09-23-2017, 05:46 PM | #1 |
Has this rear spring been heated?
I'm planning brakes and lowering for my new (to me) 65 C10. The front can easily come down 4" (2.5 spindle and 1.5 spring) but the rear does not look like it could come down 6" by any means. The truck is pretty level now. Is this normal for the rear spring? Or was it heated maybe such that the middle coils are close together?
09-23-2017, 05:49 PM | #2 |
Re: Has this rear spring been heated?
Here is the rest of the plan for comment/feedback:
Been researching CPP, ECE (my first choice), and POL. I like ECE for all the American made stuff, but struggling with the $premium. POL is 10% off everything before 10/1 and sounds at least like the spindles are of equal quality. Not sure about the rubber bits, but the $500 in savings will go a long way towards more parts. Here is the thoughts: 1. 6 lug 2.5" drop spindle disc brake kit (hope the rotors fit behind the wheels which I believe to be Wheel Vintiques 15x8) 2. Booster & Master cal 3. SS brake lines 4. Front sway bar 5. Upper and lower control arm cross shafts 6. Maybe idler and pitman arm. Manual steering will have to stay until engine upgrade later. Not messing with PS on the 230 (been there, done that before.) Now the drop question. I don't want it to be "slammed", but definitely lower for a cool look and improved cruising. The truck sits level now. The front looks like it can drop 4" easy (2.5 spindle plus 1.5 more spring). The rear does not look like it can take 6" by a long shot. Is it possible the current springs have sagged and a new drop spring might not be a true drop (or even a lift?) I'm thinking of just ordering a 2" drop block kit for the rear, going with the 2.5" spindle on the front, and maybe cutting a bit off the front if I want more. I can add lowering springs to the rear later if the 2" blocks are not enough. This complicates shock ordering. I think I need a shorter shock for the front no matter what (2.5" or 4" depending) but can stick with the current rear shocks with 2" blocks. Then I would need shorter rear shocks if I added lowering springs later. Is this right? |
09-25-2017, 07:39 AM | #3 |
I agree with the front and for the rear I would start with 4" springs and a 2 degree wedge and a long track bar. That will give you about 4 1/2" in the rear. Drive it some and see how it settles out and you can ad a block if you need to. You will also want to get a shock relocation kit for the back and shocks all around. You springs may have had a little heat but may just be showing their age.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
