Old 04-26-2007, 01:41 PM   #1
68gmcjon
Got earplugs?
68gmcjon's Avatar
Big Block
I am finally parting with my engine.
It is a 402 big block with a long list of aftermarket parts. Runs perfectly. Bottom end was rebuilt about 500 miles ago. New bearings all around. I will consider selling individual parts if the whole engine does not sell. Any more info let me know.
Here's the list.
Cloyes Billet Steel Hex Adjust Timing Set
ARP Rocker Arm Studs 7/16"
ARP Rocker Arm Perma-Loc Nuts
Lunati Voodoo Camshaft Kit 284/292 .572/.590
System 1 Pro Street Fuel Filter 06-AN Ends
Holley Electric Fuel Pump "Blue"
Jone's Racing Products Billet Aluminum Alt. Bracket
Billet Aluminum Crankshaft Pulley
Speed Pro Powerforged Pistons Ring Kit
10.81:1 CR w/ 107cc Combustion Chambers
New 168 Tooth Flexplate
Moroso Blue Max 8mm Spiral Core Over Valve Covers
Melling Hi-Volume Oil Pump
Melling Screw In Pick-Up
MSD Blaster 2 Coil
MSD 6-AL
Jeg's Harmonic Balancer 7" Internally Balanced
Cloye's Quick Button Timing Cover
MSD Billet Distributor
New Bronze Valve Guides
CSI Billet Aluminum 360 Swivel Thermstat Housing
CSI Electric Water Pump
Eagle I-Beam Steel Rods
Barry Grant Speed Demon 750cfm. Mech. Secondaries
Barry Grant Fuel Line Stainless, Filtered
Edelbrock Victor Jr. Intake
Crane Cams Gold Race Billet Aluminum Roller Rockers
Comp Cams Hi-Tech 4130 Chrome Moly Pushrods 3/8"
Comp Cams Pushrod Guide Plates
Crane Cams Valve Springs/Retainers/Locks Matched for Cam
402 Block .030 over
New Rod, Main, Cam Bearings
Stock Iron Heads, 113cc. Combustion Chambers
ARP Bolts: Intake, Oil Pan, Flexplate, Harmonic Balancer
Complete engine, fuel delivery, and ignition system.
$4000 obo
Thanks for looking
1968 GMC
Original A/C, bucket seats, PS,PB
396 bored to 402, Dynomax cerama-coat headers, Super 40 Flowmasters, 272/284 Crane cam, Crane gold roller rockers, holley 750 cfm double pumper, Edelbrock Performer RPM intake, HEI ignition, 9.5:compression
Alltogether 411HP and 446ft/lbs
Dana 60 w/ 3.54 gears
Turbo 400 tranny
Why would you have anything other than a big block? HAHA
68gmcjon is offline   Reply With Quote
