![]() Join Date: Jan 2007
Parts from a parted 70 C20
This is all the parts left from my 70 c20. I will consider offers on all parts. And here we go:
EDIT: This is a list of everything in this topic for those who dont want to go through the posts. If you see something you want, scroll down and find it in the pictures. Blue Sunvisors: $18 plus shipping Rear Wiring harness and bezels: $10 plus shipping 6 cylinder Radiator with top hold downs: $50 plus shipping Hood Latch: $15 plus shipping Front Bumper: SOLD License Plate Bracket: $10 plus shipping Tailgate Hinges: $10 plus shipping Spare Tire Bracket: $20 plus shipping Rear Wheel Splash Shields: $15 plus shipping Windshield Wiper Motor and arms: $50 plus shipping Truck Camper Brackets: SOLD Auto Steering Column: SOLD Auto Pedal Setup: $30 plus shipping Drive Shaft: $30 plus shipping Under Dash Wiring Harness: $30 plus shipping Blue Seat Belts: $20 plus shipping Interior heater box: $25 plus shipping 1969 350 Intake: $50 no shipping 1972 Valve Covers: $25 plus shipping Exhaust Manifolds with downpipes: $35 plus shipping Mirrors: $15 plus shipping Hood Hinges: SOLD Gas Tank with 2 gal. of 93 octane gas in it: $20 no shipping Automatic column linkage (not complete): SOLD Battery Tray: $15 plus shipping. Blue Sunvisors in Good Shape. There is only one little tear in it, and they could use a really good cleaning. $20 plus shipping. ![]() ![]() ![]() ![]() Rear Wiring Harness for a 67 or 68 bed. It doesnt have marker lights. Some of the wires were cut and temp. fixed. The metal parts of the tail lights are rusted and through in one spot. $10 plus shipping. ![]() ![]() Last edited by Redden05; 03-21-2009 at 07:18 PM. |
Re: Parts from a parted 70 C20
6 cylinder Radiator. In very good shape. The black marks at the left bottom are oil stains. $50 plus shipping.
![]() ![]() ![]() Hood Latch in Good Shape. $15 plus shipping. ![]() Front Bumper (without the brackets) It has a spot where the metal is bent up. See the pictures. $40 and no shipping. ![]() ![]() |
Home Made License Plate bracket without a bumper or roll pan. With alittle work, this could look really nice. The light is brand new and plugs right into the factory harness. $10 plus shipping.
![]() ![]() ![]() Tailgate stuff. Needs cleaned up and painted. $10 plus shipping. ![]() Spare Tire Bracket and one of the rods. It is in good shape. $20 plus shipping. ![]() The shields behind the back wheels. The one is broken, but I have the piece and it could be fixed. $15 plus shipping. ![]() ![]() |
It's alsways something.....
![]() Join Date: Nov 2008
is the tear in the visor on the top side with it in the up position?
1968 RS Camaro 'Vert Matching number 327 and M21 Muncie 1968 C10 Black with red interior and orig paint. 5.3 / 4l60e,3:73 POSI 17" Torq Thrusts 1968 CST 514 Red with black interior. Buddy Buckets, Factory A/C, PS, PB- 20" AR custom shop TT, 5.3 and 4l60e |
Will you take five for the rear wiring harness?
For just the wiring without the bezels and housings? I will take $5 plus shipping for just the wiring. And just some info on it if you didnt see it earlier in the listing, it is a 67 harness without markers and it is cut in several places and I temporarily fixed them with wiring connectors with electrical tape around them. They should be soldered together for a good fix. Thanks.
Windshield wiper motor, rods and wiper arms with brand new blades on them. The motor worked nice. I'm not sure, but I think the washers even worked. But I'm not too sure about that. $50 plus shipping. I will break these up if need be.
![]() Truck Camper Brackets. They were chrome at one time. $10 plus shipping. ![]() Automatic Steering column. It has a 3 speed lens and the chrome on the shifter and turn signal lever has some surface rust. $35 plus shipping. ![]() ![]() Automatic Pedal Setup in Really good shape. $30 plus shipping. ![]() ![]() A 2 piece Driveshaft that has been shortened for a 700R4 or a long tailshaft 350 turbo. I dont know much about this as it was shortened before I got it. I do not know if it is balanced or not. It has a new rear universal joint in it. $30 plus shipping. ![]() Last edited by Redden05; 02-13-2009 at 08:47 PM. |
1970 Under the dash wiring harness. The truck had full gauges (no tach). The ignition plug has melted on this. It also comes with the harness from the front to the rear which had the insulation stripped off the wires to tap into them for some reason. $30 plus shipping.
![]() ![]() A set of seat belts in blue. There is a picture below of all the pieces. Only includes drivers and passenger seat belts, no middle seat belts. $20 plus shipping. ![]() ![]() Interior heater box stuff. $25 plus shipping. ![]() ![]() 1969 Intake off of an 300 hp 350. $50 and no shipping because this is heavy (unless you want to pay for the shipping). Valve covers off of a 72 V8. $25 plus shipping. ![]() ![]() Last edited by Redden05; 02-23-2009 at 07:33 PM. |
Exhaust Manifolds with new studs in them and down tubes. The passenger side manifold is cracked in the back like alot of them. $35 plus shipping.
![]() ![]() ![]() Mirrors. The top parts are nice (except the bolts are rusty on the back). The parts that attach to the door are rusted out. $15 plus shipping. ![]() ![]() Hood hinges. They are tight and could be cleaned up and painted. SOLD ![]() Last edited by Redden05; 02-23-2009 at 07:34 PM. |
is the wiring harness still available and dose it have the harness for the heater fan switch?
![]() Join Date: Apr 2005
What is the length of the driveshafts?
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
The front drive shaft measured from the front u-joint to the carrier bearing, it is 30 3/8 inch. The rear drive shaft measured u-joint to u-joint is 26 1/4 inch. If you want different measurements, let me know what you want.
You wouldn't happen to have any pictures of this installed would you? I'm trying to figure out if this will work in my suburban.
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 Last edited by Hart_Rod; 02-12-2009 at 09:47 PM. |
#15 |
I just might. I will have to rummage through all of my pictures I have. There are no guarantees though. Also, do you want me to get any other measurements?
#16 |
can u give me a price for the hinges shipped to 34116
Are you taking paypal?
Horsepower sells cars Torque wins races |
#17 |
#18 |
Hart_Rod: I found a few pictures of the same kind of drive shaft on a different truck. Do you know if the suburbans and lwb trucks are the same wheelbase? Do you have a 12 bolt in your truck? Mine had a Dana 60 rearend in it and was physically bigger than a 12 bolt, therefore the driveshaft is shorter. Here are the pics:
![]() ![]() And here is the driveshaft when it was in the truck (sorry, it was the best picture I could find) ![]() |
#19 | |
R/
#20 |
It was no problem Rob.
#21 |
ttt: all offers are considered if the prices are out of line.
#22 |
Here is a picture of the seat belts. I thought there was the center seat belts, but I guess there isnt. It has been awhile since I saw them.
![]() I also have a gas tank that is really nice on the inside. It has a small amount of surface rust on the top of it (on the outside) but is nothing to worry about. It is out of a 68 C10. $20 and no shipping. ![]() |
#23 |
ttt
#24 |
bump
#25 |
White wall terror
You wouldn't still have the wiper switch from the dash would ya? And how far are you from Levittown Pa.
