SWB 4x4 Collector
![]() Join Date: Jun 2001
4 spd. linkage pics?
Hey guys, my 70' 4x4 has a cobbled up 4 spd linkage and I am trying to figure out what correct linkage. I am needing pics of what to look for to make it stock. Thanks Trevor
TREVOR ![]() ![]() ![]() ![]() ![]() http://67-72chevytrucks.com/vboard/s...d.php?t=624819 ![]() ![]() :2004 Jeep Wrangler Rubicon (daily driver) WTB: 1968-70 Cruise Control Lever |
SWB 4x4 Collector
Re: 4 spd. linkage pics?
ttt
Are you talking about shifter linkage, or clutch linkage? Because a 4spd with the proper tranny in it won't have any linkage to speak of. The SM465 trans is a single rail style with the shifter mechanism mounted directly to the top of the trans and all the working bits are inside the case.
SWB 4x4 Collector
I guess I should be a little more specific. I am looking for pics for the clutch linkage that comes through the firewall down to the frame that hooks into the sm465. Thanks for the help. Trevor
Ahhhhh.....I gotcha!
![]() http://www.lmctruck.com/icatalog/cb/full.aspx?Page=134 don't thank me...thank google! ![]() |
SWB 4x4 Collector
Thanks Dave, this is my first 4 spd truck. Nice engine bay and great call on the engine lift cables. Trevor
#7 | |
I do not believe that is stock. The stock linkage through the firewall is not adjustable. The linkage from the z-bar to the clutch fork is. That is a good idea though. |
Also has a single master cylinder - pre 67 something GM but doesn't look like a truck. PS box on a truck is more towards the front and on the outside of the frame rail. BTW, the rubber boot on the clutch rod sticks inside the cab not out. When I put my 70 SWB together I had mine pointing out. When I bought my 70 Burb which was untouched I found it to be pointing inside from the factory. Changed it on the 70 pickup and it fits/works much better. I'll try to take some photos later on today. I have a set up off the truck which I can layout so you can get a "picture" of the set up.
1961 C1 Corvette 1959 El Camino 350 TPI, 9" 4 w disc 69 Blazer K5 - sold July '20 2021 Durango RT 5.7 Last edited by rsavage; 05-05-2010 at 06:50 AM. |
Yeah...that's just a google image seach photo, but it is enough to give you an idea of how it works. The LMC catalog page is better, but remember the view is from INSIDE the frame. Weird,huh?
