Old 07-01-2019, 08:03 PM   #1
Jl8806
14 bolt swap pinion angle ?
I'm trying to get all the cutting/welding/etc done before I send the frame and rear end to be blasted, I have a block I can set in to go off of but I don't have a transmission yet. Is there anyway I can get the pinion angle set so I can weld the new saddle brackets on the axle tubes.
Jl8806 is offline   Reply With Quote
Old 07-01-2019, 08:07 PM   #2
Mike C
Mike C's Avatar
Re: 14 bolt swap pinion angle ?
When i did the semi float swap in my Jimmy, I built a jig to locate the spring and shock mounts. I used a protactor style angle finder to set the pinion angle same as the stock axle housing relative to the spring mounts.
Level the mounts and measure angle. Set angle on new housing to match then weld on perches level.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 07-02-2019, 09:13 AM   #3
57taskforce
All about them K’s
57taskforce's Avatar
This is good advice. I actually used an app for my phone from TREMEC to set my 14 bolt up, you won’t be able to go that route without a complete drive train though. Mike C’s method will get you what you need for sure.
Tyler
