04-14-2006, 08:08 AM | #1 |
4wd TH400 tranny options/problems dump truck
Hello,
My 1986 4wd one ton dump with a TH400 has lost reverse, as a matter of fact in neutral in goes forward and reverse it seems like it is just fighting itself. Put it in park and it goes forward too (parking pawl was broke, I replaced it but the slots it is supposed to catch on are rounded off). Is there any hope to get reverse going again for this tranny (without removing it)? The truck is used very little since it is for my own personal use, plow snow in winter and do a few errands(mulch, topsoil, gravel, etcl) in summer If it is doomed, I have 2 other used trannies that I am considering due to budget and I can get them for a few favors once the truck is on the road again. I can get a TH400 from a buddy out of a 2wd, but I do not know if a 2wd and 4wd have different output shafts? If they're the same, can I just unbolt the tailstock and bolt it to my xfer case? The other tranny I can get is a TH350 that has a transfer case on it. My transfer case has a PTO on it that I need for my dump, so can I swap just the tranny? Or... can I possibly install my PTO in the other transfer case? Is the length the same? Any other changes needed? Thanks for any advice you can give, I've changed lots of trannies but never had to mix and match before.
67 C10 396 stepside project 72 C20 402 72 K10 SWB (plow truck) 86 K20 |
04-14-2006, 01:20 PM | #2 |
Re: 4wd TH400 tranny options/problems dump truck
Sounds like your forward clutch has welded the plates together, try puting it in neutral and hold your foot on the brake and stand on it, it may break loose and if it does you will find you have reverse but no forward gears.
98 Neon 97 Grand Prix GT 02 Grand Prix 40th Anniv. 86 GMC 5.0 77 Olds 98 6.6 REAL AMERICANS, DRIVE AMERICAN |
04-14-2006, 08:11 PM | #3 | |
Another thought is to rebuild the one in it. Can anyone recomend a good book on rebuilding one. Thanks,
05-02-2006, 06:30 AM | #4 | |
Village Curmudgeon
by Ron Sessions Go to this site for great info on tranny rebuilding: http://www.technicalvideos.com/video...smission.phtml JP
78 Chevy K30 duallie, 454, TH400 78 IH Scout II, 4X4, 345, 727TF 76 IH Scout II, 4X4, 345, 727TF 65 IH 1200C pickup, 4X4, 345, 4 spd 48 IH KB-8-F, RD-450, 5 spd, 35,000 GVW (a REAL truck) "Life is too short to drink cheap beer." Harry S. Truman |
04-14-2006, 10:28 PM | #5 |
identify the type of transfer case, that will tell if it can swap but the length is different than a 400. You will have to change output shafts so that the adapter will work on a 2wd 400
