11-22-2013, 11:11 PM | #1 |
1965, L6 292 Engine Power Steering Pump Set-Up
Have reviewed and reviewed posts for which years you can use to add an original looking power steering pump set-up to a 1965 292 engine. This is a question not an answer. Is it correct to say the brackets, pulleys, pump, etc. need to be from a 1973 or older 292 engine only?
This is my take from many post such as those by "71 SWB 4X4" and others. Thank you for your patience as I know their have been many, many posts on this subject. There are reported interference issues with using PS from 1974, and newer 292 on the older engines. Les |
11-23-2013, 11:34 AM | #2 |
Re: 1965, L6 292 Engine Power Steering Pump Set-Up
Here was my original 292 setup that I just sold
1965 long bed ( grandpas old truck ) 1964 long bed BBW Custom Cab 1966 Short stepside 1964 long bed 1965 long bed Custom Cab, factory air, V-8, powerglide |
11-23-2013, 11:36 AM | #3 |
More
11-23-2013, 11:38 AM | #4 |
Heres a 1963 292 with PS and AIR . Need to check part numbers on brackets, not sure what years are the same.
IS IT an EATON or Chevrolet rear axle https://67-72chevytrucks.com/vboard/...d.php?t=843778 The hubcap thread http://67-72chevytrucks.com/vboard/s...d.php?t=702839 WANTED : 1963-1966 6 Cylinder Fan Shroud WANTED :1964-1966 PANEL TRUCK |
11-23-2013, 12:02 PM | #5 |
11-23-2013, 02:01 PM | #6 |
Here is a pre 1973 292 setup that was on ebay a while back. Pay particular attention to alternator, water pump and crankshaft pulleys used for proper belt alignment.
11-23-2013, 02:03 PM | #7 |
That looks like the exact setup I posted pics of still installed on the engine.
11-23-2013, 02:15 PM | #8 |
Sig, your setup is from the 67-72 vintage, not saying at all it wont work, but I can see the inner fenders etc. Great pictures and info Sig.
Im curious now about the correct or originals for 63-66. The pulley on my setup is odd the way it sticks out but I have another factory 63 292 setup with the same pulley . I have more brackets I need to get out and compare.
11-23-2013, 04:22 PM | #9 |
The PS pulley number 3906398 on your pump posted Factorystock is listed as 1967-1972 292 only. The 1963-1966 292 only ps pulley is 3894044. This is only for reference, it is not criticism . Just interesting to learn and research.
11-23-2013, 08:04 PM | #10 |
footnote/reference: to my above pics, the alternator is a newer style replacement.
Les |
11-23-2013, 11:57 AM | #11 |
OK, Parts book is stating 1963-1971 on the six cylinder main bracket 3877430 then 63-71 support bracket 3891598. It just states 6 cylinder, not clearly 292
67-72 292 bracket 3914992 Again not clear but heres the pages from the parts book.
11-23-2013, 03:24 PM | #12 |
More great information, thanks. Looks like I have the crank, water pump, and alternator pulleys on my 65' 292 engine already that I need to add power assist steering.
Now I need the power steering brackets, pump and pump pulley. I am going to try and and get the original pump pulley if I can find one. Below are pics of my pulleys. Have not figured out tablet to let me post more then one image at a time. |
11-23-2013, 03:26 PM | #13 |
Another pulley pic
11-23-2013, 03:27 PM | #14 |
More pulley pics
11-23-2013, 03:27 PM | #15 |
Alt pulley
11-23-2013, 03:28 PM | #16 |
One more
11-23-2013, 03:34 PM | #17 |
Not sure what that white is around water pump pulley???
11-24-2013, 10:07 AM | #18 |
Les, check the way that alternator is mounted, I think its supposed to be a little further forward to line both grooves of the pulley in line with the crank pulley. It looks likew they added a nut or something to space the adjuster bracket.
11-24-2013, 10:16 AM | #19 |
These are the two main brackets for power steering on all 63-66 trucks 230 250 and 292. The difference with a 63-66 292 is the pumps pulley. These same brackets were used on all passenger car sixes also, Camaro Nova Chevelle and Impala and were in use on 230-250 trucks till 1970 according to the parts books.
This is a 1969 250 six C10 I have out back with the same brackets but different pulley. Again these are not correct for 67 up 292 but are correct for 63-66 292.
11-24-2013, 08:01 PM | #20 |
60-66
You are right they did add a nut so that PS pulley is offset, will remove tomorrow. Thanks for clearing up the information on the PS pump brackets. It is a great help! |
08-09-2014, 06:24 PM | #21 |
1964 BBC 402 4x4 |
08-10-2014, 09:00 PM | #22 |
Randy,
The PS pulley is pretty rare. I am still looking for one. Good luck. Les |
11-24-2013, 08:08 PM | #23 |
Thought I would add some pictures of my water pump pulley. Again my "Pad" will only add one image at a time.
11-24-2013, 08:11 PM | #24 |
Another pic. This with the fan removed. (Alternator pulley is offset-not correct in this image).
11-24-2013, 08:13 PM | #25 |
Close-up of pulley and spacer to move fan forward.
