![]() Join Date: Aug 2005
Performer RPM ?
Is anybody out there running an RPM Intake and Cam combo? If so, how do you like it and how is the idle? Rough for street use?
Re: Performer RPM ?
Nobody's running this combo?
Re: Performer RPM ?
Guess not... alright, here's the specs on it. Anyone care to weigh in on it?
Cam Style: Hydraulic flat tappet Basic Operating RPM Range: 1,500-6,500 RPM Intake Duration at 050 inch Lift: 234 Exhaust Duration at 050 inch Lift: 244 Duration at 050 inch Lift: 234 int./244 exh. Advertised Intake Duration: 308 Advertised Exhaust Duration: 318 Advertised Duration: 308 int./318 exh. Intake Valve Lift with Factory Rocker Arm Ratio: 0.488 Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.510 Valve Lift with Factory Rocker Arm Ratio: 0.488 int./0.510 exh. lift Lobe Separation (degrees): 112 Intake Valve Lash (in): 0.000 Exhaust Valve Lash (in): 0.000 Computer Controlled: No Lifters Included: Yes Lifter Style: Hydraulic flat tappet |
Aluminum slot wheels rule...
Re: Performer RPM ?
ttt
WTB this ad
Re: Performer RPM ?
I personaly run the performer on both of my trucks. I just thought that they were more suited to the RPM range I would be running.
Re: Performer RPM ?
I have the RPM intake on my 355 with the 327/350 Hp cam. It works great.
Not sure on the cam in that kit. Just make sure you have the power in the range where you will be driving most of the time. It's no good it your making 375 hp at 6000 when you cruize at 2000 and make 150 hp in that range.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
Re: Performer RPM ?
Well that was my concern since the performer's range is supposed to be idle to 5000 but I figured the rpm should be ok since its range starts at 1500 and even though I don't have a tach, I know i spend a lot more time at 1500 then i do at idle.
Re: Performer RPM ?
What you need to do is search the flow rates on your heads. If your heads stop flowing air at .400 lift, then why put a .425 or .450 lift cam in it. You cannot pick a cam by its advertised RPM range, as this is an estimate. There are websites that post common chevy heads and their flow numbers. carcraft.com has flowed many different heads and created a chart. Without the cfm flow numbers you are guessing at best when it comes to picking a cam. Scoggins Dickey has some flow numbers for popular SBC nad BBC heads. Flow numbers usually start at:
.050 lift 25cfm .100 lift 50cfm .200 lift 65 cfm .300 lift 74 cfm .400 lift 85 cfm .500 lift 86 cfm .600 lift 83 cfm Look for the most cfm and then look at the lift, if the max cfm is at .500 lift and it is 2-3 cfm lower at .400 lift, then it is obviously better to go with .400 lift as it is easier on valve train. If you want you could go with .450 ish and not really lose anything. This is the ONLY way to pick a cam, period. Once you know flow numbers you can pick the lift and have a good performing engine. If you ar e sreious, find someone with a flowbench and have you heads flowed, if you have paid for port work and they didn't flow the heads, how do you know they helped the heads? A flow bench is the only way to verify how the heads work, new perf heads all list those numbers upfront, even the out of the box Vortec heads offer flow numbers. without knowing how much air your heads move you are guessing (at best what cam to buy) and more often than not we buy cams that are too big (too high of lift) and that hurts performance. I'd put a well matched small cam combo against the same motor running a too high lift cam any day, because the motor that has the correct cam to match the flow characteristics of the heads will flow the correct amount of air and not slow it down by opening the valve to far, and it will not wear out springs, etc from excessive lift. My .02 cents, but if you do not believe me, look into the cam manufactuers sites and talk to a tech, if they know what they are doing they will tell you the BEST way to pick a cam is to know the flow numbers and then the other stuff, ratio, trans, stall, etc. Good luck |
#9 | |
Re: Performer RPM ?
But simply put Advertised duration is also a huge factor. This is what will determine your cylinder pressure for a given static compresson ratio. too big a cam and your motors a slug down low, too small a cam and you have detonation issues and a cam that is far from optimal. Lobe seperation is important to say the least. If you want a scavenging effect, a peaky HP/TQ range and an idle like a pro stocker {My Nova} you go with the tighter 106,107,108 somthing around there. Now if you get in the 112,114 range you will have a broader power range a smoother idle and are better suited to run a power adder. These are other things to take into concideration way before you pull your heads off and have them flowed. As a side note, IMO most manufacturers lie about head flow but without flowing them all this will be your best bet if you want to pick a cam based on that. I have found through study that AFR and Brodix are the only 2 companies that dont inflate #'s, Brodix is actually conservative. Hence the reason i chose their race rite 200 heads for my nova.
-73' Nova 350 5-speed 9"rear, Runs 11's drives anywhere... -72' C10 350 Auto 12 bolt, runs 19's?? drives to work! |
Re: Performer RPM ?
Must...stop....reading.....Getting....dizzy.....Too...much...information....
![]() Just kidding... I'm going with the Lunati. If it sucks, I'll pull it. |
Re: Performer RPM ?
It's the cruize speed that matters you want the truck to have power starting around 800-1000 that way you have the bottom end power you most likely need.
