Old 08-17-2006, 04:22 PM   #1
pat
pat's Avatar
Fan shroud for a V8 in the V6 position
I have a 383 in the v6 mounts on my 68 chevy truck. What are my options as far as a shroud? I have a fan clutch and a 4-core radiator. Would the stock v8 shroud work?
68 Chevy 383/350 w/shift kit, 380hp/425ft-lbs, 4.5/5 drop, 17" TT2s
64 Cadillac Sedan DeVille
pat is offline   Reply With Quote
Old 08-17-2006, 05:07 PM   #2
Shane
Shane's Avatar
Re: Fan shroud for a V8 in the V6 position
yes ... wanna buy an NOS fan shroud?
Shane is offline   Reply With Quote
Old 08-17-2006, 05:29 PM   #3
cdowns
cdowns's Avatar
if you're moving the engine back for imagined better handeling why not move back the 70-80 lbs of a full radiator back an equal amt for additional imaginary handeling
Old 08-18-2006, 08:07 AM   #4
pat
pat's Avatar
The only reason I have it in the v6 position is b/c thats the way the p/o had it, I didnt want to mess with changing it all up.
Looks like Ill stick with a stock shroud for now, try to find a 4wd shroud, Id like to do electric sometime, so Ill hafta save up for that.
Old 08-18-2006, 08:51 AM   #5
Boog
laying low
Boog's Avatar
Pat. If you run into cooling probs with the current setup because the fan blades aren't close enough to the shroud I have seen a couple of cases where someone used something like metal roof flashing to extend the shrould back to the blades. Just wrap it around the opening and pop rivet it to the plastic shroud. It's not much for looks (paint it black) but can be effective until you can find the 4wd shroud.
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 08-18-2006, 10:04 AM   #6
pat
pat's Avatar
I think Ive seen something similar to what you are talking about. Ill just have to see how it goes. Truck is gettting painted next week so it wont be long!
Old 08-17-2006, 06:32 PM   #7
Blazer1970
Blazer1970's Avatar
It seems like a 4X4 shroud should be pretty close to what you need.
Blazer1970 is offline   Reply With Quote
Old 08-17-2006, 07:30 PM   #8
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
A 4X4 shrowd is EXACTLY what is needed. A normal 2 wheel drive one won't do jack though.
Old 08-17-2006, 10:26 PM   #9
Americanrider
I installed a new 3 core in my 67 K20 truck (V8 in the I-6 position) and have ran without a shroud all summer so far, not a problem but then this ain't Texas. Loose the big clunkly clutch fan and go w/ 'lectric fans.
Americanrider is offline   Reply With Quote
Old 08-17-2006, 10:35 PM   #10
Longhorn Man
I ran 2 trucks in txexas with no shrouds... no problems. They weremounted in the forward position though.
Now, my third one is without a shroud too, but the fan is less than 1/2 inch from the rad...so it doesn't really need it.
Old 08-18-2006, 03:37 PM   #11
Americanrider
I was told by a member "leadfoot067" who lives near me that the stock 'letric fan setup from a V6 furd windstar fits right and looks like it was made for our trucks... heaven knows there are plenty in the pick & pull yards around here and they are dirt cheap too. Its one of the thing on my "to-do" list.
Old 08-18-2006, 03:50 PM   #12
HuggerCST
HuggerCST's Avatar
Why not just use the stock shroud with a 2'' fan spacer?
Wynne
70 CST short fleet Hugger orange & white, 350/350, ps, pb, air, tilt, tach/vac/speedwarning, original buckets, AM/FM, oak bed floor, shoulder belts, 3.5"/5.5" drop, 20" American Racing VN425s.
Build thread
53 Chevy shortbed
69 Camaro
Click here to subscribe
Chevy GMC International Truck Club Louisiana Charter Member
http://www.louisianaclassictruckclub.com
HuggerCST is offline   Reply With Quote
Old 08-18-2006, 04:23 PM   #13
pat
pat's Avatar
Can I use a spacer with my thermal fan clutch?
Old 08-18-2006, 04:47 PM   #14
kaycee
kaycee's Avatar
Thumbs up Re: Fan shroud for a V8 in the V6 position
That is what I did (spacer) until I found a good deal on my electric fan.
2001 Silverado K-1500
2005 FXDWG stage3
69 CHEVY Short/Step 327/4L60 373 posi
63 IMPALA 327
kaycee is offline   Reply With Quote
Old 08-18-2006, 06:43 PM   #15
Longhorn Man
A spacer with a clutch on the end isn't a good idea... lots of leverage.
There is also a chance that the angle won't be the same causing the fan to eat the shroud
