Zinc In Oil
Great info, Marv D. Also, GM has an additive, E.O.S. (Engine Oil Suppliment) that's available at just about any GM Dealership/Service Department.
#17 |
Re: Zinc In Oil
Not anymore.....EOS has been reformulated and no longer has enough zinc in it either.The only safe bet are oils or additives that specifically state zinc content.
#18 |
![]() Join Date: Jun 2012
Re: Zinc In Oil
OK so what are the benefits? (hope its not a dumb question)
#19 |
Re: Zinc In Oil
Benefits of what? Zinc in oil??
Zinc in the oil is the only thing that allowed flat tappet cams to survive. Without zinc the lifters and cam and lifters will eat each other. Its an absolute neccessity in an older flat tappet cam engine. Its 100 times more needed in engines with higher lift flat tappet cams.
#20 |
Re: Zinc In Oil
So it sounds like they have been phasing the zinc out, what have they been using in its place? my truck that I am building will NOT HAVE a catalytic converter and hopefully I can eliminate the O2 sensors also, I will look into the zinc additive.
#21 |
Re: Zinc In Oil
Most off the shelf oils have nothing in place of the zinc. Older engines are being killed due to cam failures at a ridiculous rate. If its a new enough engine to have catalytic converters and o2 sensors it probably has a roller cam.
#22 |
Re: Zinc In Oil
1997 L31 Vortec 5.7
#23 |
Re: Zinc In Oil
You have nothing to worry about. That engine has a roller cam. Roller cams are not affected by the lack of zinc in modern oils. You can basically run whatever oil you want.
#24 |
![]() Join Date: Jul 2008
Re: Zinc In Oil
Any thoughts or experience with Quaker State Defy? Found one reference on-line that notes ZDDP at 1200 for this oil.
#25 |
Re: Zinc In Oil
Ttt
