Old 05-19-2004, 01:15 PM   #1
1970 CST Short Wide
Senior Moment
1970 CST Short Wide's Avatar
Thumbs up New 290 HP Crate Motor
Bought this yesterday for my son's 71. The old 283 that the last owner put in gave up. Chevy just came out with this one a few weeks ago. Not bad for $1599
It goes in this week-end, I'll let you know how it goes
Description
350/290 HP Technical Information
Horsepower ...... 290 @ 5100 RPM
Torque .......... 326 Ft. Lbs. @ 3750
Max. Recommended RPM .... 5100
Compression Ratio ....... 9.5:1
Block .................10066034
iron four bolt with two
piece rear main seal
Connecting Rods .. 10108688 Powdered Metal
Pistons & Pins.....12514101 Aluminum
Piston Rings ......12507985
Camshaft ..........3896962 Flat Tappet
Rocker Arm.........10089648 1.5 Ratio
Intake Valves .....10093027 1.94"
Exhaust Valves ....14095451 1.50"
Lifters ...........5232720 Flat Tappet
Oil Pump ..........12555284
Oil Pan ...........10066039
Spark Plugs .......R45TS Ignition Timing ...34deg
Fuel...............87 Octane
NOTE: The 290 horsepower was attained on the Dyno with the following specifications:
Carburetor.............600 CFM Holley (4150) P/N 12497147
Headers....1 3/4 inch diameter x 35 inch long with 3 inch collector
Timing.....34 degree BTDC total advance
1970 CST LS 1 6 speed Ford 9 inch Detroit Tru Track, Dakota Didgital, Vintage Air, QA1 Coil Overs Front & Rear Lots of FUN
2013 GMC PU, Oldest Son
71 GMC LWB. QA1 Suspension, Angry SB. Youngest Son
2019 GMC Diesil Dually. Youngest Son
2017 Toyota SUV Daughters car
2018 Traverse , Wife’s Ride
Pittsburg Ca
94565
1970 CST Short Wide is offline   Reply With Quote
Old 05-19-2004, 01:27 PM   #2
nevada70chev
where did you get it?
thinking about getting a new motor sometime, so i researching. where did you get it? also warranty? anything else? thanks.
70 LWB, 350/350 A/C, P/S, 3 Tone Paint (white cap, primer gray with black guide coat)
nevada70chev is offline   Reply With Quote
Old 05-19-2004, 01:35 PM   #3
1970 CST Short Wide
Senior Moment
My local Chevy Dealer had it in stock. 12 month 12,000 mile warrantee if they install. 1 year on parts if you install
Pittsburg Ca
94565
Old 05-19-2004, 02:40 PM   #4
busterwivell
I wonder if that's emissions legal for my 86 Monte Carlo SS? Is it just a long block?
Bill - Tucson, AZ
47 Chevrolet 2 dr sedan
56 Chevrolet 210 2 dr sedan
66 Chevrolet Malibu 2 dr 4 speed
71 Chevrolet C30 Longhorn
86 Chevrolet Monte Carlo SS (Sold)
01 Chevrolet Tahoe
IM - BUSTERWIVE@aol.com
busterwivell is offline   Reply With Quote
Old 05-19-2004, 03:20 PM   #5
1970 CST Short Wide
Senior Moment
This is where I got the info. I then called my LOCAL dealer to see what they had and to my surprize they had 4 in stock. Oh yea and they had the race version of the 572 $13,000 and some change
https://www.gmpartsdepot.com
Pittsburg Ca
94565
Old 05-19-2004, 03:50 PM   #6
71HUGGER396
Confirmed Truckaholic
71HUGGER396's Avatar
I think this is the best deal going for an engine. When I need one this will be the one I get.
71HUGGER396 is offline   Reply With Quote
Old 05-19-2004, 07:37 PM   #7
kickinasphalt
kickinasphalt's Avatar
Is this a Goodwrench motor or a GM Performance Parts motor? I take it must be a long block (no intake manifold).
NEVERMIND: Found all info here: https://www.gmpartsdepot.com/store/p...roduct_ID=1835
I bet with an Edelbrock Performer EPS intake this motor would make a bit over 300 horse.
1972 K-10 Longbox,6" lift w/35's/350/SM465/NP205/3.73
1972 C-10 Longbox,350/350
1998 Pontiac Grand Prix GTP
FOR SALE: 1971 K-10 Longbox,350/SM465/NP205
kickinasphalt is offline   Reply With Quote
