08-07-2007, 10:02 AM | #1 |
86 vs 1987 Fuel Injection - Cab differences?
Have an 86 gas (carb), and 87 diesel . Looking at 87 FI V6. Understanding the air/nonair difference, what else is different on the 87 cab to enable fuel injection? And would my diesel cab have the same items? 87 FI cab is rough, considering swapping 86 cab if little rework is required. Thanks!
08-07-2007, 07:02 PM | #2 |
www.73-87chevytrucks.com
Re: 86 vs 1987 Fuel Injection - Cab differences?
there is no cab difference on EFI vs non-EFI, the ECU for the carb mounts in the same place as the TBI ECU...
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com |
08-07-2007, 07:56 PM | #3 |
Great. How about the diesel cab? Did they plug the ECM wriring hole? Or use it for the glow plug controller and such? Manuals are coming but trying to decide if I should build 1 nice or 3 drivers. Thanks again.
08-07-2007, 08:05 PM | #4 |
The Crazy Machanic
how about 1 nice and a driver
*1986 Sliverado longbed 400 small block mean as hell, 700r4 trans (5 speed coming one day) * 1970 chevelle 2dr sedan Latest update June 24 2007. *1957 4 door stationwagon - pink all original needing a good restore (body great, floors bad) newest additions 1965 shortbed fleet great granddads. Been told im nuts to bring it back from the dead (still going to happen) plans-all stock with a turbo 292 inline 3 speed column shift. and thats it big block 427 and 5 speed trans and ford 9 inch theyhave no home yet thinking what to put them in and a 79 c60 trash truck um no idea i have one |
08-07-2007, 09:03 PM | #5 |
Next!
Big difference between the trucks in the fuel lines. TBI lines are different than carbed lines.
86 K30 CUCV M1028A1 86 K30 CUCV M1028a2 dually 86 K30 C&C 6.2 4:56s, 4M, 11,000 gvw, ex fire truck, now lowboy dump More square bodies and CUCVs than I care to admit to 2020 Silverado K3500HD Work truck |
08-07-2007, 11:51 PM | #6 |
You also want the gas tanks and all associated wiring. Those TBI tanks have the in tank electric pump with the correct fuel pressure for TBI.
08-08-2007, 12:17 AM | #7 |
I thought he was only asking about cab differences?
08-08-2007, 11:33 AM | #8 |
Yes, only cab differences. I'd forgot about ECM and carb (went from 82 gas to 87 diesel with 2 1990's and '99 in between). I'm pretty uup on the fuel systems and such, but the diesel is new to me. I can't imagine there are significant difference sin the cabs but thought I'd try to find out before getting started - usually I find out when everything is apart and undriveable.
08-08-2007, 12:29 PM | #9 |
On the Diesel, it should be any different either. I can't remember where the glow harness comes out, but I don't thing the hole is there. Don't quote me on that...
