My power steering box install on a 61
In searching for pics on installing power steering on a 60-62 frame I couldn't find any pictures, so I thought I would share a few from today on my 61.
I got a REZ bracket, didn't need the second plate, Like I've read these are designed for 63-6. After bolting it to the frame, the first thing is the lower rear hole needed elongated a bit inside and out. |
Re: My power steering box install on a 61
Drilling the upper front steering box hole requires a notch in the back of the frame
I cut the top rear bolt down and welded it to create a stud.
Drilled the two holes out on the steering box for the studs to fit through. Box fit right on. At the top on the back I welded the back of the stud and the plate to the frame, probably a little over kill, but thought there may be potential flex. |
#4 | |
![]() Quote:
I will be replacing mine with 1/2" steel plate and 16 gauge backup sandwich washer that I will be cutting on my Torchmate !! ![]() ![]() |
![]() Join Date: Oct 2006
Good job.I went with CPP 60-60 kit a total bolt on kit what can I say I'm lazy
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes. "Over, Around or through it... " |
Thanks for the pics. Looks great. Any plans on painting the frame? My 66 came from Norfolk. Talk about the rust! Good luck.