Unless your using 4:11's and running in the 1/4 mile at 6500rpm, the Performer setup is better for the street. We all want to say we have a massive cam and 500 HP but at what RPM ? The key is getting the power in a range where it actually get's used. All I have is the intake on my motor the cam is mainly what controlls what rpm the power is made. Low end power is best for economy and driveability.
Re: Performer RPM ?
Good point Mario. The other thing I would be concerned about would be whether my 600cfm carb would be enough with that combo or would i need to bump up to a bigger carb.
Re: Performer RPM ?
500cfm is enough for a 400hp motor jetted correctly. A 600cfm will be fine. You can go bigger but it's not necessary. If you put in a huge cam (Which work great at high RPM that's what Race cars have them and sound that way)
You might need to increase the jet size.
Re: Performer RPM ?
Yeah this is true. Well I reconsidered on that RPM cam and I'm going to go with the milder Performer cam instead. Thanks for the good info!
#15 |
Dork For Days
Re: Performer RPM ?
You didn't say what size engine this is for.
Either way those duration figures are a bit stout. Normally big block truck engines run about 220* of duration and the SBs a little less. The lobe separation isn't bad, however. I'd check out the Edelbrock dyno sheets for the different combos. Look carefully at the torque curves. You're going to want as much down low as possible with the flattest curve you can get. You could also plot the combos in Dyno 2000 or something similar to get a better idea.
1972 C20, 402/700R4 - My first classic truck, bought in September 2005. 85% transformed from "Farm" to "Cool" status! ![]() 1970 Dodge Challenger 440, 4sp (my other toy) 12.67 @ 117 MPH, with a pathetic 2.022 60' 2007 Dodge Charger SRT-8 2008 Cadillac CTS All-American garage, baby! |
#16 |
Re: Performer RPM ?
The Edle cams are old school, go with a Comp Cam, Crane, Crower etc. the RPM cam unless you have some good CR it will run just OK, till I meet up with you at the light and leave you like you have an old Iron Duke 4CYL..
1967 C10 - SWBSS Pro Street 427sbc, 700R4 & 4.10 Gears 1948 Chevy FleetMaster Coupe, LS1, (almost done) 1950 Chevy StyleLine Coupe 250/6 3x2 Dueces 2009 Toyota Tundra 1996 Harley RoadKing "I maybe getting old, but I can still burn rubber with the best of them" |
#17 |
Re: Performer RPM ?
Please post your combo in detail here include your compression ratio.
Both edelbrock cams are crap in all honesty ill give a reason why. With the RPM you have 308/318 degrees of advertised duration. You really need at least 11:1 maybe 12:1 compression for that to work worth a hoot. Then the .050 duration is only 234/244. That is a TERRIBLY slow ramp and you would be leaving alot of power to be had. If you want me to explain this in serious detail i can. Call up a few major cam companies and get some responses on your combo. But i will guarentee you that youde be leaving TONS of torque and at least 20 hp and some gas mileage on the table by running an old ass Edelbrock cam. Call Crane, cam motion, erson, bullet, crower, howard, isky. Actually i would call Lunati about their new Voodoo cams. Harold Brookshire designed them so you know they are good. He used to own Ultrdyne cams and designed comps HE line 20 yeas ago. Call Lunati for sure....but DONT GET THE EDELBROCK CAMS....
#18 |
Re: Performer RPM ?
I also did not like there 1406 carb on my 84. I love my Demon it's like a holly but diffirent.
#19 |
![]() Join Date: Aug 2001
Re: Performer RPM ?
junkyardjohn 69 1 TON TOW TRUCK // 84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. ![]() LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS) DON'T RENT U-HAUL ALWAYS TELL THE TRUTH IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST |
#20 | |
Re: Performer RPM ?
Thanks John, I've seen a couple posts on the site that didn't have good things to say about Comp Cams so I'm staying away from them.
#21 | |
Re: Performer RPM ?
#22 |
Re: Performer RPM ?
I have a RPM manifold/w1406 and I am not to crazy about it myself (PO installed it). I would have gone with the regular performer/performer air gap if I had to do it again. I have a 350/700R4 w/3.73 and I rarely see over 4,000rpm. Most of my driving is around the 1500-2200 rpm range. Look for a combo the suits the majority of how you plan to drive the truck.
Sonny |
#23 | |
Re: Performer RPM ?
So you think its the intake and not the carb? You're the first person I've heard from who disliked the RPM intake but i've seen tons of posts from people who didn't like the 1406.
#24 |
Re: Performer RPM ?
My .02..
No experience with edelbrock cam. But I have been running a 625 cfm Carter for a couple of years (which is basically the same design as an Edelbrock carb) with a Comp Cams XE274. Motor was built by a professional and dynoed at 390 hp. I 've got around 10,000 miles on it and it runs great. No its not the fastest thing in a truck but it does move and somewhat quickly.. I am pleased. |
#25 |
Young truck fanatic
Re: Performer RPM ?
Well, I have The Performer RPM cam and Performer EPS Intake and reworked heads. So far I like it pretty good but I have had No Street time on this setup so I will see. I didnt know so many people hated Edelbrock Cams.
'67 Chevy Longstep 2wd 350 w/4spd manual Muncie M21. My first project. **Proud to be Valley Trash** |
