Old 06-21-2015, 03:21 PM   #1
mr57
mr57's Avatar
Panel-specific questions
Finally starting to get at my 64 and was wondering a couple of things.
1) the back bumper has a slight bend in it. Is this a panel/burb specific piece? or is it the same as a fleetisde?
2) Will a fleetside rear 1/4 patch panel work? I need the back bottom half behind the rear wheelwell.
3) are there any aftermarket suppliers of rear door seals? and rear window seals?
mr57 is offline   Reply With Quote
Old 06-21-2015, 05:13 PM   #2
65sub
65sub's Avatar
Re: Panel-specific questions
Hi mr57. The back bumper is the same as a front bumper but with different mounting holes. You can probably find the indentations where the holes would be for a front bumper. The fleetside patch should work with some tweaking. For the rear seals, most suppliers should carry them. If you can't find them closer try http://billstruckshop.com here in Ontario
Dale
My suburban's Twisted Little Sister
http://67-72chevytrucks.com/vboard/s...d.php?t=655167
65sub is offline   Reply With Quote
Old 06-21-2015, 08:10 PM   #3
spacedebris
http://www.steelerubber.com/door-wea...rip-70-1254-72
http://www.steelerubber.com/rear-win...ket-60-0484-81
these are the rear door and window seals.
1960 c30 Apache Panel w/ '95 cummins bt6 turbo diesel (work in progress) NOTE: due to photobucket trying to extort money my photos are temporarily unavailable. currently looking for alternative to fix issue.
http://67-72chevytrucks.com/vboard/s...d.php?t=523009
spacedebris is offline   Reply With Quote
Old 06-22-2015, 01:41 PM   #4
Horacio
Horacio's Avatar
I also got my door seals from Steele
Horacio is offline   Reply With Quote
