![]() Join Date: Jul 2003
Edited in list format:
Last week I ordered a couple of small parts for my '70 Blazer from my local GM dealer. These were: Washer jug 3840083 (may need to add the zero to the beginning) $50 list 1969-1972 E-Brake release handle 3893179 (may need to add the zero to the beginning) $11 list What other parts have you guys bought from the GM dealer within the past year? --------------------------------------------------------------------------------------
1970 K/5 Blazer CST 4WD, Bronze, 93k ACT. miles, 350, 4 speed, positraction, 16.5" x 8.25" wheel option, tilt, tach, vacuum, AM/FM, manual throttle...Dad ordered and purchased new 4/70. Currently frame off restoration in progress... ![]() 1972 Cheyenne Super 20 2WD, DK Blue/White, 90K ACT. miles, 402, TH400, 4.10 open, tilt, tach, vacuum, A/C, AM/FM, manual throttle.. A mostly original paint never rusted Texas survivor... ![]() 2017 Sierra 1500 SLT 4WD, Black, 41k miles, 5.3, 6L80E, 3.42 LS, 20" polished wheels, everything but moonroof and 6.2... 2019 Canyon SLT 4WD, White, 60k miles, 3.6, 8L45, 3.23 LS, 18" wheels Last edited by 1970cstblazer; 04-17-2021 at 10:32 AM. |
Carpe manana
![]() ![]() Join Date: Dec 2010
Re: Parts still available from the GM Dealer
Hood hinge. LH side I believe. Was loose though so had it rebuilt then phosphate coated anyway.
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 ![]() |
![]() Join Date: Mar 2003
Every time I call them they laugh at me. Locally they don't have anything unless the vehicle is newer than a 2010. When GM burned all their vendors a few years back by filing BK a lot of parts went away-----forever.
It's actually easier to get parts for my 50 year old trucks than it is my 91 Suburban. |
#4 | |
![]() Quote:
1970 K/5 Blazer CST 4WD, Bronze, 93k ACT. miles, 350, 4 speed, positraction, 16.5" x 8.25" wheel option, tilt, tach, vacuum, AM/FM, manual throttle...Dad ordered and purchased new 4/70. Currently frame off restoration in progress... ![]() 1972 Cheyenne Super 20 2WD, DK Blue/White, 90K ACT. miles, 402, TH400, 4.10 open, tilt, tach, vacuum, A/C, AM/FM, manual throttle.. A mostly original paint never rusted Texas survivor... ![]() 2017 Sierra 1500 SLT 4WD, Black, 41k miles, 5.3, 6L80E, 3.42 LS, 20" polished wheels, everything but moonroof and 6.2... 2019 Canyon SLT 4WD, White, 60k miles, 3.6, 8L45, 3.23 LS, 18" wheels |
RH is listed as available 3911706 $114.95 list
Carpe manana
Could be: http://67-72chevytrucks.com/vboard/s...30&postcount=5
The only way my local parts guy could get it at the time was to take overnight delivery. Routine orders were not being accepted at that time d/t virus related back log at the Lansing SPO warehouse.
![]() Join Date: Aug 2019
When I was working at the Lansing SPO warehouse in the 70's, you would have cried at the parts that we put in the crusher. Obsolete after 9 years.
Please stay on topic. Share if you have bought a new GM part from the dealer recently, and part number too.
![]() Join Date: Mar 2013
Local dealer here will help but you have to have a valid part number, was able to order the spring that holds the clutch fork onto the ball mounted on the bellhousing came in a package of 5 sorry don't have the number handy.
![]() Join Date: Feb 2009
I've never bought a local original part in my life. I take it back, found a defrost vent 25 years ago at the wrecking yard, the guy says shoot, I didn't know it was there
![]() There aren't many trucks locally and the wrecking yards cleared of them a long time ago. I remember wrecking yard that had quite a few. He ended up scrapping what was left, and apparently a local repop. dumped tons of OEM decades ago as well. If they only knew.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
![]() Join Date: Jul 2000
Funny. This thread reminds me of when I bought my 69 C10 back in 1989. I could still buy just about any part you can think of from my Chevy dealer.
Outer grille ($120-something) Cab mount bushings Cam, lifters, and timing set Gasket set TH350 frame-to-trans shift bracket Wheel bearings and races And lots more small parts I've forgotten about. I was able to talk one of the counter guys into giving me jobber pricing for the used car lot where I bought the truck, so my price was 25% off list or better.
Mike 1969 C10 LWB -- owned for 35 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. 1982 C10 SWB -- sold 1981 C10 Silverado LWB -- sold, but wish I still had it! 1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming. Retired as a factory automation products salesman. Worked part-time over the years for an engine builder and a classic car repair shop. Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then! |
#12 | |
And that was inner and outer, right?
Yep. I drove my C10 there from about 100 out because I had thoughts of a bed plastic bed liner
![]() Couple years later I bought 15x8 Rally's, with caps that are almost fully chrome out of Sacramento too. If I remember right the wheels are stamped 1992. Bolts too, that I can't seem to find at the moment ![]() ![]() SMOKING deal on NOS caps and bolts for sure, just four years ago too @ $150 & not a mark on them. Deals were out there until recently for the most part. The two stainless (73) version NOS caps I picked up four years ago run 3-4x my cost. I need two more ![]() ![]()
#15 |
Added more to the list as I find time to verify availability
#16 |
More added
#17 |
Cluster King
![]() Join Date: Nov 2012
Brings back some memories of my Michigan days. When I was 17, I rode my bike to the local GM warehouse (Drayton Plains, MI) and bought with my dads GM id, a pass side brand new fender for my 72 swb for $69.38 cents and holding it with one arm and riding it back home on my bike.
The last I heard, they stock nothing over 3 yrs old now. The good old days are gone
Contact me on all of your gauge cluster needs. I specialize in restoration, repair and parts sales for 67-72 Chevy and GMC trucks. email me at tbonegarris@yahoo.com I am also a dealer for Counterpart for gauge cluster parts only. Also see my facebook page, CG&C |
