09-02-2019, 06:26 PM | #1 |
Is this just normal wear on an ignition switch...
I noticed this when I was given a gold plated key from my locksmith friend - when I tested the blank in my switch, I gave it a turn and started the truck right up.. I probably should get a new switch if that's the case - so I thought I'd inquire. thanks!
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop |
09-02-2019, 06:35 PM | #2 |
BlahBlahBlah
Re: Is this just normal wear on an ignition switch...
Man that's weird and scary!!!
What's your address again? =) |
09-02-2019, 06:38 PM | #3 |
09-02-2019, 06:39 PM | #4 | |
The Older Generation
It isn't a problem with the switch, it is a problem with the lock cylinder. Maybe there aren't any tumblers in the cylinder. It wouldn't be the first time someone removed them. LockDoc
09-02-2019, 06:41 PM | #5 |
BlahBlahBlah
Just realized that's a weird joke coming from someone that just got robbed ... Sorry =)
09-02-2019, 06:45 PM | #6 |
I thought it was great, CG -- lol
LockDoc, is the cylinder easy to pull? Isn't that the maneuver with a paperclip and turning it back past accessory position?
09-02-2019, 07:45 PM | #7 |
I did find the procedure to remove the ignition lock cylinder but try as I might it won’t come out I guess it will stay as is.
09-02-2019, 08:54 PM | #8 | |
"67's and some 68's don't have an accessory position. Just put the key in the ignition and "gently" turn it as far to the left as it will go. Insert a straightened paper clip in the hole (the large ones work best) and push the release pin down (go easy here, it doesn't take much pressure at all) and turn the cylinder to the left a little more. As you turn the cylinder you have to remove the paper clip or it will bind in the hole. The cylinder should pull out. You should not have to force anything." And here is a picture of all of the switch parts: Just for general info, you have to remove the lock cylinder before the bezel will screw off to remove the switch. LockDoc
09-02-2019, 08:44 PM | #9 |
Does your ignition switch go into an accessory position, which is to the left of the key straight up and down off position? It takes finesse to get the cylinder out.
09-02-2019, 10:50 PM | #10 |
Thanks Leon. Yes I was - but I wasn’t gentle like you suggest. Once I took it easy it came right out. There are not any moving components here to see. Can you tell by the pics of it is like you suggest, and why any key will turn it? My locksmith friend is not home at the moment, but I can show home tomorrow. Thank you.
09-03-2019, 10:36 AM | #11 | |
Take the same pictures with the key out of it if you can. I don't see any problems in those. When you remove the key the sidebar should pop out. (The rectangular piece in the second picture) LockDoc
Leon Locksmith, Specializing In Antique Trucks, Automobiles, & Motorcycles (My Dually Pickup Project Thread) http://67-72chevytrucks.com/vboard/s...d.php?t=829820 - Last edited by LockDoc; 09-03-2019 at 10:42 AM. |
09-02-2019, 11:04 PM | #12 |
This Mechanic where I live had a one of our trucks for sale on his lot. Wasn't all that nice, but I stopped to look at it. I took the key for my truck and started it. He come out and was a little peeved that I used my key to start it. Any how they get worn down and sometimes a smaller screwdriver will work.
Ron
Member #111 68 C-10 Daily Driver 70 4x4 Project 76 Jeep CJ-5 Help Support the Board: http://67-72chevytrucks.com/vboard/payments.php He who knows nothing is closer to the truth than he whose mind is filled with falsehoods and errors. Thomas Jefferson |
09-03-2019, 11:25 AM | #13 |
Here is the before and after with the key. The bar doesn’t stick out very much with the key removed. I take it that keeps the cylinder from turning. I think what’s happening is that the bar isn’t enough to lock it, and there is enough play to use my key blank to turn the ignition
09-03-2019, 11:54 AM | #14 |
New A/C Delco ignition switch from Auto Zone $29.00 Just replace it.
09-03-2019, 01:02 PM | #15 | ||
LockDoc
09-03-2019, 02:25 PM | #16 |
Thanks for all of the help. My locksmith neighbor/friend confirmed..
09-03-2019, 04:06 PM | #17 | |
No problem on the help. Sounds like you and your problem are in good hands..... LockDoc
09-03-2019, 06:04 PM | #18 |
On the bright side. You'll never lose the key to it, because any key will work, but so will everyone else's
09-03-2019, 08:38 PM | #19 |
I'll probably pick up another cylinder at some point to replace it. There is a great parts store out here called the Filling Station - they have new ones for $15
09-03-2019, 09:01 PM | #20 |
I recommend getting the 2 door locks and the ignition cylinder as a set, that way they will all work off the same key without having to get them re-keyed.
