So I recently purchased a 70 C10 with a 307. It did not originally have power steering. The previous owner had begun adding power steering (transplant from unknown application) and completed everything except for installing the pump and crank pulley. He had the pump and brackets though, which he gave me with the truck.
So I got around to attempting the install today and can't quite figure out the puzzle. I'm not sure what he pulled the pump and brackets off of and I can't see how/where it mounts in. Here are some pictures that I thought might be helpful. Any help would be greatly appreciated. I have spent a lot of time going through pictures of these engines online and these forums and have not see any similar brackets yet. In the pictures there are two brackets. The larger one is actually a duplicate of the one already installed on the pump.
1970 C-10 lwb, 307 V8, THM-400 1998 Camaro Z28, LS1, T-56 6 speed manual (Daily driver) |
Re: Need Help: Power Steering Transplant (307)
for some reason, I cant see the pictures--not sure why. I'm interested as I'm doing the same conversion currently.
Figure out what you want--then figure out what you are willing to give up to get it. |
Proprietor of Dale's Corner
![]() Join Date: Nov 2012
I can't see them either
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man |
I did this on my 70 307 4x4 but no longer need the pump or bracket. LMK and I will dig it out for pics or sale.
It was pretty easy to do. I would put a frame strengthening kit in there while it's apart...
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 |
are you sure the stuff is for a short pump and not the long water pump? That would make everything more confusing looking to you. The pump brackets for the Swp are pretty self explanatory.
Sorry about the pics above, the link I used evidently was behind a user login so it all loaded for me. Try these:
![]() Join Date: Aug 2008
The ps pump and brackets in the photos is for a long water pump set up.
Use "teeitup" is an excellent source of items such as this. He makes a sideline/ hobby of parting trucks. I have bought quite a few pieces from him in the past. Great prices, quick shipping, no funny business of any sort. know you cant post a "want to buy" thread on the parts board, but i know of no reason why you couldn't send him a PM seeking the pump and brackets.
There are two brackets needed to install a ps pump on a sbc with a swp. One is like a cradle that mounts under the pump and uses the bolt holes below the freeze plug on the front of the block. (Originally the motor mount holes in vehicles using front mounts, before GM went to side mounts). The other bolts to rear of pump and to one motor mount holes.
Here is what they look like:
The photo is upside down. I took it with my cellphome and tried to edit it 180 degrees but it still post upside down. (!)
Next
Last
Another upside down one!
Here is a link to a post with photos of the brackets. http://67-72chevytrucks.com/vboard/s...d.php?t=592611 |
#15 |
Thank you everyone for the feedback. Can I use the pump I have if I get the correct brackets or do I need a different pump?
#16 |
Not sure if you can use the old pump but don't get rid of it til you are up and running. I have a pump and bracket with a chrome pulley on it that I am not using if you are interested...
