12-15-2009, 09:10 AM | #1 |
rear sway bar installation
Does anybody have any info on installing a rear sway bar on a swb coil spring rear. I thought I ran across a website that gave the measurements, but I can't find it now. Thanks.
Aaron |
12-15-2009, 09:34 AM | #2 |
Retired Air Force Veteran
Re: rear sway bar installation
are you you installing the stock, pan hard bar or super track bar.
Harry 69' SWB Step Side 1/2 Ton w/68' Front Clip Swap from Leafs to Trailing Arms (Complete) Swap 6 Lug to 5 Lug (w/ Disk Brakes in Front) 3/6 Drop Help Support The Board Click Here For Information On How To Subscribe Krue's FAQ Page Vendors |
12-15-2009, 12:02 PM | #3 |
i've used the bolton helwig rear swaybar on two trucks with coil rears both were lowered4-5" the bar went on easy and worked great . i think i got them from jcwhitney
i liked it because it mounted ahead of the rear and clamped onto the trailing arms. which located the frame mounting points to the most rigid section of the frame with no panhard or gastank clearance issues as well as being tucked up out of sight
71c-10 350/2004r/4:11 lowered3/4 longbed/dead by hurricane MEANING OF DEATH::::: SOMEBODY ELSE GETS YOUR STUFF DONT BELIEVE EVERYTHING YOU THINK TAKE MY ADVISE;I DON'T USE IT ANYWAY Last edited by cdowns; 12-15-2009 at 02:06 PM. |
12-15-2009, 12:59 PM | #4 |
when i lowered mine, i replaced the stock springs for 6'' inch lowering springs from gmc paul's and used a super track bar from early classics (ece)
12-15-2009, 01:56 PM | #5 |
Like a Rock!
I called ECE (Early Classic Enterprises) about installing a rear sway bar and they advised me AGAINST doing this. I don't remember off the top of my head the reason though.
69 LWB Runs great - work in progress Mess with me and you mess with the whole trailer park! |
12-15-2009, 02:15 PM | #6 |
I lowered the rear with 4" drop springs and I have an adjustable panhard bar on it. I was wanting to mount the sway bar to the trailing arms.
12-15-2009, 07:18 PM | #7 |
They told me the same thing. Basically said it makes the truck loose.
12-15-2009, 02:32 PM | #8 |
Moderator
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man RIP FleetsidePaul |
12-15-2009, 03:08 PM | #9 |
Project '67 454
12-15-2009, 05:18 PM | #10 |
That's a big help. Thanks guys.
Aaron |
12-15-2009, 05:50 PM | #11 | |
Here are some picts of it. Which one are you using?
Get your facts first, and then you can distort them as much as you please!!!!!. Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild |
12-15-2009, 06:02 PM | #12 |
Big_al_71,
That's looks like the same one I have. I bought the bar and brackets that attach to the trailing arms at a swap meet. I need to make the brackets that mount to the sides of the frame. I also need to get the bushings. Why were you told it wasn't recommended when you dropped it more? |
12-15-2009, 11:59 PM | #13 | |
I replaced my rear trailing arms with the square tubing ones from ECE my truck rides 100% better than it did before with the rear sway bar. I did not want to drill my new trailing arms so the sway bar was coming off no matter what wether they said yes or no..
12-16-2009, 09:32 AM | #14 |
Anyone have thots on this setup? Looks like it would be a clean install altho not exactly bolt on. Im considering this on my burb but certainly open to input.
http://www.competitionengineering.co...?CatCode=13048 |
12-16-2009, 11:56 PM | #15 |
Am I missing one? There's one there but you cant see it too good since its black.
07-28-2010, 10:12 PM | #16 |
Any update on the Trans Sway bar on the rear? How does it feel??
1972 Chevy C10 SWB 1999 GMC Sonoma Mini 2008 Yamaha R1 2007 Harley Nightster |
03-04-2013, 01:56 AM | #17 |
any updates???
OLD thread
69 SWB 780hp Hellcat powered, manual 6 speed, currie 9 |
